Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
How to connect an AKAI LCD tv to an INDOOR antenna. I have set the TV from cable to "air".
  • 11,896 Answers
Put tv on air, connect antennae to the coaxil input on back of tv.
You can also go to tv's menu and find the "autoprogram" feature and select it. Let it run thuroughly until it is done searching all available channels. Tv. may need to be on channel 3 or 4 to use the antennae/converter box
Posted on Nov 17, 2009
  • Vincent Gonsoulin
    Vincent Gonsoulin Nov 16, 2017
    Problem is I have done all of the above and still no signal????????????????????????
How to install indoor digital tv antenna to a lcd tv & pickup digi channels
First, the LCD TV has to have a digital tuner in it. Older ones may not. If it does, then you attach the antenna connector to the TV connection that is marked TV IN or CABLE. Then, in the TV's menu, you would need to ensure that the digital tuner is selected. Once that is done, then, still in the menu, perform an "ON AIR" channel scan to find and lock in whatever digital channels that the antenna can detect.
Aug 05, 2015 | Electronics - Others
Hoe to set up the tv and antenna
you either need this, Indoor Matching Transformer Gold 75 Ohm to 300 Ohm Balun Antenna Coaxial Cable Twin Lead for Off-Air TV Video Signal Component Connection Adapter / Converter
25711901-wlg4wwjx1hbxmhorbqissfon-1-0.jpg or one of these,
May 25, 2015 | KZ 2013 Sportsmen Classic 200
How do I set TV to antenna - Vizio VA26L
The input should be selected as 'TV' to get any on-air transmission. Now the input is selected to Cable. Change it to TV. Refer its user manual for more details.
Aug 04, 2012 | Vizio VA26L 26 in. LCD HDTV
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
A GPX model tvwb534 connecte to an indoor rabit antenna doesn't work?
You either may have the set on Cable setting or the signal is too weak for the set to pick up the channels---indoor antennas have a very limited range and many channels have ended on air broadcasts completely
Mar 24, 2012 | Televison & Video
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
May 15, 2011 | Televison & Video
I just bought an LCD 1933A TV. I don't have cable so I connected an indoor antenna to it as instructed ( Radio Shack indoor amplified HDTV antenna 15-254). I turned the TV on and no matter what I did...
Few things,
  1. You will have to go into your menu settings and be sure to select "Air" instead of Cable for your antenna connection
  2. Then run auto scan channel setup to find all available channels in your area
  3. Once completed be sure you are on Input Source TV you should be able to select Channel up/down on the remote to select your channel to view
If you ever see No Signal you are probably on an AV input and not on your antenna input.
The full PDF manual can be found here:
http://www.curtisint.com/html/custservice/manuals/CUR_LCD1933A_EN.PDF
I hope this helps
Magoo
Mar 11, 2011 | Curtis Televison & Video
I cann;t receive several network channels on my Dynex 26: L150A11 LCD TV using only an antenna (no converter box). Does this TV have a built-in digital tuner? Do I need to use anything else to connect ?
all new tvs should have a built in digital tuner. Make sure that tv is set to receive antenna signal and not cable by going into the menu. Use autoprogram feature if you haven't done so already. it will lock onto whatever signal is strong enough for it to see. Also if you are using an indoor antenna it may not be able to get enough signal to the box. Indoor antennas are not the greatest especially if the station is far away.
Sep 11, 2010 | Televison & Video
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
346 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
