Question about Compaq Presario V4000 Notebook
My cursor keeps moving to the left making typing almost immposible sometimes it works fine ??!
    Brigadier General:
  • 10,406 Answers
Either the "left-arrow" or the "backspace" keys on your keyboard is getting stuck in the "down" position.
Take the computer to a qualified technician, and get the keyboard replaced.
Posted on Nov 17, 2009
Samsung labtop cursor jumps around when typing causing all kinds of problems including highlighting and erasing entire lines or sentences!
Press Fn & F10. This disables the touchpad. You will have to use arrows or a mouse to move the cursor. This helps when you are doing a lot of typing. Press the same keys to enable the touchpad when you are finished typing.
Jan 21, 2012 | Samsung N150 (36725723009) Netbook
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
Scrolling/cursor problmem on Sony Vaio VGN-C140G laptop
Im having a similar problem , have you got it fixed yet? I really need some help the scrolling feature on my Vaio VGN - FZ31S does not work at all and I have tried everything.
Feb 20, 2010 | Sony VAIO Notebook
Cursor moves left when typing in internet explorer
under tools in IE in the general tab check the languages settings there may be a language in thre that writes from right to left.
Jun 03, 2009 | Computers & Internet
Cursor won't stay where I move it with the mouse
Hi, your first problem (and possibly second problem) sounds like it's the "Insert" function on your keyboard. I've seen this a lot. Find the Insert key on your keyboard. It's normally off to the right side with the Home, End, Page Up, and Page Down keys. When you have the problem, press the Insert key and then keep typing. It should toggle between the cursor moving with typing, and not. If this was helpful, please rate my response. Thanks!
May 15, 2009 | Dell Latitude D820 Notebook
Wireless controller is constantly moving down
One of two things. First, when you turn on the power, do not have anything pressing against the joysticks. It will sometimes cause the problems you are describing. If that is not the case, I would assume you got something stuck under it or spilt something on it. Good luck.
Apr 28, 2009 | Microsoft Xbox 360 Wireless Controller
Typing problem
I think some key board problem..try to use a external key board...
Dec 01, 2008 | Computers & Internet
Typing english words in a persian document
An easy solution (for me) is to type what I want to insert into a document in its own "notepad" page.
After I've typed what I want to insert, I copy the whole thing (Cntrl + A, then Cntrl + C) from the original document. Then, I return to the document I'm working on, make sure the cursor's where I want to make my comment, and paste it (Cntrl + V). That usually will even keep the formatting from the notepad script.
Oct 17, 2017 | Microsoft Digit Media Pro bx100005...
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Compaq Presario V4000 Notebook Logo
1,000 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
