Question about LG LS-L1210CL Mini Split Air Conditioner
What is the button to heat up my room? - LG LS-L1210CL Mini Split Air Conditioner
  • adamsaire May 11, 2010
    According to your equipment model info your system is for cooling only, so this system has no heating capability. It is for cooling only. Sorry!
  • intisarkhan2
    intisarkhan2 May 11, 2010
    There is no heating system.
  • 400 Answers
Open the cover on the remote, to the top left (usually) there is a single button which if pressed repeatedly, changes the mode settings. This can also be seen by changing icons on the display. The first is an ice crystal, second tear drop, third a triangle with a moon, fourth is a sun. Press until you have the sun icon in the display area. Then close the remote and using the up arrow and down arrow buttons select the temperature which is comfortable for you.
Posted on Nov 18, 2009
How to fix power button
I could spend a lot of time describing how you heat round the screen, pry it off, move battery, remove 2 screws holding button assembly, relocate or shim button and reassemble it, but it's easier to point you at someone else's good work and some videos (thanks to those people)
Fix Power Button iPod Nano 6th Generation
Nottingham Solving power button problem in iPod Nano 6th gen The Computer Room...
iPod nano 6th gen power button problem The Computer Room How to
Jun 27, 2014 | Apple Ipod Nano 6th Generation Silver 8 Gb...
The heater won't heat in my window unit.
Hello Jim Hyde - Try pressing the reset button on the plug, if you haven't so already. If the unit continues to not heat up, contact a professional that works with your manufacturer to move forward accurately. Keep in mind that for some air conditioners the heating option is simply a supplement to help heat up a room but in most cases it will not completely heat up the entire room.
Oct 09, 2012 | Frigidaire FAC126P1 wall/window Air...
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
Ive tried to program the heat in my house, but its always too cold, how can i turn on the heat
the thermostat may be in the wrong location for it to work correctly. make sure its in a well heat vented room and not in a closed low volume room. it you want heat push the "hold" button and set a temp that works for you. when done push "run program" buttom to run what you have set into the program.
Jan 31, 2011 | Honeywell Electronic Programmable...
230/208 Volt Built-In Room Air Heat/Cool Unit blows cold air, not heat. Unsure if it may be thermostat, if so.. where is it? Another one blew fuse. Where is it located?
To locate the fuse;
1. Turn the power off or unplug the Room Air Heat/Cool unit.
2.Follow the power cord of the unit. This will normally
terminate at the fuse terminal/power reset button., where you can replace the fuse.
3. After the fuse/power reset button terminal the wire
go to a thermostat normally located at the air output
section at the front portion before it goes to the motor
and heating element, while the other wire may connect direct from the fuse terminal to the motor or
heating element.
This is just the basic electrical set up, it can be modi-
fied. Hope this will guide you in locating the fuse and
the thermostat.
fied
Jan 06, 2010 | GE Built-In Room Air Heat Cool Air...
The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
I want to put room temp on 30c but the default 24c
If you want the room at thirty C, it would appear you want the aircon to heat. To do this it would need to be a heatpump model which is capable of heating. If this is true, then it is a matter of changing the mode setting from cooling (default 24) to heating which would default at 30. Hope this helps. Look for a button with three or four icons, one should resemble an ice crystal (cooling) another should look like a radiating sun.
Jun 09, 2009 | LG Heating & Cooling
2000 hyundai elantra inside room heat
Almost every car(including yours) has a flow through ventilation system which means even with the air turned off air will still come through the vents. Its hot because of outside temp and engine temp.
Basically just push the recirculation button and it will stop.
May 18, 2009 | 2000 Hyundai Elantra
A solid red light
If you have the economy button on turn it off. If there is a draft around the room sensor it will read much lower than the room. That should make the heater run wide open all the time however. Make sure the screens and fan blades are spotless. When it is 4 degrees outside your heater may be working very hard to try to heat the room.
Stay warm,
Tom Hawkins
hawkins111@gci.net
Jan 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
LG LS-L1210CL Mini Split Air Conditioner Logo
167 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
