Question about Sharp Office Equipment & Supplies
L and 1 alternating - Sharp Office Equipment & Supplies
  • Sharp Master
  • 1,297 Answers
Exposure lamp malfunction code.Check or change the mirror motor control board,check the expo lamp and expo lamp thermofuse continuity.
Posted on Nov 17, 2009
How do I remove the alternator from a 1998 Oldsmobile intrigue
Here is the procedure....
26299069-usz5n5q55ej5tpgx0jyrm3et-4-0.gif The CS130D alternator, used on these engines, is serviced as a complete assembly only.
  1. Disconnect the negative battery cable.
  2. Remove the serpentine drive belt.
  3. Remove the alternator from brace.
  4. Remove the electrical connector from the alternator.
  5. Remove the retaining bolts from the alternator.
  6. Remove the protective boot from the alternator output "BAT" terminal and remove the nut. Disconnect the battery positive lead from the alternator.
  7. Remove the alternator from the vehicle.
To install:
  1. Position the replacement alternator to the engine bracket.
  2. Connect the battery positive lead to the alternator output "BAT" terminal and install the nut. Tighten the nut to 15 ft. lbs. (20 Nm). Install the protective boot over the terminal.
  3. Hand start the alternator front lower bolt and tighten to 37 ft. lbs. (50 Nm).
  4. Install the alternator brace stud through the alternator flange and the bracket and tighten the brace stud to 22 ft. lbs. (30 Nm).
  5. If equipped with the CS 144 alternator, install the inboard alternator bolt through the flange and into the alternator brace assembly and tighten to 37 ft. lbs. (50 Nm).
  6. If equipped with the CS 130D alternator, tighten the rear brace bolt to 22 ft. lbs. (30 Nm).
  7. Plug in the electrical connector to the alternator.
  8. Install the alternator front brace.
  9. Install the serpentine drive belt to the alternator pulley.
  10. Connect the negative battery terminal.
Oct 02, 2016 | 1998 Oldsmobile Intrigue
What is the cheat code for wwe legends of wrestlmania Xbox 360
Animal's alternate costumeEnter "TheRoadWarriorAnimal" as a password to unlock Animal's alternate costume. Alternately, successfully complete Legend Tier 1 in Legend mode.
  • Brutus Beefcake's alternate costumeEnter "BrutusTheBarberShop!" as a password to unlock Brutus Beefcake's alternate costume.
  • Hawk's alternate costumeEnter "HawkFromLegionOfDoom!" as a password to unlock Hawk's alternate costume. Alternately, win three gold medals in Relive mode.
  • Jimmy Hart's alternate costumeEnter "WithManagerJimmyHart" as a password to unlock Jimmy Hart's alternate costume.
  • Koko B. Ware's alternate costumeEnter "TheBirdmanKokoBWare!" as a password to unlock Koko B. Ware's alternate costume.
  • Shawn Michaels' alternate costumeEnter "ShawnsSweetChinMusic" as a password to unlock Shawn Michaels' alternate costume.
  • The Iron Sheik's alternate costumeEnter "IronSheikCamelClutch" as a password to unlock The Iron Sheik's alternate costume.
  • The Rock's alternate costumeEnter "UnlockTheRockBottom!" as a password to unlock The Rock's alternate costume.
  • The Undertaker's alternate costumeEnter "UndertakersTombstone" as a password to unlock The Undertaker's alternate costume.
  • Hell In A Cell matchWin two gold medals in Wrestlemania Tour mode to unlock the Hell In A Cell match.
  • Ironman matchWin three gold medals in Wrestlemania Tour mode to unlock the Ironman match.
  • Steel Cage matchWin one gold medal in Wrestlemania Tour mode to unlock the Steel Cage match.
  • Quick bloodshedIn a Steel Cage match, Irish Whip your opponent into the cage to quickly make him bleed every time.
