Question about Palm Pixi Cell Phone
When i go to create a profile it says my internet connection isnt working when it is! help!!
My laptop will not connect to the internet when i click on the internet explorer icon the little circle spins round for a bit then nothing happens.I've noticed asymbol in the bottom right hand corner...
it might be possible that there is a virus in your computer which is causing this...if ie is not responding create a new user profile...go to control panel click on user profile...create a user profile by going into manage another account.(give the admin rights to new profile)
once the new account is created..log off from this account and then login to the new account check there if its working there or not
Aug 11, 2011 | Computers & Internet
What is the gprs/mms setting for sony ericsson X8? my network provider is globe philippines. i went to their customer service but even the representatives there can't help me with my problem.
Just follow this Guidelines
GPRS SETTINGS
1. Go to Menu>Choose Settings>Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Browser, Slect Options and click Internet Settings
6. Add New Profile
Connect Using: MyGlobe GPRS
IP ADDRESS: 203.177.042.214
ADVANCED
Chg. Homepage: MyGlobe GPRS
Address: http://www.globe.com.ph/globe.asp
Save Profile
MyGlobe Internet Settings
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
5. Go to Messages>Picture Messages>Option>Internet Profile
6. Create New Profile
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
9. Save Settings
10. Go to Messages>Picture Messages >Options
11. Edit Message Server
http://192.40.100.22:100.21/mmsc
12. From Message Settings, make your Internet Profile: MyGlobe MMS
Hope it helps...
Jul 15, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Hi, i am using internet with airtel mobile office service on my Nokia N72 . Whenever i'm trying to open a file on youtube it shows Define default access point first so what can i do please help
u have to make a new profile-
Manual Settings on Mobile 1st step:Create a data account in the name AirtelGprs
Access point as airtelgprs.com or airtellive.com Then leave all other blank 2nd Step:Then create an Internet Profile name with AirtelGprs
In "Connect using "
option select
"AirtelGprs " access
point that we have
created in step 1 proxy:
100.1.200.99{not
necessary if you use airtelgprs.com } Port: 8080
Thats all
Activate this profile for
streaming Then connect to
m.youtube.com Related Topics enjoy streaming video
Jun 13, 2011 | Nokia Cell Phones
Internet not work.
The user can surf the internet as the KP500 cookie mobile phone supports HTML/XHTML and WAP 2.0 web browsing technologies, providing speedy connections. The EDGE and GPRS technologies provide not only a speedy service but a good quality of service especially for data transfers. The user can connect their LG KP500 mobile phone with ease to other compatible devices with the USB and Bluetooth with A2DP technologies. The KP500 operates on a Quad-band network and covers GSM-850/900/1800/1900 enabling the user to use the roaming facilities as and when abroad. The LG KP500 supports a document viewer which enables the user to view documents in XLS, DOC and PDF formats.
To Setup the Access Point
  1. Go to the Main Screen
  2. Select Menu (the 4 dot button)
  3. Select the Settings tab
  4. Select Connectivity
  5. Select Access Points
  6. Select Add access point
  7. For the Connection name enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  8. Set Authentication to This option varies on devices but typically is similar to the setting provided.
    ">#Authentication
  9. For the Username enter The Username for the connection provided by the Carrier.
    ">#Username
  10. For the Password enter The Password for the connection provided by the Carrier.
    ">#Password
  11. For the APN enter Access Point Name - Similar to the server the connection uses for the connection. Different APNs provide different services.
    ">#MMSAPN
  12. Select Save
To Setup the Internet Profile
  5. Select Internet profiles
  6. Select Add profile
  7. For the Title enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  8. Set Use proxy to AT&T:
    • On
    T-Mobile:
    • Off
    • Alternative: On
      Note the proxy only needs to be on if using the Alternate settings
    ">#Proxy
  9. For the Proxy server address enter The Server address to use for the connection.
    Some devices require the address in the format of 000.000.000.000. (ex: 011.012.013.014)
    ">#MMSProxy
    if the Proxy is on
  10. For the Proxy server port enter The Port number used by the connection.
    ">#MMSPort
    if the Proxy is on
  11. Set the Access point to the profile created above
  12. Select Save
To Setup the Browser Profile
  3. Select the Utilities tab
  4. Select Browser
  5. Select Settings
  6. Select Profiles
  7. Select Add profile
  8. For the Title enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  9. For the Homepage enter Can be set to anything if an Internet Plan is on the account such as www.google.com
    ">#Homepage
  10. Set the Internet Profile to the profile created above
  11. Select Save
  12. Select Yes to Activate
  13. The internet should now be configured
Jan 25, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
How to activate my mms? globe prepaid
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service.
or
This tutorial will help you setup your mobile phone and activate/configure GPRS, 3G and MMS features for Globe Telecoms.
