Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Hp photosmart c4180 ink cartridge problem, SAYS REMOVE AND CHECK CARTRIGE ON RIGHT, which i have many times and cleaned contacts but still the same , any ideas ????
  • 51 Answers
SOURCE: INK CARTRIDGE PROBLEM Remove and check
Take the cartridge out and rub the contacts with a piece of damp tissue paper and try again.
Check the contacts in the printer itself where the cartridge sits. If there is any damage or pin hole on the white ribbon with the gold contacts on it then the printer is unrepairable but it sounds like a cartridge problem. Try changing the cartridge as well
Posted on Jun 14, 2008
  • 521 Answers
SOURCE: my hp photosmart 2575 says
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Posted on Aug 14, 2008
rizla
  • 1463 Answers
SOURCE: Printer says Remove and check colour cartridge
hi john
see if any on there site helps yo here theres also a manual on here as well.
Ink cartridge or toner, paper & accessories HP Photosmart C4183 All-in-One Printer
riz.
Posted on Jan 20, 2009
SOURCE: remove an check cartridge problem in HP 2410xi printer
bought new
Posted on Apr 09, 2009
  • 107 Answers
SOURCE: My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Posted on Oct 21, 2009
My c4180 printer says Ink cartridge problem. Remove and check colour cartridge. Cant get message to go away. I use original Hp ink cartridges
If the color cartridge contacts are clean and there is stil ink in the cartridge.
What you could try is to remove both ink cartridges.
Close cover and turn off printer and unplug the printer.
Wait at least 15 minutes for the printer to reset to clear memory.
Plug the printer back in and turn on and install the ink cartridges.
If you cartridge is not empty and has not expired.
You may call HP and ask for a free replacement.
Jan 09, 2011 | HP PhotoSmart C4180 All-in-One Color...
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
It says remove & check cartridge on right it
Clean the contacts of the cartridge & the printer.
Jan 09, 2010 | HP PhotoSmart C4180 All-in-One Color...
Printer Cartridges won't align C4180 printer
Printer keeps trying to perform an alignment after installing a new black ink cartridge fix:
1. Unplug USB
2. Turn printer off
3. Wait 10 seconds
4. Remove paper from paper tray so printer has no paper to print on
5. Turn printer on
6. Printer messages to insert paper in paper tray
7. Press and hold “Setup” and “ Cancel” buttons and press “OK”
8. Should be good until next black ink cartridge change.
Nov 28, 2008 | HP PhotoSmart C4180 All-in-One Color...
Alignment
Remove both the cartridges from the printer and check the expiry dates on both cartridges, if any of the cartridge is expired then change the cartridge and check the result. If the cartridges are not expired then check the ink levels present in the cartridges from the HP Solution Center. If the ink levels are good then clean the copper contacts of the cartridges with a soft cotton cloth and power cycle the printer.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
Now insert the cartridges and align them, after alignment page prints then scan the page.
If it still gives alignment failed message then remove the cartridges and reset the printer and check for the result.
Jun 10, 2008 | HP Photosmart 4180 All-in-One Printer
Print Cartridge in Right Stall not Supported.
print cartridge colour ink is not workink fix with hp print
May 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
868 people viewed this question
Seeker5211
Seeker5211
