Question about HP Officejet 7130 All-In-One InkJet Printer
Clean officejet print head
Print head plugged up
  • deeyouefef Mar 07, 2008
    How do I clean the color print head?
    Problem Solver:
  • 9 Answers
You can get very good results in reviving the HP Officejet 7100 Series printheads simply by placing them in a shallow plate or dish with about 1/4" of hot water (ideally distilled water). Soak the nozzle face (bottom) for at least 5 minutes before drying and testing; repeat if needed for really clogged heads.
Posted on Mar 12, 2008
2 Suggested Answers
  • 54 Answers
SOURCE: print head on Officejet Pro L7590
Press Setup on the control panel.
Press the right arrow button until Tools displays, and then press OK .
Press 2 to begin the cleaning process.
Posted on Nov 21, 2009
HP Officejet Pro 6830 - "The print carriage cannot move"
Unplug the printer and wait 20 minutes and then re-plug.
Jun 20, 2017 | HP Office Equipment & Supplies
How do you remove the print head for cleaning?
You should first try the cleaning procedure that is available through your printer's control panel - .HP Officejet 6600 6700 Printers Fixing Poor Print Quality Problems If that does not work here is a video on removing the HP print head.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 10, 2016 | HP OfficeJet 6600 e-All-In-One Inkjet...
Hp officejet pro 8500a shows cleaning print head/alining print head
that might be your printing settings and laptop file formate
Mar 17, 2016 | HP Office Equipment & Supplies
HP Officejet 6500A - frequent print head clogs
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 13, 2012 | HP Officejet 6500A Plus
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
I have a HP Officejet printer model 6500 E709n (USB connected) and I have just changed the black print cartridge and now the printer only ptints blank ppages. I check of the printer status reveals that...
What about print head?.. perform print head cleaning process through tool box, check any back print out? no remove black/yellow print head clean nozzles manually, try it if not resolved replace print head..browse the link how to clean the print head..http://www.ehow.com/video_4974250_manually-clean-hp-inkjet-cartridge.html
Oct 27, 2011 | HP Officejet 6500 Wireless All-in-One...
On my HP Officejet 4215, my black cartridge doesn't print. The cartridge is nearly full.
If you haven't used the black print option, as in to print without using the color cartridges, then the black print head may be 'gummed up'.
You can try to clean the print head using the 'clean' function, which may work.
You can also try to get the print head to work by using ammonia and hot water. If the cartridge has its own print head, you can use some hot water on a paper towel and set the print head onto the soaked towel for a few minutes. After it has sat for a while, gently dab it dry with another paper towel, and try to use it. If it works, you're done. If not, you can use ammonia to try to clean the print head using the same tactics as using water. Try water first, then ammonia.
If the print head is fixed in place, you have to remove the whole assembly from the printer, and then try to clean the print head using the same method.
tom
Aug 11, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Black ink will not print
The ink on the print head is dry and it is preventing it from printing.
I do my own refill so I buy a refill kit, in it, has 3 bottle of inks and a bottle of cleaning solution. The cleaning solution I use to clean the head.
A place that refill in should carry some kind of a cleaning solution that you can use.
I hope this help you
Mar 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
How to clean Print Heads?
Go to the control panel
Select printers
Find the OfficeJet Icon and move the mouse over to it.
Press the right mouse button and select properties
Look for a tab that says toolkit.
select ink jet cleaning.
Jun 17, 2008 | HP OfficeJet 7110 All-In-One Thermal...
HP Officejet 7130 All-In-One InkJet Printer Logo
879 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