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
4. Save Account
5. Go to Internet Settings
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
12. Save Changes
3. Create New Account. GPRS / PS Data
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
Jun 26, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How to open Globe gprs to Nokia 6303
GPRS SETTINGS
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
11. Change Homepage
Title: MyGlobe
12. Save Changes
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
4. Save Account
Connect Using: MyGlobe Stream
Jun 26, 2010 | Nokia 6303 Cell Phone
Please Check Browser Settings
U need to first check all the settings to browse internet...... 1) Create ACESS POINT(Settings>Connectivity>Access Points). 2)Create INTERNET PROFILE, with accesspoint as created above(Settings>Connectivity>Internet Profiles). 3)Setting Up PROFILES in Browser, with Intrenet profile created in step 2(Utilities>Browser>Settings>Profiles)
May 22, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How, where can i get the i.p adress of my china phone n5310,
hi dave, you can try visitiing smart centers, they can surely help you with that.
Feb 15, 2009 | Nokia Cell Phones
Getting "GPRS NOT SUBSCRIBED" message
Data Account Setup:
From the Main Menu select > Services > Data Account > GPRS
Scroll to an empty account (IE: Account icon_cool.gif and select Edit
Set Account Name to T-Mobile Internet
Set APN to internet2.voicestream.com
Leave Username and Password blank
Press Done
Select Yes to Save
WAP Profile Setup:
From the Main Menu select > Services > WAP > Settings
Select Edit Profile
Scroll to an empty profile (IE: Profile icon_cool.gif and select Edit Profile
Set Profile Name to T-Mobile Internet
Set Homepage to http://www.t-mobile.com
Select Data Account > GPRS > T-Mobile Internet
Set Connection Type to HTTP
Leave Proxy blank
Leave Port blank
Press Done
When Prompted to Save select Yes
Scroll to T-Mobile Internet and select Activate Profile
To Access the Browser:
Select Homepage to bring up the homepage
Select Enter Address to browse other pages
To setup Picture Message (MMS)
Create Data Account
Select Menu
Select Services
Select Data Account
Select GPRS
Choose an empty profile
Account Name enter T-Mobile WAP
Press Options
Press Done
APN enter wap.voicestream.com
Press Options
Press Done
User Name
Password
Auth. Type choose Normal
Press Done
Press Save
Create Profile
Select Menu
Select PIM
Select Messages
Select MMS
Select Message Setting
Select Server Profile
Select a Profile
Select Edit Profile
Select a profile
Choose Edit Profile
Rename Profile enter T-Mobile MMS
Homepage enter http://216.155.174.84/servlets/mms
Press Options
Press Done
Data Account select GPRS
Select T-Mobile WAP
Connection Type select HTTP
Proxy Address enter 216.155.165.050
Port enter 8080
User Name
Password
Press Done
Activate the profile
Jan 25, 2009 | Dual Electronics CECT P168 Cellular Phone
Need to use the motorolla phone to send and recieve pictures
setting up an internet conection and multimedia connection on unlocked gsmphone
Model No: Motorolla Krzr Z6 a German Market Model
1st of all make sure u have the internet connection:
creating an internet connection
menu>connection>Data connection>add a connection>
Profile Name: Atnt
Proxy 1: 66.209.11.32
port1: 80
domain 1:
gprs apn: WAP.CINGULAR
user name: WAP@cingular.com
password: cingular1
GPRS Timeout:15 min
click on additonal settings
Proxy 2:
Port 2: 9201
csd number: 14152441012
unername: WAP@CINGULARGPRS.COM
password: cingular1
speed: 9600
line type: ISDN
CSD Time out: 15 min
main menu>messages>options>settings>multimedia Messages>Service Profile
there creaate a profile
Profile name: Cingular
Service Center: http://mmsc.cingular.com
internet connection: : atnt
Then go the the browser setup
browser setup:
Menu>office tools>web access>browser setup>broser profile>add a new profile
profile name: cingular GPRS
home page: http://device.home
data connection: Atnt
cookie poxy Policy: let gateway decide
restart the phone
goldenguras@gmail.com
Feb 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Palm Pixi Cell Phone Logo
110 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
