Question about Garden
Mower set under carport for 3 years, i replaced the fuel, but can't get it started. it will run while spraying carb cleaner into carb but quits once that's burned off. it's an lx277 twin cylinder kaw. fuel is squirting from fuel pump? what's wrong?
SOURCE: Fuel problem?
I have a 1990 ford f-150 whent to start it and nothing No fuel pump hum nothing I replced fuel filter and 2 relays and fuel safety not popped up all the engine does is crank over and thats it.
Posted on Dec 06, 2008
  • 246 Answers
SOURCE: mower wont stay running
Hello nater357:
>>From your Description it Sounds like a Bad Carburetor Solenoid, Restricted Carburetor Passages or a Stuck Carburetor Float Needle Valve.
>>The Following is a Basic Instruction File I made for Checking the Carburetor Solenoid. Any Input is Appreciated.
>>**Check for Current/Voltage (10.5 VDC Minimum) to the Carburetor Shut Off Solenoid. If the Carburetor Shut Off Solenoid has Current, then On Some Solenoids you can Remove the Needle and Replace the Solenoid to Test them.
>>****PLEASE DO NOT OPERATE THE MOWER WITH THE SOLENOID BYPASSED IN THIS MANNER. THIS IS "ONLY" FOR TESTING.****
>>For Others, Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 1/2" to 3/4" Long for the Horizontal Mount Solenoids and 1/4" to 1/2" Long for the Vertical Mount Solenoids. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid.
>>***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES***
>>Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jet Properly.** **Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. There is Some Slop/Free Play in the Solenoid Pin. Usually the Electromagnet is Simply Not Pulling the Pin as it Should or there is a Small Bur on the Pin. Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. Clean and Lightly Oil the Pin before Inserting it Back into the Solenoid. Just a Film of Oil is All it Takes.**
>>If the Carburetor Solenoid is Good, then
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 225 Answers
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Posted on Jun 21, 2009
  • 59 Answers
SOURCE: lawn mower ony runs at idle and dies after seconds
try holding the throttle open
Posted on Jun 26, 2009
pippall
  • 1486 Answers
SOURCE: 14sb mower starts and runs 2-4 min, then quits
The plug is breaking down.Change the plug.
Posted on Jul 24, 2009
How primmer bulb works
actually the bulb primer pumps a little gas into the carburetor. if it is torn or worn out the replacement is inexpensive and easy to replace. Ebay sells them for anywhere from 3 to 5 dollars. I replaced mine and still had hard starting and throbbing. I used it this way for quite some time until it finally would not start. I had been spraying the carb with cleaner for quite a while as well. Well I finally fixed it and here is how. You have to remove the filter and housing, then the frame that attaches to the carburetor and be careful not to damage the gasket. Once removed, look at the gasket and on the left side you will see a cut channel leading to a hole. Spray that hole with carb cleaner really well. Reassemble all and the mower will run like new.
Jun 27, 2014 | Craftsman Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
Mower started and ran great for about 50 mins. and then stopped. I added gas as it appeared to run empty. It started back up, but would only stayed running for a few seconds, before turning off again. ...
You did not mention whether your mower has a 2-cycle or 4-cycle engine. 2-cycle engine may require 2-cycle oil mixed with the gas to lubricate the pistons/cylinders.
4-cycle engines do not require mixing gas & oil as they have a separate sump for oil. These engines are quite easy to maintain and will last for many years. The most common problem is the fuel delivery system. If you allow the fuel to run low, debris sitting at the bottom of the tank is picked up and can clog the strainer (if so equipped). Check for a clogged in-line fuel filter and replace as needed. Occasional cleaning of the fuel inlet and strainer may be necessary; some disassembly is required. The carburetor jets also suffer from blockage usually caused by varnish residue from gasoline if the mower was allowed to sit for long periods of time without the fuel being drained or at least treated with some type of fuel stabilizer (Sta-Bil is one). If you have time, open up the carburetor and spray all the fuel passages with Gumout Carburetor cleaner to dissolve said varnish. Jiggle the choke mechanism while spraying to dislodge carbon build-up at the butterfly valve. And if you have a compressor, blow out these passages with pressurized air. Poking them with wire is a NO-NO. If it has a paper-element filter and it looks like you can plant grass on it, it is time to replace them. Does it have a re-usable/washable air filter? Clean the filter element with an air filter cleaner solution (or dishwash detergent) and re-oil (I use K&N filter oil) once dry.
Always use clean gas (your gas container may be contaminated over the years) and an ounce of STP carb cleaner per gallon of gas usually keeps things clean.
Apr 04, 2011 | Garden
Mower starts fine but conks out in about a minute or two.I changed the air filter but it still stalls a minute after starting. toro mower is about 2 years old
Recheck your fuel selector to make sure it is ON. Also if this is the first start of the season there may be old gas / debris in the bottom of the float bowl. One other area to check is the bottom of the gas tank / fuel outlet port of the tank. I don't remember if this model had an in-line fuel filter but also something to check if installed.
This is listed under Toro Mower with power tools that has a 6.5 Briggs and Stratton engine.
To clean the carb passages you will need to do the following.
(FUEL SELECTOR OFF)
1. The adjustment screw on the side of the carb that has a spring on it. You need to count the number of turns it takes turning it clockwise until it just comes up snug NOT TIGHT. Then remove it.
2, Remove the float bowl and dump the contents.
3. Spray carb cleaner in the adjustment screw hole.
4. Disconnect the fuel hose to the carb and spray carb cleaner in the brass tubing hole. The cleaner should be exiting via the float needle. Make sure float assy is down....
5. Connect the fuel line. (use a spray paint can lid and catch the fuel in this step. FUEL SELECTOR on. Catch fuel exiting carb. Lift the float to a LEVEL position and feul flow should stop. DO NOT FORCE IT! Gentle lift only.
FUEL Selector off.
6. Install float bowl
7. Re-install adjustment screw/needle/spring in the side of the carb. Turn it until it just snugs up.. then back it off the number of turns it took to initially close it before removal.
FUEL Selector on... wait 30 seconds..
7. Start mower.
That should do it.
Kelly
May 03, 2010 | Toro Lawn Mower With Toro Power Tools
Totr model #20479 GTS 5 motor, when you push prime
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 16, 2009 | Toro Lawn Mower With Toro Power Tools
My mower starts fine, and idles smoothly, but once I start moving, occasionally it will sputter, and the engine will lag a little, then will rev back up and then run smoothly for several more minutes...
Probably a dirty carburetor. Try some carb cleaner in the gas tank. If this is a Briggs engine, and the carb sits on top of the fuel tank, often times the pick up tube will become clogged.. You may have to remove the carb and spray clean it with carb cleaner spray can.
Also, spray the linkage on the carb.
Aug 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman mower will not start without starting fluid
Sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure your float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish by reattaching the air filter support bracket making sure the gasket between the carb and the bracket isn't damaged. Also, never use last year gas, alway buy freah every year.
Jun 07, 2009 | Craftsman Garden
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
