Question about Palm Tungsten T5 - Multilingual Handheld
When I use my Palmone T5 calendar it will not save and I get a fatal error and have to reset again. I can not beam into the clendar without fatal error message. What can I do to get this to work properly?
  • Palm Expert
  • 346 Answers
You might want to try a a hard reset. This will erase everything on your hand held so you might want to try the free palm chat that palm offers. Here is a link to that. Just scroll to the bottom of the page and you will see Palm Chat. Click on the link that says Chat Now and follow the directions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t/unlocked/supportservices/page_en.html
Posted on Nov 19, 2009
My T5 will not synch my calendar in Outlook
Welcome to Fixya
Double check the Palm or palmOne program in Windows. Click Start then All Programs then Palm or palmOne. You should see an icon in there called Sync with Outlook or something similar. Click that icon and the Outlook conduits will replace those for Palm Desktop. Some conduits, like Media/Photos will continue to sync with Palm Desktop, but Calendar, Contacts, Tasks, and Memos will sync to Outlook.
Thank you for using Fixya!
Aug 10, 2011 | Palm Tungsten T5 Handheld
Fatal Alert Datamgr.c,Line7564 InvalidUniqueIDPassed I get this when I synchronize.
Perhaps you haven't tried performing a more severe reset to break the freeze. You might want to try doing a hard reset. This will erase all data from your hand held so make sure you have everything backed up on your computer so you can sync it again after the hard reset. Note, when I occasionally receive a Fatal Alert error, the Reset on-screen button almost never responds to a tap...I invariably have to depress the reset button in the back of my E2. http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(26419) resets:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887) Depending on a variety of factors including the available memory on your E2 and other installed applications, the problem might or night not be caused directly by the program you were trying out. But once you get the E2 unfrozen, you should refer to this article to troubleshoot the cause of this apparent software conflict:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908) Also, I recommend going to the developer of the software you are using, to determine whether there are any compatibility issues at their end, and whether they have an upgrade available.
Here are the directions for the hard reset.
1. Press and hold down the power button.
2. While holding down the power button, use the tip of your stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear and then release the power button.
4. When you see the message that warns you about erasing all your data please continue and then follow the on screen directions.
If this doesn't help then I recommend going to www.palm.com. From there you will need to select PDA's and then the model of yours. It will go to another screen and you should be able to contact palm via free chat. I have had to do this several times and both times I got fast service. Hope this helps.
Aug 24, 2009 | Palm Tungsten E2 Handheld
T3 sync with PC- Windows XP
Need to reload software in pc. Dropping stuff. If you found this helpful, please post as so. If you need to knwo how, live chat
Sep 14, 2008 | Palm Tungsten T3 Handheld
Interrupted update - jammed
An interrupted update will corrupt your ROM. I sincerely hope you'll get a better 2nd opinion, and from your post it seems like if theres a solution out there then you're not likely to miss it ;] Good luck, and let us know if you worked it out
Apr 17, 2006 | Palm Tungsten T5 Handheld
Treo 650 Hotsync Problem
Many factors can influence the synchronization process. you will have to go step by step from this: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(25004) Good luck.
Jan 04, 2006 | Palm Treo 650 Handheld
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Prob with hot sync
You have to do a clean sweep of office.
Sep 12, 2005 | Palm Treo 650 Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
650 stopped syncing after I set up the email function
Reinstall software. If this is helpful, please post as such. TY
T5 Outlook Calendar Synchronization failed - Any one have a fix?
I went to the MY COMPUTER folder, clicked open PROGRAM FILES, open PALMONE folder, open the username folder and deleted the back-up files. However, before I did this I deleted all of the problems dates in the PC calendar and set the hotsync to PC overrides handheld. While this works, unfortunately I have found that I need to do it every once in a while which is very disappointing. It seems that Windows does not operate seamlessly with the Palm T5. I find that the hotsync crashes 50% of the time forcing me to reset my Palm T5. No information is lost, but it is really a pain in the *** to have to do so often. Versamail hotsync sometimes freezes on the handheld, but that is another issue which I have managed to fix much in the same way as describe above.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Palm Tungsten T5 - Multilingual Handheld Logo
189 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
