Question about Refrigerators
I have a Frigidaire frost proof FPE-24VWA refrigerator, that the freezer frost up and get extremly cold, the refrigerator gets warm. I replaced the defrost timer, and it has not changed anything. I did have to change the wiring on the timer to match the one I took out.
    Problem Solver:
  • 23 Answers
Replace Defrost thermostat which is fixed with evaporator coil.Sure your problem will be solved.
Posted on Nov 17, 2009
Code H1 on my frigidaire ffhs2622mwla refrigerator
HI is an error for freezer temperature detected as too warm... Look for frost on the back wall of freezer (defrost failure), or a failed evaporator fan (you should hear it running in the freezer compartment), if the food in the freezer is beginning to thaw, check the compressor to see if it is running. If the compressor is running, but the freezer isn't cold enough, and the evap fan is good with no frost build-up, you may have a sealed system leak (refrigerant charge is low). Frigidaires really suck in recent years and have lots of leak issues...
Jun 20, 2016 | Frigidaire Refrigerators
Frigidaire problems
Use the link below to view and read the user manual. If this is a used refrigerator it is possible that there may be a problem but it should be minor. The refrigerator section is cooled by air from the freezer. This problem is usually caused be excessive frost but you should not have frost buildup in only 24 hours.
There is also parts lists and diagrams.on the site.
I am also including a link to youtube videos about refrigerator problems.
FGHT1832PF0 FRIGIDAIRE REFRIGERATOR Manual
Frigidaire FGHT1832PF freezer cold refrigerator warm YouTube
Sep 04, 2014 | Frigidaire FGHT1832PF Gallery Series...
Refrigerator section is warming and does not resond to raising temp freezer section at first produce extremely cold food, now has great amount of frost
Hello Diana,
That sound like one the defrost system components has failed allowing the frost build up in the freezer which is restricting cold air flow into the refrif.compartment....this tip i wrote will help ya what to check on the defrost system parts http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Sep 08, 2011 | Amana Refrigerators
Fridge warm, freezer frosted over and cold
Freezer fan motor is probably not working properly. Cold air is not being transferred from the freezer to the refrigerator.
Oct 09, 2009 | Frigidaire FRT18HS6J Top Freezer...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
My frigidaire refrigerator is not cooling anymore. The light is on. The motor is running. What is wrong?
if one of the panels in the freezer has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | Frigidaire Refrigerators
The frig part and the freezer part are not getting cold. They get cold every two days, then gets warm for two days and then it re-peats the cycle.
Hi, check to see if both the fans are running or check and see if there is frost builing up inside the freezer. Are the condesor coils clean? These coils are located under the refrigerator near the compressor.
Please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Frigidaire FRT18G4A Top Freezer...
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
281 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
