Pilot light will not stay on. i have a model ml060hpa, single burner heater
  • 11,896 Answers
It is common for the gas valve springs to become weak and not keep valve open.
Also common for the pilot itself to become corroded on the little inside rod that keeps pilot heated. Try cleaning the pilot so it is shiny and clean. And check that gas valve is completely opened.
Posted on Nov 17, 2009
Gas burner wont stay lit
Is it the Pilot, or the main burner that won't stay lit?
The pilot has a little 'flame rod' in the path of the pilot flame, that conducts a tiny current thru the flame, to a detection circuit-- assuring that there is a pilot flame-- If that rod get's dirty, it can cause false trips. Is that any help?- Mack B
Oct 25, 2013 | Honeywell Pilot Burner for Natural Gas,...
Pilot will not light, seems to not be getting any propane to it. The regulator on my propane tank works fine. What could be the cause?
I would trace gas line out and determine were you are getting gas and where it is not. With the gas on I would carefully loosen union or flex fitting going to gas valve.If you have gas there then retighten union and go to fitting on pilot line and check it.You should be able to get gas there by depressing pilot light button.If you have gas there then go to pilot assembly and remove it from gas valve and burner. Remove pilot orifice and carefully clean and blow thru pilot line to make sure it is not obstructed.
If you cannot get any gas thru gas valve then shut off gas before valve and remove inlet line. There should be a fine mesh steel screen there. Make sure it is clean.If you are getting gas to gas valve but not thru it then you probably need to replace gas valve. Thank you
May 17, 2011 | Procom ML060HPA Heater
Pilot light does not stay lit when I attempt to light the plaques. Pro com 6000 btu.
Either you have a gas pressure problem or the ODS (Oxygen Depletion Sensor is clogged. I suspect it's the latter. If you feel comfortable attempting to clean and service it yourself, it can be done. But, it will require taking the front cover off the heater. If you don't feel comfortable doing it yourself, contact your Propane provider or a hearth and home store in your area. These units do require annual cleaning and service.
Jan 19, 2011 | Procom ML060HPA Heater
I have a PROCOM model ML300TBA, two years old. Here is my problem: Pilot lights fine. Burner lights fine. When I go back the next morning, often times it is out. Burner and pilot are out. It will...
You could try cleaning up the thermocouple with steel wool. Some manufacturers call this a flame generator as well. Any how make sure it is clean and positioned in the top center of the pilot light for best signal. This is only speculation as these are common problems that will arise on heaters in general. This also turns the gas to the burners and pilot light so thats why to start here first. Hope this helps you out.
Dec 23, 2010 | Procom ML300TBA Heater
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
