Question about Magic Chef CTB1722 Top Freezer Refrigerator
We have a Magic Chef CTB177GR refrigerator (no ice maker hooked up) that leaks...from where I don't know. I took off the lower back cover, it is dusty but no water present there. I pulled out the crispers and no water there. What next? Thanks.
  • intisarkhan2
    intisarkhan2 May 11, 2010
    Leaking water on floor or inside?
    President:
  • 1,218 Answers
Good day.
Water can only come from one place, where the frost is melted off the coil in the freezer during it's normal defrost cycles that occur daily.
Two styles. One style allows this condensed water to run down the back wall of the inside of the refrigerator, under the crispers and thru a hole in the bottom of the cabinet into a drain pan positioned
under the hole.
Possible missing pan, not positioned properly, or crack in the drain pan itself.
The other style drains the water to a hose mounted on the back of the machine, down and then into the pan.
Possible hose blocked, not connected properly, or the other items as described in first style.
It's a look-see type of repair.
Posted on Nov 17, 2009
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
Hello we have a magic chef refmodelctf1826arq which started to leak water onto the floor from underneath I can not find the reason why leaking ref is cold, and ice maker working.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Magic Chef Refrigerators
Ice maker will not dump ice
water freezes at 32 deg the ice mker works at 15 deg or lower . ck the tempts in freezer . if the freezer is lower than 15 deg the icemker may be at fault . .. mm hope this helps .. feed back pls .
Jul 09, 2011 | Magic Chef Refrigerators
Looking for parts for a Professional Series PS 78111 Ice Maker
It took me a while but for all of you looking for parts for this Ice Maker, it is the exact same product as Magic Chef Model No. MCIM22TS and you can order all parts here
https://www.mcappliance.com/partorder.aspx
Jan 29, 2011 | Continental PS78111 Compact Refrigerator
My magic chef wine fridge keeps making a loud popping noise every 15-20 minutes. It s model # WCMC458?
I have a Magic Chef wine cooler making that loud popping noise - Model # MCWC45MCG Could you let me know the way to fix it if possible or where to take it considering I live near Indianapolis, Indiana?
Aug 15, 2010 | Magic Chef MCWC45A Wine Cooler
Magic Chef refrigerator model CTF1923. erratic ice production
As long as your freezer temperature is at 0 you should have steady ice production. If you have to jumper the ice maker to get it to harvest then you most likely have a bad thermostat. That coupled with the leak issue really warrants just replacing the entire ice maker.
Be sure to ask for pricing on both the ice maker by itself as well as the complete kit. You may be surprised to find that the entire kit (including a new valve, line and bucket) will cost lest than just the ice maker by itself.
Jun 13, 2010 | Refrigerators
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Magic chef water running on floor, from under risper, i removed crisper did not see drain hole ice maker not hooked up
leaking from frig side or freezer side? If its freezer side the drain hole is behind back wall. Get you trusty blow dryer out...
Oct 16, 2007 | Maytag MZD2766GES Side by Side...
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef CTB1722 Top Freezer Refrigerator Logo
146 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
