Question about Sharp AR-275 Copier
Error code L6-10 on sharp ar-275
Please help me, i don't have money now.
  • 66 Answers
Try to reset or replace the polygon motor
Posted on Nov 19, 2009
My sharp machine ar 5516s is having problems giving error code l and 4 simulteniously what can i do
can be the main motor locked if its l4-01 but if its l4-31 its fusing fan locked detected or l4-35 its PS fan locked detected
Jun 18, 2014 | Sharp AR-275 Copier
My sharp phohtocopy showing call for service F2-04 after opening the cover when booting please help me with the code to fix it
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Jul 03, 2011 | Sharp AR-275 Copier
What does code u2-40 mean and how do i by pass it
Hello, You can download the manual here http://sharp.diplofix.com/forum-SHARP/AR-275
It looks like this error is a CRUM chip error, which could be caused by the type of toner cartridge you are using, and or the actual CRUM chip. The connector could be bad (check the connector for the toner cartridge) or when you replaced the toner cartridge; it may have bent the plate that it is mounted on and it needs to be straightened, realigned.
Oct 07, 2010 | Sharp AR-275 Copier
H2 00 problem
Try to reset the error code by pressing these buttons :
[#] [interupt] [c] [interupt] [1] [4] [start/copy]
If the error code still exist check the thermistor and it's connection and reset again.
May 21, 2009 | Sharp AR-275 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Call for service U2-40, on a sharp AR275 printer
In AR 275 Sharp copier U2 40 is very common problem, U have to only reset the above error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 16 then press ok key
pl ask for any difficulty
May 17, 2009 | Sharp AR-275 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-275 Copier Logo
515 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
