Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Panasonic viera tv,recorder. since updating the system the channel guide for the recorder displays ''No data''. Front panel of recorder says A1. Clock is set but does not display. Any ideas?
Ran auto set up on hdd recorder
Posted on Nov 19, 2009
Panasonic tv model TC-L55ET5 lost 3 digital channels with last update
Those particular digital channels may have been eliminated. The channel lineup changes periodically.
Nov 20, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I can't get the recorder to keep my guide.
There might be a TV Guide issue located in your area, since the transition to digital, TV Guide have been updating there broadcast frequency which is know been done by CBS. Have unit reset by holding down channel up and down button for 15 second on the unit itself until 12 flashes on display, then power on unit and setup TV Guide, then have unit off for 24 hours especially between 11pm to 6am for listing. If issue still exist contact Panasonic to have issue send to TV Guide.
Sep 28, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Jun 24, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Service menu codes
Panasonic TH-42PZ80U Enter Service Mode InstructionsWith TV on, press and hold the volume down button on the front of the TV, and press info three times on the remote. Select Category Instructions1 and 2 Change Data Instructionsvolume up and down Exit Service Mode Instructionspower down Menu Categorywb adj Menu Itemsrgb cut rgb drive all cut all drive -->do not use these unless you need to match ywo displays side by side.
Apr 16, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Cant record sky
connect it to the box with a SCART lead, select A1 or A2 with the channel up / down buttons and away you go
(select A3 if you use the phono connectors under the front panel)
Mar 01, 2009 | Panasonic DMRES20D DVD Recorder
DMR E100H panel button does not work
call Panaonic 1 708 981 4842 and talk to tech support, it sounds like a faulty unit and should be return immediately
Feb 01, 2008 | Panasonic DMR-E100HEBS DVD Recorder
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
331 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
