Question about Epson Office Equipment & Supplies
Dirty Waste Ink Pads (Epson Stylus R285)
How do I remove and clean the waste ink pads in my printer?
  • Epson Master
  • 419 Answers
There is no easy way to remove and replace the waste pads on this model (or any built around the same time) as the waste pads were never placed or designed to be user-replaceable.
It's much easier to simply install an external waste ink kit which is easy enough to do...
More than a few resources exist that cover this including this:
http://www.octoink.co.uk/_video/p50/
Resolving the physical waste ink issue is only part of the equation though so you do still need to consider how to reset the waste ink counter as this is required to clear the "Service required" error displayed when the pads are deemed to be "full".
Posted on Nov 30, 2012
    Problem Solver:
  • 7 Answers
Remove to top cover and replace the ink pad with a new one. You can get these pads from a place called pudsey computers www.pudseycomputers.co.uk
Posted on Mar 15, 2010
Epson stylus TX121 printer's ink pads are at the end of their service life
My printer name
Epson tx121
it's show "The printer's ink pads are nearing the end of their service life. Please contact Epson support".
May 14, 2012 | Epson Stylus TX120 Inkjet Multifunction...
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Parts inside your printer are near the end of their service life.
Most likely the waste ink counter has reached its programmed limit. You can replace or clean the waste ink pads. You need to disassemble the printer from the top; the waste ink pads absorb the ink during cleaning cycles and when you do edge-to-edge printing. Have plenty of newspaper or other material to keep the excess ink from spreading. Remove the pads, blot off most of the ink and then hold them under running water until it stays clear. Blot the excess ink from the area where the pads rest as well. Dry the pads (you can use a hair dryer to speed up the process). Then reassemble the printer. If you want to replace the pads, contact Epson Service.
Fill out the form here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes and get the Ink Pad Reset utility. You will need to provide your printer's serial number. Run the reset program (Windows computer).
Please note that the programmed timing on the waste ink is based on the expected life of the printer. You may have additional failures with the printer in the near future.
I hope this helps.
Sep 29, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
Iwant to clean out or change waste ink pad on epson r265 printer. have just used cotten buds to soak up waste ink to fix flashing lights. but i think only a temp. solution
Photo walk through here shows how to access waste pads
http://www.inkrepublic.com/KnowledgeBase/R260WasteInk.asp?C=0
Also shows how to replace with a bottle to collect waste ink
Feb 08, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson stylus 830Uink pads full not printing help
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
EPSON STYLUS C43SX PRINTER
You need to reset the waste tank or the counter to resolve the problem.
If your C42 blinks both lights and displays a message to the effect that parts inside your printer have reached the end of their servicable life, then you probably need to clean the waste ink pads. These pads collect waste ink whenever the printer cleans it's heads. The printer counts how much ink it thinks is in the waste ink pads and refuses to print when they are full.
To verify whether this is the case, download the "SSC Service Utility" from http://www.ssclg.com/epsone.shtml.
http://www.ianwillis.co.uk/c42/
Mar 26, 2008 | Epson Stylus C43SX InkJet Printer
EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Mar 25, 2008 | Epson Stylus 2200 InkJet Photo Printer
Changing waste pads
try this rescue kit that includes everything you need to do the job, including how to clean the old pads instead of buying new ones.
http://www.tradebit.com/filedetail.php/2379162-Documents-eBooks-Technical
Jan 08, 2008 | Epson Stylus CX6600 All-In-One InkJet...
1,030 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
