Question about Copystar CS-1510 Copier
What does the OP error code mean? Thanks! - Copystar CS-1510 Copier
  • 105 Answers
Usually that thers is an access door open
Posted on Nov 17, 2009
2 Suggested Answers
  • 168 Answers
SOURCE: Mita error code
I think that stands for OPEN. Check to make sure that all the doors are closed. Right side, left side door, and also front door.
Hope this helps.
If you still have the OP message, then let me know and I will dig out my books and look it up.
Good luck.
Mac
Posted on Mar 13, 2008
"OP" what is the meaning of this code refrigerator frigidaire
Good Morning friend, thank you for your post!
I see that your Frigidaire refrigerator is displaying an "OP" error code and you want to know what it means. An "OP" could stand for open thermistor. This could be a possible problem with your thermistor or control panel. In any case that it is a false error code I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for roughly ten minutes. If that does not help resolve your issue I would suggest consulting with a professional technician for proper diagnosis. Hopefully this is helpful information. -Matt
Feb 12, 2015 | Frigidaire Refrigerators
What does the error code "OP" mean?
OP - Open Thermistor - Replace thermistor.
Aug 27, 2013 | Washing Machines
Hi we have a PDW-HD1500 with an error message/code of Error02-FB7. Thanks.
Error code 02-FB7 means "No movement is detected in the ND filter initial operation check of OP (OP1)", meaning the filter that regulates the ammount of light coming out of the laser diode is faulty. It does not say what the problem is, only that there is one.
Swapping the OP (Optical block assembly (the laser thingy on the two rails in the ODD)) for a new one will certainly fix this problem. just make sure you don't touch the lens!
Jan 02, 2013 | Sony PDW-HD1500 XDCAM HD Compact Deck...
"od" message
The OD and OP error codes are trouble shot the same way. See if this link will help.
display shows OP but unable to clear
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference
If you need additional help let me know.........Rich
Jul 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
OP error code. What is wrong with my Hayward pool
OP is the error code for a faulty Temperature Sensor. Try replacing the Temperature Sensor. I have seen many of these units have the wires chewed up by mice, etc., so you may want to check the wiring for any damage.
Jul 03, 2010 | Hayward 116k BTU HeatPro Digital Heat Pump...
I have an error code OP what should i do
You could have a lid magnet out of position. Quick check for that is to place a magnet over the left bumper with the lid raised and see if the OP error code clears.
If it does you need to remove the inner panel of the lid to access the lid magnet see page 32 of the Service Manual for the procedure.
If the external magnet doesn’t clear the OP error code you will have to start troubleshooting the Left Hand Lid Lock. You could have severe corrosion with and an open lead on the magnetic reed switch in the Left Hand Lid lock. Link to replacement Left Hand Lid Lock
See this post Left Hand Lid Lock Troubleshooting for further info. I discuss troubleshooting the OD error code but you troubleshoot the OP error code the same way……Rich
Jun 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
OP error
Have you added toner recently?? If the copier is just running and then shows code you may have to install a new toner. The soft ware is different in different contries and the codes are all not the same meaning. I would cheak the toner first..
Apr 14, 2009 | Kyocera KM-1505 Copier
Mita error code
Hope this helps.
Good luck.
Mac
Mar 12, 2008 | Office Equipment & Supplies
OP error
OP stands for open door. Either the front door is open or a side door is open.
Hope this helps.
Jan 26, 2008 | Kyocera KM-1505 Copier
Copystar CS-1510 Copier Logo
51 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
