Question about Brown Stove Works TEM721-DK Electric Single Oven
What is the Correct Wire Gauge And Ampere Supply For An Brown Builtin Oven. Appliance Numbeer 5G81120,Type 44823,Voltage 120/240, 1 Phase, 3 wire, 60 cycle, KW 2.3 Max My Oven was bought from DOBBS Aplliance Store with a 12/3 BX Cable Attached to Rear Exterior Panel for attachment to Residential Wiring. The existing Residential wiring provideing Power to this Electric Oven 1s 6/3 Romex . The Ampere Rating for the Ciruit Breaker is 50 Amp. My Name is Johgn W. Koch Phone # 928 920 5492 Email User ID is John Koch E-Mail address jkochjr@roadrunner.con
    Sergeant:
    Champion:
  • 289 Answers
12/2
Posted on Nov 17, 2009
It is wired for 3 phase can it be wired single phase
3-phase is a way to supply more power on similar wires. If your oven is designed to be run off 3-phase, then it will need that. I've not seen any residential ovens wired that way, though. What makes you think it's wired 3-phase? If you are in the US, it's likely wired for 230v, which is 3 wires, but not 3-phase.
Jun 02, 2015 | Ovens
Proper Gaggenau EB294 Oven Terminal Block to Cable Harness wiring
If its brand new, most possibly the electrician did not bridge the mains connection.
It sounds like an installation fault.
There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection.
Oshie
Apr 09, 2008 | Gaggenau EB294/295 Electric Double Oven
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
I have had a P-44 oven in an Auntie Anne's Pretzels shop for 15 years. It has been connected to a 4-wire, double-breaker circuit. I ordered a new P-44 through Auntie Anne's and thought it would be...
hi...since the specification of your new oven is 208v 1-phase and since voltage rating on your receptacle or outlet s only 120v..it would be advisable for you to purchase an INVERTER, it is a step-up transformer that converts 120v to 220 v..in that way you can supply your oven according to its specification..thanks..
Jul 06, 2011 | Bakers Pride P-44S Oven
When baking something all of a sudden the preheat will beep a couple times and the oven will start cooling down.It does not maintain its heat.Just a little frustrated right now because trying to do...
check the ignitor use an ampere meter or set a voltage meter to amps clip it on the ignitor wire should be reading 3-3.3 amps any less and your oven will not be lighting in time and will cool down because it takes so much longer to light if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
RIck
Dec 19, 2010 | Ovens
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
Hi , i am an electrician installing a westinghouse pek1380w-r stove , my mate that bought the stove is still waiting for the manual and cannot tell me how many amps the stove will draw so i can select a...
this unit will draw up to 50 amps if all burners are operating. i do not know the exact wattage, but they usually have an 8 gauge wiring connector already on the oven, if a wall oven.
if a free standing then you will have to put on a cord that will also be an 8 gauge.
you will need to determine what wire gauge to use depending on how long of a run you have from the circuit panel to carry the load.
it is also a single phase 240 volt system, but that doesnt matter because the wires are the same.
are you new at being an electrician? check your code book to make sure you are doing this wiring by the codes for your area.
Jan 12, 2010 | Ovens
Bakers pride electric deck ovens aprox 10 yrs old
It depends on the ampere rating, you will not normally be able to get a single phase supply in the UK at more than 100 amps total.
If the total oven rating is not more than 60 amps you may be ok.
Conversion would involve altering the wiring in the oven which may be costly and not worthwhile on a 10 year old oven.
Jan 06, 2010 | Bakers Pride CO11-G2 Gas Double Oven
Looks like our church just received the Vulcan VC4ED convection oven - 208 volts 60 amp. We have the 60 amp breaker but what gauge wire from the breaker to the oven do you recommend? I have to run about 35...
use 3 -- 6 gauge copper wires, you could get by with 2--6 gauge wires for the two hot phases and 1--8 gauge for the neutral connection,but with that long a run use all 6 gauge so you don't experience any voltage drop,also in your community you may need to check the local codes on grounding and need to add a separate grounding wire,which you can use an 8 gauge for this wire connection, if you use aluminum wire(which I highly DO NOT reccomend) you will need to get one gauge larger as in 3--4 gauge aluminum to carry the same current as copper wire
Dec 08, 2009 | Vulcan VC4ED Electric Single Oven
Blodgett convection oven how to wire it
They can tell you right on. Great Co.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
May 03, 2009 | Blodgett CTB BASE Electric Single Oven
Brown Stove Works TEM721-DK Electric Single Oven Logo
371 people viewed this question
Top Brown Stove Works Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Brown Stove Works Oven Expert? Answer questions, earn points and help others