  • Read more: http://www.cheatcc.com/xbox360/wwelegendsofwrestlemaniacheatscodes.html#ixzz3SF9YEJWx
    Under Creative Commons License: Attribution Non-Commercial No Derivatives
    Sep 26, 2014 | Microsoft Xbox 360 Console
    I have a 98 Toyota Avalon that recently had a dead battery at the airport. When the airport lot attendant jumped the car, it cranked weakly for a second and then nothing happened. Numerous jump attemp
    The battery needs replacing.Also it confirms that alternator is the issue too.
    Check the help links mentioned below.This will help you to get the alternator tested and confirm the problem :----
    Click the link :----
    How to test and replace Alternator on Audi A4 Car models?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-alternator-on.html
    How to inspect Vehicles Alternator?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-inspect-vehicles-alternator.html
    How to Test Vehicles Alternator?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-test-vehicles-alternator.html
    How to Service Vehicles Alternator?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-service-vehicles-alternator.html
    How to Replace Alternator?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-alternator.html
    How to monitor Vehicles charging system?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-monitor-vehicles-charging-system.html
    Car Alternator making noise?
    http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
    Car Alternator Working Intermittently?
    http://repairhelpcenter.blogspot.com/2011/12/car-alternator-working-intermittently.html
    Car Alternator Bearing Makes Grinding noise?
    http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
    How to Inspect Alternator Drive Belt?
    http://schematicsdiagram.blogspot.com/2011/12/how-to-inspect-alternator-drive-belt.html
    How to replace Alternator Drive Belt?
    http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-alternator-drive-belt.html
    How to change Alternator on Peugeot
    http://www.howtorepairguide.com/2012/11/how-to-change-alternator-on-peugeot.html
    Nov 28, 2012 | 1998 Toyota Avalon
    How do i take alternaoter iot of peugeot e7
    Go through few Alternator related solved Solutions including replacement of alternator.Select and Click the link below:----How to replace alternator? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-alternator-on-gmc-sonoma.html
    How to test alternator on Dodge Stratus?
    http://technoanswers.blogspot.in/2012/02/how-to-test-alternator-on-dodge-stratus.html
    How to Remove Voltage Regulator on Car?
    http://vwrepairhelp.blogspot.com/2011/11/how-to-remove-voltage-regulator-on-car.html
    HOW TO REPLACE AN ALTERNATOR BELT
    http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-alternator-belt.html
    How to monitor Vehicles charging system? http://repairhelpcenter.blogspot.com/2011/11/how-to-monitor-vehicles-charging-system.html
    Car Alternator making noise? http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
    After replacing Alternator, the battery indicator light Comes ON dash?
    http://howtobyme.blogspot.com/2011/11/after-replacing-alternatorthe-battery.html
    How to Replace Alternator? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-alternator.html
    Alternator testing? http://schematicsdiagram.blogspot.com/2011/12/alternator-testing.html--------- Cars electrical system is pulsating? http://technoanswers.blogspot.in/2012/01/cars-electrical-system-is-pulsating.html------ 1998 Ford F150 pickup Battery Drains overnight due to Alternator? Alternator drains car battery? http://technoanswers.blogspot.in/2012/02/1998-ford-f150-pickup-battery-drains.html------- 2002 Ford Focus sits over night and battery goes dead? http://technoanswers.blogspot.in/2012/02/2002-ford-focus-sits-over-night-and.html--------- Charging system problem on Chrysler LHS car? http://technoanswers.blogspot.in/2012/02/charging-system-problem-on-chrysler-lhs.html---------- How to replace alternator 1997 Dodge Stratus? http://technoanswers.blogspot.in/2012/02/how-to-replace-alternator-1997-dodge.html------- How to replace Alternator on Mitsubishi Lancer http://www.howtorepairguide.com/2012/10/how-to-replace-alternator-on-mitsubishi.html
    These details will help.
    For more help.Keep updated.
    Thanks.
