Question about Motorola Mobility RAZR V3
My screen has gone dark. Howdo I get te dispaly to
My screen has gone dark. How do I get te dispaly to function again?
Black Crayon marks in lt colored couch and floor
try using a cleaner called goo-gone, it disolves a multitude of different oil and wax based staind and marks I use it to remove gum from a dark green couch and then a white carpet. Both stains are gone no residue, it has a citrus smell that fades with regular soap and water after te stain is gone.
Feb 11, 2011 | Garden
Two thirds of the picture has gone dark on 42lg5000-za tv
The problem actually is from a lamp in the unit, it is getting damaged gradually that is why it is two third of the screen that has gone dark. once it gets completely damaged, the entire screen will turn dark.
Try to ***** the lamp of the television and replace it with a new one.
After doing that your television will be in good condition once again.
Take care and good luck
Oct 23, 2010 | LG Televison & Video
Hi first I would like to thank you inadvance your technical support to me. the problem is that the screen is not functioning it stayes dark.
I assume that you can at least see the display like texts or images on the screen even if it's dark. There four things which can cause this, first the display cable (flex cable), second the display connectors on the display or on the board of the mobile/phone,third is display ic and the fourth is the display itself.
To troubleshoot this, it's a must to open apart the set, you'll need appropriate screw drivers and spares like display and flex cable.
Open the case, disconnect the terminals of the display flex cable from both the display and from the board, do some cleaning with alcohol/spirit/ipa solution with a soft brush, and again reconnect them after it's dried. If this isn't successful, go to next step.
Next replace another cable (display) and check if you can see the light on the screen or not. Again there's no light? Next step...
Connect the other display (should be a working display of the same model and type). If the problem goes, then your solution is replacing the display. If not the display ic which only professionals and trained technicians can handle.
Hope this helps.
Good luck.
Thanks for using FixYa.
Jun 27, 2010 | Samsung S3500i Cell Phone
Dark Screen even when i adjust the 'brightness' tab?
check the power settings on te unit, if it is set to default for the backlight, possible that your LCD's backlight is not powering up properly on the unit or LCD's backlight needs replacement.
Jun 03, 2010 | Apple iPod touch
W810i's dispaly problem
there is no other way except getting a new screen but a local phone repair shop would more than likely be cheaper than sony ericsson service centre
Apr 08, 2010 | Sony Ericsson Walkman W810i Cellular Phone
The screen is too dark to read
See if there is a contrast adjustment somewhere on the laptop first, if not then its a possibility your back light has gone and needs replacing.
Jan 19, 2010 | Acer Aspire 3000 Notebook
Screen is dark
Is this a brand new computer? Was it displaying properly before and just suddenly started showing up dark?
Most laptop monitors have a brightness control. It is possible that yours may have been inadvertently turned all the way down (it can happen accidentally). It is usually accessed by a function selector on the lower left side of the keyboard in conjunction with a function key, like F7, F8, F9, etc... you should check your manual first to be sure.
If that doesn't help, then it is possible the backlight for the LCD screen has gone dead. Those can be replaced by authorized service centers.
Dec 29, 2008 | Everex StepNote NC1500 Notebook
Laptop screen very dark very,very,difficult t read.Laptop has t0 be lnked to an ouside monitor
You have lost the lcd backlight, probably the backlight power supply, this is very common. What type of laptop is it?
Jul 16, 2008 | Intel Motherboard
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Dark screen
go to your dispaly setings and check on the contrast and ilumination, if they are low, increase them and the screen will be bright
May 16, 2008 | Nokia 6133 Cellular Phone
Motorola Mobility RAZR V3 Logo
114 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
