Question about ORIS Watch Williams F1 Team Day Date 63575954194RS
Hello. I just bought an Oris Williams automatic watch on EBay. I was able to get it started and adjust the day/date but it stopped overnight and now it will not re-start. I tried moving the watch around for a while to rotate the automatic winder but it still will not start.
    Scholar:
  • 110 Answers
I presume they told you on E-Bay that the watch ran ok. If it was mis-representitive that's another story that you probably have some recourse through E-Bay to return and get you money back. If you are stuck with the watch, then it may just need a good cleaning by a reputible watch maker/repairperson. You can also purchase some rather inexpensive watch winding machines to keep the watch wound if you don't wear it all the time. Hope you get it working, Good Luck
Posted on Nov 19, 2009
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Apr 16, 2010 | ORIS Watch TT3 Day Date 63575887067MB
Need help with ORIS Miles Complication 58175284061LS Watch: The hand for ''day of the week'' came/drop off and I wanted to get it put back in place. Will be sending it to Oris service centre. Is it...
most watch companys will only do this with a full service as you have found out wich is not needed i would find a good local repairer to do the hand replacement wich is only a 30min job..and yes you can use your crown or fit a new one remember to ask for a reseal for watch as well..as far as i know oris use a Valjou movement in this watch made by ETA of switzerlamd so parts hands etc are no problem for any repairer to buy and fit..
Mar 25, 2010 | Watches
I have an Oris BC3 which was never a great time keeper; gaining or losing 5-10 seconds per day. Recently, it started to gain at an alarming rate and I took it to be cleaned and regulated at a watch...
Take your watch back to the watchmaker and ask to regulate the watch again. After a decent repair watch shouldn't loose or gain that much and if properly regulated and tested can keep good time. ORIS is using the same Swiss made ETA movements as Tag Heuer, Ebel, Montblanc, Tissot, Maurice Lacroix etc. These are very good mechanical movements and can be adjusted to allmost perfect timekeeping.
Dec 22, 2008 | Watches
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
4. Press ADJUST to view lap time. Press again to sesume lap timing.
Nov 22, 2008 | Timex 1440 Nylon watch
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Timex Indiglo Acqua watch
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
Dec 05, 2007 | Watches
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
ORIS Watch Williams F1 Team Day Date 63575954194RS Logo
378 people viewed this question
Top ORIS Watches Experts
Ansel Alberto
Ansel Alberto
Are you an ORIS Watch Expert? Answer questions, earn points and help others
