Question about Dell Latitude D610 Notebook
Need to add a dell laptop to a wirelees router how do i get the network key to allowed access
  • 4,281 Answers
Connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.Click on wireless and If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Posted on Nov 17, 2009
Linksys WAG54G-UK Router Blocker
Hello I have a question wirelees have a network connection at a hotspot romtelecom a router without antenna which is called LINKSYS NETWORK IS FREE WIRELEES How can I find the IP address of your router linksys As I have access to it Thanks
Jan 14, 2013 | Linksys WAG54G-UK Router
A dell inspiron 6400 with windows vista will not allow the d-link to connect. It asks for a security code
Welcome to Fixya.
If you need you Security Key (Network Key) on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.0.1, the Default username is admin and the password is blank. Go to the Wireless Settings and under Security Mode you'll find the Network Key or Passphrase. You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Don't Forget to say Thanks. Thanks for using Fixya.
Mar 14, 2011 | D-Link Computers & Internet
Looking to hook up wirelees router
You should have one plug that is marked WAN - this connects to your modem with a standard Ethernet cable. If you cannot read the labels, it will be the plug, slightly removed from the other four plugs.
You need to connect the power adapter to a power strip to avoid unnecessary power entering your network and to protect the router.
You should be able to start the router without a PC attached. Just look for Dynex being broadcast wirelessly. Your network is not secure wirelessly until you add a password to the network.
See if you can get to fixya.com from your laptop. If so, things are going pretty well. You now want to add security to the wireless network.
Write back if you need help.
May 24, 2010 | Dynex 4-Port Ethernet Broadband Router...
Laptop can't connect to DSL-G604T
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
Mar 05, 2010 | D-Link DSL-G604T Wireless Router
Cannot get wireless connection to my laptop it works with the ethernet cable plugged in
You need to make sure you have the same settings on your wireless access point that you use on your laptop.
Make sure you spell your SSID (wireless network name) correctly. It is case sensitive.
Turn off security on your access point just to see if it works.
Configure your network card for Open access and turn off all other security settings.
Once you get it working turn on WEP encryption on your access point and create a wep key. Enter the same key on your Laptop.
Don't turn on stuff that you don't need or don't understand.
You just need to make it as simple as possible and then turn on adequate security.
OR
If the WEP stuff just gets too hard you can use MAC security.
That is where you say only known computers can access the wireless network. On your wireless access point configuration add the mac address of every devices network card that will connect. Sometimes these settings can be a little hard to find on the access point.
Hope this helps.
Start simple and then make it complex :)
Sep 22, 2009 | Dell TrueMobile 2300 Router (000001)
I have a Apple Router I know the Internet ID #, I know the Airport ID #, I have the Serial # but I cannot connect to my computer to go wirelee online. When I try to connect it requires a Password / Key...
Using your wired computer, you need to access the router's setup page by going to your internet browser and type http://10.0.1.1 and press enter, you can see the wireless network key under the wireless tab or wireless security tab
Apr 19, 2009 | Apple AirPort Extreme Router
Need to get password for wireless network to add to new laptop
Access the configuration page of the router (192.168.1.1) then for the network key you'll needing to open the wireless settings, you can set a network key or you will get the key that you wanted for the network.
Mar 25, 2009 | NetGear WGT624 Wireless Router
Discovering wep key to add a new laptop to network
try logging in to your router e.i. 192.168.2.1. You'll need probably a password or try blank to get to security settings.
Feb 28, 2009 | Dell Computers & Internet
Internet access with wireless
Assuming that your laptop has a built-in WiFi Networking card (or even a USB or PCMCIA WiFi adapter), normally its a matter of setting your Network configuration to "Auto obtain IP address automatically". This could be done in your Control Panel/Networking Connections, right click on your wireless Networking, click on Properties, highlight Internet protocol (TCP/IP), click on the Properties button and tick "Obtain...".
In some instances you might need to key in the WEP or WPA security key if it has been enabled and set in your WiFi router, though it has been known to slow down connections. If on the otherhand the router has its MAC filter enabled, then you would need to add your laptop's WiFi MAC numbers to the list that the router would allow access to.
Should the above be not corrective of your concern, pls post back with the make & model of your router, laptop, and the WiFi adapter if external/add-on. Knowing your Operating System would also help.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 09, 2008 | Computers & Internet
Dell Latitude D610 Notebook Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