    Oct 15, 2012 | 1986 Ford Bronco II
    Replace alternator
    Alternator REMOVAL 3.2L Engine
    1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    2. Remove or disconnect the following:
      • Negative battery cable
      • Front splash shield
      • Alternator drive belt
      • Adjuster
      • Top alternator bolt
      • Alternator wiring connectors
      • Alternator
    3.5L Engine
      • Accessory drive belt
      • Alternator
    INSTALLATION 3.2L Engine
    1. Install or connect the following:
      • Alternator
      • Adjuster
      • Alternator drive belt. Tighten the alternator top bolt to 16 ft. lbs. (22 Nm) and the adjuster lock bolt to 17 ft. lbs. (24 Nm).
    3.5L Engine
    2. Install or connect the following:
      • Alternator. Tighten the 10mm bolts to 30 ft. lbs. (41 Nm) and the 8mm bolts to 15 ft. lbs. (21 Nm).
    Jan 08, 2011 | 2000 Isuzu Trooper
    Trying to remove an alternator from an 06 altima
    Removal and Installation L4-2.5L (QR25DE) Engines To Remove:
    1. Before servicing the vehicle refer to the precautions at the beginning of this section.
      • Engine cover
      • Front/right-side engine undercover
      • Drive belt
      • Alternator harness connector
      • Engine ground wire from top mount
      • Alternator upper and lower mounting bolts
    3. Set the alternator aside and remove the top mount.
    4. Remove the alternator.
    To Install:
    1. Slide alternator in place.
      • Alternator top mount
      • Drive belt
      • Engine cover
    V6-3.5L (VQ35) To Remove:
    2. Disconnect the negative battery cable.
    3. Drain coolant from the radiator into a suitable container.
    4. Remove or disconnect the following:
      • Radiator
      • Front/right-side engine under cover
      • Drive belt
      • Idler pulley
      • Alternator adjustable top mount
      • Alternator lower mount bolt and nuts
      • Alternator lower front bracket bolt
      • Alternator harness connectors
      • Alternator
    To Install:
      • Alternator in place
      • Idler pulley
      • Drive belt
      • Radiator
    2. Replace the engine coolant.
    3. Connect the negative battery cable.
    4. Start the engine and check for leaks.
    5. Recheck coolant level and top off as needed.
    Oct 15, 2010 | 2006 Nissan Altima
    How do i replace an alt on an 97 Grand Voyager?
    When you says ALT, I'm assuming that you are talking about ALTERNATOR...
    REMOVAL & INSTALLATION
    2.4L Engine
    2. Remove the accessory drive belt.
    3. Unplug the push-in field wire connector from behind the alternator.
    4. Remove the B+ nut and wire from behind the alternator.
    5. Remove the nut securing the top of the alternator to the adjuster bolt (a.k.a T-bolt).
    6. Remove the alternator pivot nut and bolt, located below the alternator.
    To install:
    1. Install the alternator into position on the vehicle's engine.
    2. Install, but do not tighten, the alternator pivot nut and bolt.
    3. Install the nut securing the top of the alternator to the adjuster bolt.
    4. Connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
    5. Plug in the push-in field wire connector onto the back of the alternator.
    6. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys, especially the alternator.
    7. Adjust the drive belt and tighten the adjuster/locking bolt to 40 ft. lbs. (54 Nm).
    8. Tighten the pivot bolt to 40 ft. lbs. (54 Nm).
    9. Reconnect the negative battery cable.
    10. Verify the charging rate of the alternator.
    3.0L Engine
    2. Remove the windshield wiper/motor module assembly.
    1. Remove the accessory drive belt from the alternator.
    2. Remove the bolt securing the top of the alternator to the mounting bracket.
    3. Remove the bolt securing the bottom of the alternator to the lower pivot bracket.
    1. While holding the alternator, unplug the push-in field wire connector from behind the alternator.
    2. While holding the alternator, remove the B+ nut and wire from behind the alternator.
    3. Remove the alternator from the vehicle.
    To install:
    1. Hold the alternator in position near the mounting bracket, then connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
    2. Plug in the push-in field wire connector onto the back of the alternator.
    3. Place the alternator into position on the mounting bracket, then install the bolt securing the bottom of the alternator to the lower pivot bracket.
