Question about Poulan Garden
My poulan 1800 is pouring gas from the exoust, what can I do?
    President:
  • 2,220 Answers
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Posted on Nov 17, 2009
Poulan pro pbv200le 711848 it is not getting gas ,, i have check daighram in carb , i have clean carb, i have blownn out ever hole and hose, i have checked fuel cap, still no start,, when you pour a...
Have you been able to make adjustments to the carb's high and low settings? If not, there is a good chance it has the limiter caps that require a special tool for the adjustments. It will have to be taken to a dealer to get that done.
Aug 30, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Do you add the oil first or the gas first?
If you're talking about mixing two-cycle oil with gas for a two stroke motor, always mix it in a gas can then pour it in the weed eater. It's easier to put the oil in the gas can first then fill it with gas to get the two mixed well.
Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan 2150, chain oiler not working. Chain is getting very hot.
Try to pour some gasoline only in the oiled tank and look if the gas comes out, if not the tank is clogged .
Oct 12, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
Forgot to put oil in the gas for my trimmer and blower. will not start now. can this be fixed? how?
pour out all the gas and make up new batch you may have to replace the plug but otherwise your still in good shape
Sep 12, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan push mower won't start
Remove the spark plug and pour a teaspoon of gas into the spark plug hole then replace the spark plug and it will start.
Aug 06, 2009 | Poulan "Poulan" Push Mower
Briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
115 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
