Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Hard drive needs to show as f instead of g on computer when plugged into usb
    Sergeant:
  • 206 Answers
Drive Letter changes can be made from the Control Panel, Administrative Tools, Computer Management page. Under Storage, Disk Management, the volumes (drives) are listed. Right click for properties, then change drive letter.
I am curious about why a particular letter drive is needed. Windows will default assign the drive letters. It lists the Drive Icon, Drive Name (or Type) and Drive Letter...OS (C:), CD Drive (F:), etc.
Posted on Nov 17, 2009
    Brigadier General:
  • 10,406 Answers
Why does it need to be 'F:' ?
Disconnect the FreeAgent drive, and restart your computer.
Open "My Computer".
Does it already show an 'F:' drive?
Connect the FreeAgent drive.
Click Start
Right-mouse-click on My Computer
Click Manage
Double-click Storage
Double-click Disk Management (local)
Right-mouse-click on the G: drive
Choose Change Drive Letter, and select 'F'.
  • 4,281 Answers
Connect your harddrive to computer then when you power up the computer press F8 key then enter in safe mode.
Then it fix messup .
If still not show as G then right click on my computer icon then click on manage.
Then click on storage->removable storage or disk management there you can see your drive icon right click on it then change drive letter.
3 Suggested Answers
sunnylab85
  • 302 Answers
SOURCE: i disconnectd my hard drive from the computer and
maybe another hard drive is running on it and it might have name that one as e so you don't need to bother yourself much the moment it is working fine it is the computer that assign it to the default valves
Posted on Oct 26, 2009
lock123
  • 6831 Answers
SOURCE: computer not recognising my external hard drive????
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory disk / hdd to the computer , run the program.
On the program , select the dig deep option for accidentally deleted files or dig deeper for a formatted drive. Then select the disk you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the data was lost. Save the files to a location on the computer hard drive and not back to the disk it is recovering from as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Posted on Sep 30, 2010
Genx flash memory
Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Note: Connecting your USB external hard drive into a non-powered USB hub can cause a lack of enough power to operate the external drive. Instead, plug it directly into your computer.
Sep 29, 2013 | Electronics - Others
Usb shows 4 MB space instead of 4GB
hi, if you do not need data,go to cmd prompt format your pendrive using this cmd "format Z:"
then see your size
May 25, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Iomega eGo 1TB USB 3.0 Portable portable harddisk 500GB. while connected to PC show an error on desktop "insufficient power on USB hub port" . pls suggest
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer? 2. Try switching out your USB 3.0 cable for a different one. 3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable. Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's into the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer as they will supply more power than the USB's on the front of the computer.
Dec 20, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I have a brand new usb flashdrive and i have no idea how to put the story im writeing in it. can some one help me?
All you do is plug the drive in and save the file containing the story to it instead of your hard drive. Use file save as and look for your drive in (It should show up as a removable disk) the drop down menu.
Nov 11, 2009 | HP/ USB 1.1/ 64MB S2 Flash Drive...
I disconnectd my hard drive from the computer and let someone else plug into my cumputer with there hard drive. since i did that mu computer is caling my hard drive f instead of e. i have it pluged in the...
Don't worry, if it works. You are talking about external HD with USB connector?
The computer assigns the drive letters in 'operational order' and it doesn't matter in which order they go. In WinXP - system the drive letters 'rearrange' after reboot.
Oct 24, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My verbatim usb external hard drive quit working on only one of my computers. I tried using computer management but it doesn't recognize it there. it does show up as Toshiba in the device manager but...
The brand of your HD is Verbatim, so it should not show up as Toshiba in the Device Manager. Your computer is detecting another device.
Please do not rely on the Device Manager, you have to check the Disk Management instead. If the HD did not show up in the Disk Management, try connecting the HD into another USB ports of the problem computer. It could only be the USB ports of the problem computer is bad.
How many computers do you have? If you have 3 PCs and only one computer is having a problem, then you might need to update the USB driver of the problem computer.
Have a great day!
Sep 04, 2009 | Verbatim 160GB USB FireLite: The "drive...
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Plugged in, J drive showing on computer but no means of accessing files to the hard drive? How do I do that please?
In Windows? Try volume manager (admin. tools or via rightclicking on the drive, which you should totally have tried first.) If there are already files on it but they don't show, perhaps that computer doesn't know how to access the filesystem used initially, and you need to get the appropriate filesystem (or a compatible likeness) installed on the machine at hand.
Often USB hard drives come preformatted to FAT32, but that filesystem can't handle files over 2GB, so you almost certainly need to install NTFS or something better instead.
Jul 19, 2008 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
169 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
