Question about Sony BRAVIA KDL-46V3000 Television
Is it safe to turn the volume up all the way without risking damage to the speakers for prolonged periods of time?
    President:
  • 1,284 Answers
Yes, the volume can be ran at 100% but not suggested. The problem is the sound is very distorted when you push the internal speakers at their limit. The other thing is at full volume the set is more likely to rattle. I hope that clears things up a bit... Please take a few moments to rate my answer... Thank you. :)
Posted on Nov 17, 2009
  • 15,935 Answers
No - the resistance in the tiny voicecoil will heat up rapidly, and blow.
3/4 gain is the approximate "safe zone" for any speaker at "full volume"
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Polaroid fxm-3211c has picture but no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 30, 2015 | Polaroid FXM-3211C 32 in. LCD TV
Tip
WARNING: Do not allow PW to run "dry"
It is recommended that once pressure washer is in operation and water flow thru wand is there ,that you do not allow off period between burst of no more that 2 minutes or you highly risk damage to your pump,not engine, due to overheating. See if Dump valve is adjustable,cheaper models not adjustable. This valve senses pressure/heat build up in pump when trigger is released, and is a secondery backup to release such heat/pressure to avoid pump failure. If you have repeatly left trigger off for more than 2 minutes in for prolonged periods of time,this is not good.
Thanks and Please Rate a Fix Ya
John jj505
on Apr 15, 2009 | Honda 8 HP Engine
Yamaha ysp 900 will not turn on,occasionly will come on if power socket is switched on and off rapidly,it will then just stop working randomly..
There are several reasons that can cause the power transformer to fail. The most common reason in Yamaha's experiences is overheating. When a transformer gets too hot, a heat sensitive device called a "thermal fuse" opens up. This renders the transformer useless and it must be replaced. All Yamaha products sold by our authorized dealers carry an Underwriters Laboratory or CSA Certification. This UL listing assures you that the product is completely safe to use when operated in accordance with your owner's manual. And should there ever be a failure within your unit, it will not shock you or catch fire or present any hazards to life or property. The thermal link in your transformer is a requirement to obtain the UL or CSA listing. This thermal link opens up instead of having your transformer catch fire or cause potential electrical hazards. Your amplifier should not have anything placed on the top of it, covering the vents. These vents need to be left open as that is how the unit cools itself. If your amplifier is in an enclosed cabinet, air movement could be severely restricted. Consider a small cooling fan for increased air circulation. Never remove the feet from the bottom of your unit, as there are ventilation holes on the bottom of your unit as well. Another reason for power transformer failure is a continuous heavy current draw through the unit over a prolonged period of time causing excessive heat buildup within your unit. This could be related to the impedance of the speakers you are using, the level of the volume control, and how many speakers you are using at one time. You can only use 1 pair of 4-ohm speakers, or 1 pair of 6-ohm speakers, or 2 pair of 8-ohm speakers. Any other combination or types of speakers that you are using other than what was just mentioned could lead to premature failure of your amplifier or power transformer. In addition, do not turn your volume control further than the halfway point. If you are doing this, you run the risk of damaging your amplifier or speaker system. (See Why Do I Keep Blowing tweeters/Midranges, And How Do I Prevent This From Reoccurring?). If the level of sound is not high enough for you when the volume control is at the halfway mark, then we recommend that you obtain a larger power amplifier. If you are going to evaluate the purchase of a larger power amplifier, you should choose one that has about double the power of the amp you are currently using. And be sure that your speaker system is capable of handling the power of the amplifier you are considering.
Jan 26, 2011 | Yamaha YSP-900
Hook up extra speakers
Most of these portable PA systems do NOT have amplifiers capable of driving extra speakers SAFELY without risk to the amp.
I would NOT attempt to drive more speakers without using another amp to drive those speakers.
Sep 19, 2010 | Peavey 00511800 Escort Portable Sound...
Unit would shut down just a few seconds after startup. Checked all 5 speakers and all had good impedance. Main speaker left channel must be blown 'cause all it does is hiss. How to fix?
Your unit is likely shutting down because you have a short on one or more speaker outputs. This is a safe mode on short circuit to protect the unit.