    4. Install the bolt securing the top of the alternator to the mounting bracket. Tighten the upper and lower alternator bolts to 40 ft. lbs. (54 Nm).
    5. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys.
    6. Install the windshield wiper/motor module assembly.
    7. Reconnect the negative battery cable.
    8. Verify the charging rate of the alternator.
    3.3L and 3.8L Engines
    3. Remove the accessory drive belt.
    4. Remove the bolt securing the top of the alternator mounting bracket to the engine air intake plenum.
    1. Remove the bolts securing the outside of the alternator mounting bracket to the alternator mounting plate.
    3. Remove the alternator mounting bracket from the vehicle.
    4. Rotate the alternator toward the dash panel.
    5. Unplug the push-in field wire connector from behind the alternator.
    6. Remove the B+ nut and wire from behind the alternator.
    1. Remove the bolt securing the bottom of the alternator to the lower pivot bracket.
    2. Remove the alternator from the vehicle.
    To install:
    2. Install the bolt securing the bottom of the alternator to the lower pivot bracket.
    3. Connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
    4. Plug in the push-in field wire connector onto the back of the alternator.
    5. Rotate the alternator forward away from the dash panel.
    6. Install the alternator mounting bracket in position on the vehicle.
    7. Install the bolt to secure the top of the alternator to the mounting bracket.
    8. Install the bolts to secure the outside of the alternator mounting bracket to the alternator mounting plate.
    9. Install the bolt to secure the top of the alternator mounting bracket to the engine air intake plenum.
    10. Tighten all of the alternator mounting bolts to 40 ft. lbs. (54 Nm).
    11. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys.
    12. Install the windshield wiper/motor module assembly.
    13. Reconnect the negative battery cable.
    14. Verify the charging rate of the alternator.
    Hope helps woth this, remember rated this help. Good luck.
    Jul 08, 2010 | 1997 Plymouth Grand Voyager
    Alternator Removal
    Alternator - REMOVAL & INSTALLATION
    2. Raise and safely support the front of the vehicle securely on jackstands.
    3. Remove the passenger side engine and transaxle splash shield.
    4. Remove the alternator wiring harness bracket bolt from the rear of the alternator.
    5. Disconnect the alternator electrical connector from the alternator.
    6. Remove the ground wire nut and wire.
    7. Remove the B terminal wire boot. Remove the B terminal nut and wire.
    8. Loosen the inner and outer alternator to bracket mounting bolts.
    9. Loosen the alternator adjustment lock bolt.
    10. Turn the alternator adjustment bolt counterclockwise to loosen the belt.
    11. Remove the belt from the alternator.
    12. Remove the alternator lock bolt and washer.
    13. Remove the inner alternator to bracket mounting bolt and two washers.
    14. Remove the outer alternator to bracket mounting bolt and two washers.
    15. Remove the alternator.
    16. The installation is the reverse of removal.
    17. Adjust the drive belt. For the procedure, please refer to General Information and Maintenance, Routine Maintenance and Tune-Up, Belts, Adjustment, Alternator.
    Fig. Alternator wire identification
    Hope help with this (remember rated this post).
    May 17, 2010 | 1998 Mercury Villager
    How do i change the altinater on a 98 lincon continental
    Removal & Installation
    Rotate the tensioner and remove the belt from around the alternator pulley
    Detach the 2 connectors from the alternator
    Slide the boot up to access the battery cable on the rear of the alternator
    Remove the nut retaining the battery cable and . . .
    . . . remove the battery cable from the post on the rear of the alternator
    Remove the three alternator rear mounting bolts
    Remove the two front alternator mounting bolts
    Remove the alternator from the engine by carefully lifting it up and out of the engine compartment
    2. Tag and disconnect the wiring connectors from the rear (or side) of the alternator. To disconnect push-on type terminals, depress the lock tab and pull straight off.
    3. On 3.8L and 4.6L engines, rotate the automatic tensioner away from the drive belt and disengage the drive belt from the alternator pulley. Remove the alternator brace.
