Question about AT&T Motorola RAZR2 V9 Cell Phone - Purple
I dont have the disc RAZR2 V9x where can i get it
I bought this online from China. I put my sim car in and can make calls but it is charging international calls. Took it to AT&T and she says it's locked and cannot change this. What do I need to do.
Hi Lydia
It sounds like your phone is dialing internationally for all calls since your phone is intended for a region other than that which you are using it in.
To use it with AT&T you will need the subsidy unlock code from the service provider the phone was originally intended for.
Then you'd have to go through the settings to turn off international dialing so it treats dialing as local dialing. I would probably also call your service provider to block international dialing if you are not wanting any unless you specifically enable it before a trip.
Regards
Maya
Motorola Support Team
May 27, 2015 | Motorola Mobility RazR 2 RazR2 V9 V9X 3G...
Unlock at&t motorola razr v9x
Hi, You can unlock a Motorola Razr V9X safer and easier using unlock code. You can get the unlock code for a Motorola Razr V9X from www.wickedunlock.com/motorola-razr2-v9x/rs11wp9/ at affordable cost.
Sep 28, 2012 | Motorola Mobility RAZR2 v9 Cell Phone
The front screen will not turn off after charging and some calls. I have to turn it off and on to reset it Motorola razr2 v9x
hello,if it's for some while that is how it is designed,but if it remains permanent,definitely that is how you made the light display setting to look,so all you need to do is just to adjust the display setting,but if the setting is kind of in order then it is most definitely a flex problem that will require you change the flex for it to work as normal as you wish.
please kindly rate the solution if it's helpful,
take care.
May 26, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
How do you save a picture that was sent to you on a RAZR2 V9X.
go to that specific picture msg and hit option. once the option menu appears , click save. it will say save file, click yes
Aug 22, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
I have a Motorola razr2 v9x i can not get any of the keys to work
Yeah, I got the exact problem too with my V9 and I eventually found out that it was about the small button located the right side of it (one of the smart button) it stucked inside and it keept all the other buttons away from working then I opened it and got it done.
Aug 20, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Free unlocking codes for motorola v9x
call your carrier and tell them your leaving the country and need the unlock they will give it to you
Jan 20, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Open Questions:
See all AT&T Motorola RAZR2 V9 Cell Phone - Purple Questions
AT&T Motorola RAZR2 V9 Cell Phone - Purple Logo
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