The hiss is an indicator of the short (it has been shorted so long that one transistor set is probably bad. Look for a single strand of wire crossing from red to black speaker output on the receiver or at the speaker input on the speaker. If not there - you may have touched speaker wires together at one time - especially when volume was turned up.
Most likely you have blown the power transistor to that channel (left). You will have to open up the unit and look for the large transistors mounted to a heat sink (large aluminum frame). There should be two transistors for each channel (12 total for six channels) in an AB (push/pull) configuration.
You will have to measure the output (AC voltage) of each pair - right wire is usually the emitter. You can hold the neg (black) lead on the volt meter to the black speaker terminal when checking each. If you are lucky - there will be white lettering to indicate which speaker each pair of transistors is for.
Simply desolder the bad ones and replace with identical type (www.digikey.com or www.alliedelec.com should have most transistors you will need - radio shack will not have the correct transistors). If you get no AC or only low AC or AC output voltage does not track with volume knob turn, then you have a bad set of transistors on that channel. Compare to other channels.
Be EXTREMELY careful when you open the unit. Static electricity can damage components. Touching something near the AC main (wall power) kinput, the filter network for AC main power, transformer, rectifier will damage you. If you are uncomfortable, you can take your time and learn how to do this (Books, videos, learn from a friend). Do not do this without knowing about electricity and where the hot spots are in your unit. You will be much better off spending $300 - $500 on a new unit rather than risking your life/health to fix this unit.
Good luck and drop a note on this site to let me know what you do.
Mar 31, 2010 | Yamaha RX-V440 Receiver
When i turn the volume up past a certain point the music stops playing and all i hear is a scratchy noise every couple seconds
This is usually due to the headphones or speakers not being able to play back the audio past that point, try a different set of headphones, the earbuds might be burnt out. some earbuds **** and cant play sounds past a certain dB the general dB levels tolerated without distortion are about 104-110 ish, but if you are listening anywhere near that your gonna hurt your ears. tests have shown that audio levels past about 90dB will seriously damage your ears after prolonged usage. Generally get nice in-ear ear buds with noise cancelation and never move your audio past 90% to clearly hear the music without damaging your ears.
I got my girlfriend some Jbuds J2 and they are great and i prefer them over my 200$ bose ear buds. check amazon they are about 14$ the J3's are around 24$
Nov 04, 2009 | SanDisk Audio Players & Recorders
Denon AVR-1604 too large front speakers blew the avr
Try disconnecting the speakers at the receiver. turn it on radio or any other source and turn up the volume. If the receiver still shuts of, there is an internal capacitor issue and needs serviced. More than likely though, it's a speaker problem. If the speakers were underpowered and at max volume, chances are the damage was to a voice coil in one of the speakers. If the receiver continues to stay on without being connected it's ok. check your speaker wires as well. Frequently loose braids on wires touch each other and create very little resistance until turned up, more volume, more resistance. Then the receiver puts itself into protection mode so no damage will occur. If you need further help, post a comment and I can help you troubleshoot further.
Aug 17, 2009 | Denon AVR-1604 Receiver
Receiver shuts off when volume raised above 10
A fuse breaker or resetting electronic componet device attaced to the audio receiver protects the amp & speakers for destruction! The quality of the amp ,spkers& spks. wires help on choosing for protection shut downs! Of course at 10 volume you risk all of the amp in the receiver , buy a higher quality brand reciever ,intergrated amp, single amp . BE CAREFUL AT THE HIGHER VOLUME RATINGS YOU RISK HEARING DAMAGE! FOR REAL!
Feb 04, 2009 | Philips FR975 Receiver
MX5020 Noisy
Try to blow it out with compressed air. Then, with the speakers turned off, turn the volume knob to full volume and back as quickly as you can (without damaging the switch) three or four times. This should take about one second for three movements. Undertake this at your own risk. Turn them on and see if it has helped. Do not just keep doing this. if it doesn't help immediately stop. if it does help, repeat blowing out and repeat the knob turning, once.
Jan 22, 2007 | Altec Lansing MX5020 Computer Speakers
Sony BRAVIA  KDL-46V3000 Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