    4. On 3.8L engines, remove the alternator pivot bolts, top and bottom and remove the alternator.
    5. On 5.0L engines, loosen the alternator pivot bolt and remove the adjusting bolt. Disengage the drive belt from the alternator pulley.
    6. On 3.8L and 5.0L engines, remove the alternator pivot bolt and the alternator. On 4.6L engines, remove the alternator mounting bolts and remove the alternator.
    7. Installation is the reverse of the removal procedure. On 4.6L engines, tighten the alternator mounting bolts to 15–22 ft. lbs. (20–30 Nm) and the alternator brace bolts to 70–106 inch lbs. (8–12 Nm). In addition, on 5.0L engines, adjust the drive belt tension
    Nov 30, 2009 | 1998 Lincoln Town Car
    Remove and replace alternator
    2000 Ford Truck Expedition 4WD 4.6L EFI 8cyl
    4.2L Engine
    2. Disconnect 2 alternator and voltage regulator electrical harness connectors at the alternator. To disconnect push-on type terminals, depress the lock tab and pull straight off.
    3. Remove the positive battery cable nut and remove the positive battery cable at the alternator.
    4. Rotate the drive belt tensioner away from the drive belt and remove the drive belt from the alternator pulley.
    5. Remove 3 alternator retaining bolts and remove the alternator.
    To install:
    1. Place the alternator on the engine and install 3 alternator retaining bolts. Tighten the bolts to 18-22 ft. lbs. (20-30 Nm).
    2. Rotate the drive belt tensioner away from the drive belt and install the drive belt on the alternator pulley.
    3. Connect 2 alternator and voltage regulator electrical harness connectors.
    4. Connect the positive battery cable to the alternator and install the nut and washer. Tighten the nut to 84 inch lbs. (10 Nm).
    5. Connect the negative battery cable.
    6. Start the engine and check for proper charging system operation.
    4.6L, 5.4L and 6.8L Engines
    Fig. 1 Detach the connectors from the alternator
    Fig. 2 Remove the nut and the battery cable from the post on the rear of the alternator
    Fig. 3 Remove the 2 front alternator mounting bolts and ...
    Fig. 4 Remove the alternator from the engine by carefully lifting it up and...
    Fig. 5 ... out of the engine compartment
    2. Rotate the drive belt tensioner away from the drive belt and remove the drive belt from the alternator pulley.
    3. Detach the electrical harness connectors at the alternator assembly.
    4. Disconnect the positive battery cable and remove the nut and washer.
    5. Remove 2 front alternator bolts.
    6. Remove the rear alternator support bracket retaining bolts and the support bracket.
    To install:
    1. Place the alternator in position and loosely install 2 front alternator retaining bolts.
    2. Install the alternator bracket and 3 alternator bracket bolts. Tighten to 84 inch lbs. (10 Nm).
    3. Tighten 2 front alternator retaining bolts to 19 ft. lbs. (26 Nm).
    4. Connect 2 electrical harness connectors to the alternator assembly.
    5. Connect the positive battery cable and install the nut and washer. Tighten the nut to 72 inch lbs. (8 Nm).
    6. Rotate the drive belt tensioner away from the drive belt and install the drive belt on the alternator pulley.
    7. Connect the negative battery cable.
    8. Start the engine and check for proper charging system operation.
    5.8L and 7.5L Gasoline Engines and 7.3L Diesel Engine
    1. Disconnect the battery ground cable.
    2. Label and detach the connectors from the alternator.
    3. Release the tensioner and remove the drive belt from the alternator pulley.
    4. Remove the alternator retaining bolts.
    5. Remove the alternator from the vehicle.
    To install:
    1. Position the alternator and install the retaining bolts. Tighten the retaining bolts to 15-21 ft. lbs. (21-29 Nm).
    2. Install the drive belt.
    3. Attach the alternator connectors.
    4. Connect the battery ground cable.
    I really hope help you with this (remember rated this help) Good luck.
    Oct 13, 2009 | 2000 Ford Expedition
    65 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
