Question about D-Link GamerLounge DGL-4300 Router (DGL4300)
Will not let me into router. only have an option for password and nothing works. tried resetting to default and it still doesnt work
  • 2,263 Answers
Are you trying to access the router set up ?
First make sure that your computer will be connected to the router with the ethernet cable.
Now check the IP address and Default gateway on the computer. Default gateway will be the IP address of the router.
When you try to access the router it will always ask you for the password.
Try the default user name = admin and password = admin
or try user name = blank ( do not type anything), password = admin.
if that is not working then the password of the router must be changed.
try some different password that you use most often.
If that doesn't work then you will need to reset the router and reconfigure the router.
once you reset the router , you will loose all the settings on the router.
Reset the router for 30 seconds. unplug the power. plug it back in. wait for 1 minute and try to open the page again.
Click Here to know more about how to reconfigure the router
Posted on Nov 18, 2009
  • 4,281 Answers
Connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Posted on Nov 17, 2009
2 Suggested Answers
  • 1082 Answers
SOURCE: I try to acces my
Look on the back or bottom for a reset switch. Usually it is recessed and you need a tip of a pen or paperclip to push it.
Hold it down for about 10 seconds.. Then power off and on. This should set it to factory settings, and you should then be able to use default login and password.
Posted on Dec 01, 2010
Router was reset and had to make it secure. When I applied the password it said invalid password. Tried several times. Then I got an unable to join message. Next day worked a little more on the router...
If you reset the router perhaps you reset the password as well. there are default password lists on the internet for your make and model router. However for your username and password i would try admin for both fields, or just user and leave password blank. If that doesnt work sometimes tech is the default password. Again it depends on the model. this is a site for default passwords. your router may be here http://www.searchlores.org/defpasslist1.htm
Hope this helps you Sean
May 06, 2011 | Computers & Internet
How to find user name and password
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and thenpower for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open abrowser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 25, 2011 | Belkin F5D8236-4 Router
When using set up system is asking for a password for linksys G
have you tried entering a blank username i.e. enter nothing? and use admin as the password
if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
if you find this info useful please vote
Feb 23, 2011 | Linksys Wireless-G WRT54G Router
I try to acces my router options and it asks me for username and password, ive tried all the default usernames/passwords but it still doesnt allows me to enter, ive even tried on different computers,...
Dec 01, 2010 | Computers & Internet
It doesnt sign in with default usename and password
If you cannot sign in with the default username and password , you can try first typing your commonly use password and username but if still not working there's chance that the username and password was change so there's no other option here but to reset the unit by pressing the reset button of it for 10 seconds while power is ON then it will be back to the default settings with default username and password...
Dec 15, 2009 | Arris SURFboard SBG900 Wireless Router...
I can not remember the password to get in my router
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
Hi, I am trying to reset my 2wire 1800HG router in order to restore to factory default. I reset to factory default on the webpage for the router, and then hit the reset button on the router itself. Now, I...
you have to open internet explorer and type 192.168.1.254. then go to broadband link at the top of the page. hit the advanced settings then you have to re enter all you information like your username, password etc... i hope the helps you if i doesnt let me know.
May 18, 2009 | 2wire 1800HG Router (RG1800HG00)
The default username and password to configure router doesnt work
Try to turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin. Also turn off any firewall you have.
Apr 01, 2009 | Linksys WRT54GL Wireless-G 54Mbps...
I need help trying to put a password
By default, Username is "admin" without the quotes and Password is left blank. Once you are in configuration, you can change the default Username and Password to whatever you choose, then hit "Apply" to save it.
If neither of those options works, do a complete reset of your router by holding a small object into the reset button located in back for 30 seconds while plugged in and continue to hold it another 30 seconds while unplugged. Reconnect everything and try the steps above again.
Mar 03, 2009 | Linksys Wireless-G WRT54GS Router...
192.168.1.1 the default IP Address of my router is not working.
easier to configure if direclty connected using ethernet cable not through wireless laptop or anything wireless.
type in exactly in address bar 192.168.1.1 nothing else(no http or www.) and hit enter. if this doesnt work try to hold the little button near power plug on router for about 10 seconds to reset it and try once again. If it works when you type in the 192.168.1.1 and hit enter you will be prompted for password. user is always linksys and the password by default is admin. then hit enter. now you should be in configuration pages.
Feb 21, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
D-Link GamerLounge DGL-4300 Router (DGL4300) Logo
380 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
