Question about NetGear WGR614 Wireless Router
How do i find my network key as i want to add my laptop to the network Main computer is running vist and laptop has XP
  • 4,281 Answers
Connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.Click on wireless and If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Posted on Nov 17, 2009
    Brigadier General:
  • 10,406 Answers
On your VISTA computer, connect to the router's internal web-interface,
and run the "Wireless Setup Wizard", to set a new network-key and to choose a SSID key.
Use those values on your laptop.
Where is the network security key
The network security key is set by the user when the home network is setup. It prevents people from stealing your wireless signal. If you have forgot it, or didn't set it up but it still is asking for one, you can unplug and hit the reset button on your router and delete the home network you have on your main computer. From there, just run the network setup wizard from the main pc and set your network security key to something you can remember as well as write it down. Then you should be set to add any other pc to your home network as long as when you try to connect, you put the correct key in.
Sep 28, 2012 | Belkin (F5D7231-4) Wireless Router
Tip
Wireless Network issues. Validating identity and Certificate Errors in Windows...
At times after you have entered the correct password for the wireless network on your computer you are unable to connect to the wireless network and see the below mentioned errors:<br /><br /> <ul> <li>"Windows was unable to find a certificate to log you on to the network." </li> <li>"Validating identity" replacing the name of the wireless network. </li> <li>A pop-up window requesting for login credentials off the wireless connection. </li></ul><br />To avoid these error messages, you need to manually create or add a wireless network profile. Follow these steps to manually add a wireless network on Windows XP and Vista computers. <br /><br /><span>Manually add a wireless network on a Windows Vista computer:</span><br /><br /> <ol> <li>Click Start, and then select Network. </li> <li>Select Network and Sharing Center.</li> <li>Click Manage wireless networks.</li> <li>Click Add and select Manually create a network profile.</li> <li>Type the SSID, select the type of security and type the wireless password in the Security Key/Passphrase field. </li> <li>Select the Start this connection Automatically and Connect even if the network is not broadcasting check boxes. </li> <li>Click Next and close the window.</li> <li>Go to the Network and Sharing Center and select Manage network connections.</li> <li>Right click on Wireless network connection and then select Status. </li> <li>Click details and check the IPv4 address. </li> <li>If there is a valid IPv4 address, check if the computer can access the Internet wireless.</li></ol><br /><span>Manually add a wireless network on a Windows XP computer </span><br /><br />Note: The following steps are for a wireless network that has WEP security.<br /><br /> <ol> <li>Click Start, then select Control Panel.</li> <li>In the left pane, select Switch to Classic view.</li> <li>Click Network Connections.</li> <li>Right click Wireless Network Connections and select Properties.</li> <li>Click on the Wireless Networks tab.</li> <li>Click the Add button.</li> <li>Enter the name of the wireless network (SSID). </li> <li>Set the encryption type to WEP.</li> <li>Clear the key is provided for me automatically check box.</li> <li>Enter the network key and confirm it. Note: Make sure that "This is a computer-to-computer (ad-hoc) network" is not selected. Click OK, and then click OK again.<br /></li> <li>Right-click Wireless Network Connections and select Status. </li> <li>Click on the Support tab and check if there is a valid IP address.</li> <li>Check if the computer can access the Internet wirelessly.</li></ol> <br /><br />If you still receive the same error message after manually adding a wireless network on a Windows XP computer, ensure that IEEE 802.1x authentication of the wireless adapter is disabled.<br /><br /><span>To disable IEEE 802.1x authentication: </span><br /><br /> <ol> <li>Click Start, then select Run.</li> <li>In the Run dialog box type ncpa.cpl and then click OK.</li> <li>Right-click the Wireless network connections icon, and then select Properties. </li> <li>Click the Wireless network tab.</li> <li>Click the Properties button beside Remove. </li> <li>Click the Authentication tab, and clear the Enable IEEE 802.1x authentication for this network check box.</li> <li>Click OK to update the settings.</li></ol>This TIP applies to: <br /><br /><span>All Windows XP and Vista computers that display the listed error messages when attempting to connect to wireless network of routers (specifically NETGEAR).</span>
on Apr 28, 2011 | Computers & Internet
Networking issues
Sounds like your printer isn't configured for "sharing." Go to Control panel > Network and Sharing Center > Choose homegroup and sharing options. Make sure Printer has a check mark.
If you have any other computers, check them to see if you can print from them.
Jan 14, 2012 | HP Photosmart C4180 All-In-One InkJet...
How do i get wep key or wpa key from my main computer
If your main computer is running Windows Vista/7, you can go to Control Panel\Network and Internet\Manage Wireless Networks, right-click on your network, and select properties. Once there, select the Security tab, and your key will be there (you may have to check the show characters button). The key may already be encrypted, but you can still input it into a device to connect to the network. If you're running XP, go to Control Panel\Network Connections, and follow the same process. You can also go onto your router's configuration page and find the key (using a computer that is already connected to it).
Sep 20, 2010 | Computers & Internet
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
Problem connecting to WNR2000 on laptop running vista
Perform the task below on the wireless VISTA computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 26, 2009 | NetGear WNR2000 Wireless Router
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Instaling network printer from main computer
On the Vista computer, right click on printer, go to sharing tab, click on Additional Drivers button. On the next screen you need to select Windows XP.
This will ensure that whenever a print request is queued from any computer that runs on Windows XP, it will process the request on the Vista machine.
You should also try to ping the printer. You should also check if the computer is able to share files with Vista machine.
Apr 02, 2009 | Microsoft Windows XP Professional SP2 for...
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
Home network w/ XP pro desktop and Vist Home pro laptop
So you want to remotely control your Desktop from your laptop from anywhere, correct?
Well only thing you need  is an internet connection, and you can access your desktop.
There are tons of software you can use to control your desktop remotely.
Here are some good ones:
Logmein free click that, that will link you to LogMein's free solution.
Logmein offers several solutions, the free is what I would use for you unless you wanted to pay.
Another very good one is:
RemotelyAnywhere click there, that is a very good software probably my favorite.
Those are the main 2 that you would like.
There are other ones more for more advanced users like:
http://www.uvnc.com/
-Cam
Oct 21, 2007 | Computers & Internet
NetGear WGR614 Wireless Router Logo
234 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
