Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
My son dropped the remote on a carpeted floor and now the lights are dim. I've tried to replace both the bulbs and battery in the remote but nothing works. Why did this happen?
Just hold down the light button on the remote. It'll go dim then will brighten back up then dim again.
Posted on Dec 03, 2009
    New Friend:
My bell remote was drop on the floor now it won't go on guide are change Chanel's so I got another one it still won't work what's the problem
Posted on Nov 30, 2013
  • 161 Answers
Push and hold the light button, the lights should dim down and brighten up after a few seconds
Posted on Nov 17, 2009
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
I just bought a home with two outdoor fans with a Minka Aire TR111a remote.
The light is a battery indicator. Try a new battery .
Sep 25, 2015 | Minka Dryers
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
I have a 2002 Hyundai Accent (UK RHD). I've had a headlight go out, side lights and full beam still work. I've changed the bulb and fuse but its still dim. Ran out of ideas...
Hi ,Check the light bulb,see if its seat in the seats properly 'for earth' and the light terminals for dirts ,grease,or corrosion.clean if needs to.I think its a Earth problems
Dec 17, 2012 | 2002 Hyundai Accent
Honda 2004 Silver Wing 600 ABS has not been generally starting but every once in a while does. I've replaced the battery and taken it to the Honda dealer when it finally started. It always started for...
It seems like something is draining the batery. For a battery to go dead on you like that there must be something draining the battery while the vehicle is switched off. It could be something like a short across some circuit. The first and easiest test is charge the battery and then to disconnect the battery negative cable whenever you park the vehicle overnight etc. and see if the battery still runs down.
As a more positive step is to disconnect the positive lead from the battery and wire a bulb like a tail light bulb, between the terminal and the removed lead. The bulb should light up. Make sure that everything on the vehicle is switched off, the bulb should still be lit. Remove and replace the fuses one by one until the bulb goes out. That is the circuit that is running your battery flat. Check all the components on that circuit until you get the light to stay out and your problem should be fixed.
Check your charging system. With the engine running at about 4000 rpm, a volt meter across the battery terminals should read around 14 to 14.5 volts and drop to about 13.8 volts with the engine at idle. If this does not happen, the charging system may be defective. Even with lights on the voltage should climb, but will drop lower at idle.
May 21, 2011 | 2004 Honda Silverwing 600 ABS
I changed my bulbs and now the fan or the light will not shut off by the remote. The lights dim but that's it.
changing the bulbs shouldn't cause a problem, it could be a difference in the designation of the fixture and the bulb, or be a simple problem with the remote. If you haven't checked or replaced the remote's batteries, you can try checking what the specs are for the fixture (should be on the side of the light-socket), and see how that synchs up with the bulb's specs.
Oct 23, 2009 | Hampton Bay 04345 Cruiser Ceiling Fan
How do I replace a taillight lens on a 1991 Geo Storm?
Rear Turn Signal, Brake and Parking Lights
STORM COUPE
  1. Disconnect the negative battery cable.
  2. Lift the luggage compartment floor carpet toward the front of the vehicle and remove the spare tire cover panel.
  3. Remove the ten plastic retaining clips from the rear end trim panel.
  4. Disconnect the luggage compartment lamp electrical connector.
  5. Remove the luggage compartment trim panel and the rear end trim panel.
  6. Disconnect the rear combination lamp assembly electrical connector. Fig. 1: Rear Turn Signal, Brake and Parking Lights — Storm
  1. Remove the seven nuts and the rear combination lamp assembly from the vehicle.
  2. Disconnect the rear combination lamp electrical connector.
  3. Remove the four bulb sockets from the rear combination lamp assembly and remove the four bulbs from the sockets. To install:
  4. Install the four bulbs to the sockets and install the four bulb sockets to the rear combination lamp assembly.
  5. Connect the rear combination lamp electrical connector.
  6. Install the rear combination lamp assembly to the vehicle and the seven nuts.
  7. Connect the rear combination lamp assembly electrical connector.
  8. Install the rear end trim panel and the luggage compartment trim panel.
  9. Connect the luggage compartment lamp electrical connector.
  10. Install the ten plastic retaining clips to the rear end trim panel.
  11. Install the spare tire cover panel and the luggage compartment floor carpet.
  12. Connect the negative battery cable.
Mar 21, 2009 | 1991 Geo Storm
Dropped Nintendo DS Lite on wooden floor - NOW IT WON'T TURN ON
remove the battery for a few mins and put it back in and try again?
Its a long shot but theres very little you can do with this, the insides of the DS lite are REALLY small and the only replaceable parts are the screen, buttons, etc. and you cant really fix damage to the board or chips inside which presumably is whats happened here if you get zero response.
Sorry.. :(
Nov 13, 2008 | Nintendo DS Lite Console
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
335 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
