Question about Toshiba 36HF73 36" TV
Removing parent block on a used Toshiba 36HF73 36
I was given a used Toshiba 36HF73 36" TV that unfortunately has a parental block locking out even PG-rated shows. The previous owner has moved away. Is there a way to reset/remove the blocking?
    President:
  • 1,284 Answers
If you don't have the unlock code you can do this to remove it. Please take a few moments to rate my answer..Thank you...
If you cannot remember your PIN code
While the PIN code entering screen is displayed, press RECALL
four times within five seconds. The PIN code will be released
(Blocking Reset status restored)
Posted on Nov 17, 2009
Testimonial: "Thanks! Seems to have worked great."
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Jun 17, 2013 | Televison & Video
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Child lock
  • Step 2 Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
  • Step 3 From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
  • Step 4 From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
  • Step 5 Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
  • Step 6 Lock the controls to activate the changes using item six on the "Parental Controls" menu.
  • Nov 30, 2009 | RCA Mikomi 5290925 15 in. LCD TV
    Turning parental control blocks off
    Parental locks are put in place to stop minors from accessing usuitable programs. An adult usually selects the channels to lock out as well as categories of videos that can be played. Thesae are controlled by a code neterd by the Parent or Giuardian and cannot be subverted without knowing the code. I am tempted to say.... ask your parents for permission to unlock this. We cannot supply any information without proof of age here.
    With this model also there are no secret codes listed to over ride an entered password as its not a regular brand of TV. maybe the people you bought it from ( Walmart?) may be able to contact the supplier who rebadged this unit, to help you overcome the problem
    Sorry we cant be of more help for you. Please accept our apologies
    Thank you for using FIXYA
    Sep 25, 2009 | Prima C2012 TV
    Password reset
    The Rating menu allows you to block playback
    of DVDs based on their ratings.
    Setting the Password & Rating Level
    The DVD player allows you to block playback
    of inappropriate content with a passwordprotected
    Rating system (not all discs are rated).
    A. From Stop mode, press SETUP.
    B. Select Rating and press ENTER.
    C. Select Rating and press ENTER repeatedly to set the rating from 1 (most restrictive)
    to 8( least restrictive ).
    If a password has already been set, the lock icon will be closed. You will not be
    able to select Rating until you SELECT the correct password using the 0-9 keys.
    D. Select Password.
    E. Use the 0-9 keys to SELECT a 4-digit password and press ENTER. The lock icon will
    close to indicate that the rating and password are set.
    F. Press SETUP to save and exit.
    Not all DVDs are rated.
    DVDs that are rated higher than the level you select will not play without SELECTING
    the correct password.
    If you forget your Rating password, select 8888 to clear the memory. Keep this password
    out of reach of children as if will always unlock the Parental Control setting.
    If you need more help you can get the full manual from
    http://www.retrevo.com
    Thanks for using fixya
    Aug 01, 2009 | Astar DVD-3800
    Can't get the child lock off
    You can use theV-Chip Parent Lock to
    Block or Allow programs based on the
    ratings sent by the broadcast stations.
    The default setting is to allow all programs.
    You can block programs by the
    type of program and by the categories
    you want blocked. Or you can block all
    programs during a specific time period.
    To use the V-Chip Parent lock, you will:
    • Enter a passcode
    • Select theV-chip ratings and categories to block
    • Select theV-chip hours to lock and unlock for television programs
    • Select lock by time
    Enter a Passcode
    MENU
    I. Press _ to display the Main Menu.
    2. PressAorV to select V-Chip Parent Lock.
    PressE_ R,
    3. Using the number keys, enter four numbers. To
    delete a character and move back one space, press
    CANCEL ENTER
    . Press _ to set the passcode and go to
    theV-chip ratings menu.
    MENU
    4. To exit without entering a passcode, press _ to
    HOME
    go to the previous menu or _ to return to
    television viewing.
    IMPORTANT
    If you forget your four-digit passcode, please
    see Appendix 3 : Procedure for Bypassing the
    After you set the lock, you will need the secret code in order to:
    • view a locked program,
    • view the locked TV, or
    • cancel the lock.
    If you forget the code, you can view the locked TV without entering the code. To do this, simply
    press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
    code is requested. Unlocking theTV this way is temporary.
    To change or permanently cancel the lock:
    I. Turn on your TV. If the TV requests your secret code, press
    and_ at the same time.
    MENU
    2. Press _ to view the main menu.
    3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
    4. The on-screen display will ask for your current passcode. Press
    and _ at the same time.
    5. The on-screen display will now ask you to enter a new code:
    MENU HOME
    • To cancel the passcode permanently, press _ or _ .
    • To change to a new passcode, use the number buttons to enter a
    new code, then press E_R,
    IMPORTANT
    You must use the remote control included with this
    TV. You cannot use a remote control from another
    Mitsubishi component and you cannot use "Univer_
    sar' remotes from other manufacturers.
    65
    Nov 24, 2008 | Mitsubishi VS-55707 TV
    Smart lock
    If that function was put in use by the previous owner, the fastest way to change the parental lock out would be to contact your friend and get the access code from them.
    Since the set probably uses a bit of flash memory to store the access code and other settings, if an individual chip, that would have to be physically removed and replaced.
    If you can locate service information on your set, it will likely contain a procedure to set the memory back to factory default.
    Jul 06, 2008 | Philips Magnavox 20MT133S 20" TV
    Soundstorm car dvd player
    This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
    May 29, 2007 | Soundstorm SDVD-100 Car DVD Player
    Message protected program by tv-pg
    Go into Menu /V Chip arrow key up to tv rating should show all locked volume down or visversa should should view all Note may have to volume up to get to options from menu depending on how old the tv is.
    Apr 04, 2007 | Emerson EWV403 VHS VCR
    Toshiba 36HF73 36" TV Logo
    733 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
