Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W25 pierre
Once in a while the tv has a poping sound and the picture flashes, today it was doing it more, i removed some covers and vacummedas i do every 6 months, i noticed on one tube or what ever it might be, located at the front and lower section of the tv a light flashing, no clue of what it might be,
any help it would be appreciated, also is it worth to fix.
  • pierre121 Jan 11, 2008
    i will ck connections, the one that blinks is on the left the green one, is this something i can do or is it better to have somelse to do it?
    Thanks
    I was searching around last nite and found out what it would take to replace the crt, well i learned alot and leathal voltage is something i will not mess with i did find a crt for 190 not to bad so i would suspect labor is around 200, that is if that is the issue, I want to thank you for your help.
    Pierre
    Genius:
  • 1,030 Answers
Possible arching crt. which one red blue or green. HIgh voltage problem could be simple connection ... could be tube.. replacement of crts in these units are generally expensive to say.around 400 for parts and labor
Posted on Jan 10, 2008
  • Willie Howell Jan 11, 2008
    i personally would not recomend fooling with crt. voltages are leathal also crt tend to be tricky with alignment> unless your a tech please get someone to check it for you
D52W25 RCA Problems
What is the problem you faces with this TV? Provide more details please. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 15, 2013 | RCA 264102 Refurbished Power Board Circuit...
Rca hd d52w25 tv was working fine turned it off when turned on now no picture or sound and power button flashes green
The most common cause of that symptom in that model are the CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with repair instructions.
Nov 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W25 power issues.
Install the repair kit called the CP150, CP120 and CP114 repair kit available from www.tvrepairworld.com the kit contains instructions on CD also.
May 24, 2010 | Televison & Video
The power button light blinks a few times but no power afterwards. RCA D52W25 is dead. I lightly shook the TV last night and it worked until this morning.
These units are famous for loose solder connections at the high voltage transformer and for bad capacitors in the power supply. Have a repair shop check it out for you. You have to remove the Deflection PCB to do these repairs. Thanks
Oct 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound won't work on RCA D52W25 TV
first things to check in settings check to see if the settings to make sure the set is set to internal amplifer. not external. there two other things this can be the speakers if blown or the audio amp is blown if the amp is blown the the main board will need replaced. Tech have special equipment needed to replace this and at my shop it would run about 250
Apr 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV MODEL D52W25
Take the back off the TV look where the wire from the power plug enters the TV. There is a small fuse on the board where the wire plugs into. If that fuse is blown, you have a power supply problem.
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W25
Thats possibly the flyback causing that. If you need more help with the problem or how to change the flyback, let me know
May 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Rear projection Tv D52W25
the would be you high voltage flyback do not run the set while this is happening as it could do more damage.
you should replace that part.
Jan 09, 2008 | RCA P52926 52" Rear Projection Television
Rca projection tv sound problem
You could try to get the set fixed but I would say the set is just worn out.
Time to buy a new TV I think (going by the picture above anyway)
Dec 28, 2007 | RCA G27647 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
141 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
