Question about LG WM0642H Front Load
Wont finish a small load. Gets to 4 minutes and
Wont finish a small load. Gets to 4 minutes and just keeps going back and forth but does not finish spinning out.
  • 1,543 Answers
With a small load, the machine will have a difficult, if not impossible job of balancing the load. A bigger load will help. Another thing you can do is to use a low spin speed. If you wish to spin it out faster, just turn the machine back on after it has finished a cycle on the low spin speed and just push the spin speed button without selecting a cycle. You can touch the spin speed button until it shows the next higher spin speed, then push the start button and the machine will not fill with any water, it will just pump and spin. (about 14 minutes) This generally works, because you have spun most of the water out at a lower spin speed, and now the washer is able to reach the next higher spin speed as the load is not as unbalanced as it was before the low speed spin.
Posted on Nov 17, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Spin cycle
moduel or triack motor controler
Aug 12, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My maytag neptune TL when it gets down to 12 minutes left it starts flashing dc and wont finish the cycle, what is wrong?
You could have a Clutch malfunction if the machine is a FAV6800A or FAV9800A. If that is you r machine type see this post. Clutch Fix
Post back of you have questions.....Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
I work in a hotel and our lobby a/c keeps tripping off I have to continuously keep back and forth turning it on and most of the time it wont even turn on just clicks back off, or stays on for a couple of...
The unit is either too small to cool the area or the compressor is going out. Replace the unit, cheaper to buy a new one than to fix an old unit.
Sep 08, 2009 | Heating & Cooling
Machine freezes at the 9 minute mark.
it might be a timer switch issue thats getting stuck. with the RPM issue thats a transmission issue. make sure the repair guy looks at the tranny for proper function
Sep 04, 2009 | Kenmore 46462 Front Load Washer
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Playstation won't finish loading
probably got a Problem with you Laser...open the machine, clean the lens and see what happens...
Oct 21, 2007 | Sony PlayStation 2 (PS2) Console
LG WM0642H Front Load Logo
267 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
