Question about Acer Aspire AM5641-U5520A PC Desktop
Will not load past start up off windows swapped out memory, video card,windows operating system, hard drive
    Problem Solver:
  • 14 Answers
Two things in my experience: Now when you say will not load past start up, do you mean that you are booting off the Recovery Disk or do you mean that you have an "image of your drive"?
If you are using the Recovery Disk and it does not boot (depending on how old your system is or what it has been put thru i.e. over clocking, static electricity, or surge) I would replace the Power Supply based on what you have replace already and assuming you know what you are doing when replacing the components from above.
If you are using an "image" (exact copy) of your hard drive, does it go all the way up to the scrolling Windows Icon (assuming you are using XP) and then give you a quick burst of a blue screen and then restart? I have had this problem and come to find out it was a DLL driver in Windows that failed and I could not recover from it without doing a full rebuild of Windows and all the software. My suggestion to you if you have stuff on the original HD is to get another HD and start doing a build on the Operating System with the original removed. Then once you are finished with the build, turn it off, hook up the second hard drive, turn pc on and change the settings to boot off the second drive to recover you personal items.
This is all making assumptions based off the limited info you gave and may not apply. You can also try starting in Safe Mode if applicable. I just do not know how far your computer was able to boot up to, nor what your operating system is.
Posted on Nov 17, 2009
Testimonial: "good feed back with information I gave them"
  • 5 Answers
You'll probably have to re-install windows. I had a problem just like this. I could start loading safe-mode but then it would shut off and restart again.
INSTALL WINDOWS AGAIN...
Not enough virtual memory
Step 1:
Virtual memory is a portion of your hard drive that Windows sets aside to utilize as memory. When your RAM is over utilized, the operating system can swap pages of data to the hard drive to make more room. Swapping files, or paging, is slow, but it allows your computer to remain functional when your memory space is full. If your virtual memory space, or page file, fills up as well, you'll get an error. Fixing this issue is quick and the process is identical in safe mode or in a typical boot situation.
Change Virtual Memory Settings in Windows XP Click "Start" from the Windows desktop. Right-click "My Computer" and click "Properties." Select the "Advanced" tab and under Performance click "Settings." Select the "Advanced" tab and click "Change" under Virtual Memory. Click "System managed " to allow Windows to automatically adjust your Virtual Memory as needed. Click "Custom " to alter the memory space to your own specifications. Enter a value in MB equal to at least 1.5 times the of your computer's memory for the initial . Enter a value in MB no larger than four times your memory for maximum . Click "OK" and restart your computer for the changes to take effect.
Feb 13, 2013 | Microsoft Windows XP Professional
Tip
Performance tip: Do you have more that 1 hard drive in your Computer?
If you have 2 or more hard drives in your computer you can increase performance by moving your swap file (an old operating system trick to artificially create more memory space used by Windows, also called virtual memory or page file).
In XP(Other Windows OS's are similar):
Start Button -> Control Panel -> double click System icon.
-In the System Properties Box select Advanced.
-In the Advanced tab select settings located under Performance.
-In the new box select the Advanced tab.
-In the Advanced section select change located under Virtual Memory.
-Under Drives select the drive that has have your Operating System in and choose No paging file, click on set.
-Next select any other drive and select System Managed size, click on set. Click OK,OK,OK OK to restart.
Usually the bigger the drive the faster. The faster the better.
Windows can now access the swap file on 1 drive as it accesses data on the other instead of waiting for data from 1 drive.
This tip applies if you have 2 physical hard disk drives, not 2 drives in 1 disk.
If you are a gamer get another disk and do this trick.
on Jan 08, 2010 | Computers & Internet
Is it possible to be locked out of my hard drive
yes
if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
or
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Oct 30, 2012 | Iomega Prestige 500 GB USB 20 Hard Drive
When a user starts a computer, portions of the operating system are copied from the computer's hard disk into memory.
Windows uses a swap file (page file) as memory, and is crucial for it to operate properly. Leave alone if this is what you are referring to.
Oct 23, 2012 | Microsoft Computers & Internet
Hello, my pc is very slow and it has very few memory. If I add memory, is it going to be better ? I can't make updates for example... thank you
It depends on what you are calling memory. There are 2 things commonly called memory by users. One is the hard drive where your operating system lives and all your files are stored and the other is the "RAM" kind of like your short term memory where programs are loaded into while they are running.
If its the RAM which is low on space then it is quite possible that upgrading it so there is more would most likely help.
If it the hard drive which is low on space it maybe possible to just have a clear up of your files to free up some space.
Thanks
May 05, 2011 | Computers & Internet
Moto gp 08 wont load on my computer. ive downloaded direct x 9 and my video card meets the requirements. what should i do?
Hai, MOTO GP is a nice game, the system requirements for MOTO GP 2008 is given below
System requirements:
  • Operating system Windows XP/Windows Vista;
  • Processor Intel Pentium 4;
  • Operative memory of 512 Mb (Windows XP)/1 Gb (Windows Vista);
  • 5.5 Gb of an empty seat on a hard disk;
  • Video card with support DirectX 9.0c/Shader3.0, NVIDIA GeForce 6600 or is better, ATI Radeon X1600 or it is better;
  • Compatible with DirectX 9.0c a sound card.
Do you meet all these???If any installing Bug Try this!
Aug 05, 2009 | Video Game Consoles & Games
System will not boot into windows,, get this error message RV 370 P/N 113-A62801-106BIOS what can i do to fix the issue so it will boot? i had tried to add memory and it gave me the error,, then i removed...
I'm assuming this is coming up right when you first power up, and it appears in the top left corner... this is the video card POSTing and showing it's chip revision and BIOS release number. If this is ALL you see, and the PC never gets as far as even the Dell logo, then you have some type of hardware problem. First, try pressing F2 repeatedly and see if the PC goes into BIOS. If so, look around and see if the hard drive is recognized correctly, if the RAM is seen correctly, etc. If nothing happens after pressing F2, power down, unplug the power cord, open the case, and start unplugging devices one-by-one (this includes modems, hard drives, optical drives, floppy drive, memory sticks one at a time, etc), and reconnect the power cord and try to power up until the PC gets past where it's getting now. Basically, you swap out parts and remove 'em and through a process of elimination you determine what's causing the hangup. If you have a different video card, or can maybe borrow one from a friend, that would be my first thought.... the idea is to get the PC to continue the start up process. If it starts trying to boot after the hard drive is disconnected, then we know it's at fault, and the same would apply to any of the other devices.... just be sure to power down and unplug the power cord in between each device rotation/removal...
Jun 26, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computer OS won't load
yes, I think your memory is the problem, it's crash
it is hardware problem, not system
May 31, 2009 | Dell Dimension 9100 PC Desktop
Blue Screen of Death
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Dec 01, 2008 | Kobian MP545 MP3 Player
What i have as agp or pci and whats the best graphics card i can get without getting a new pc
An AGP video card would provide a better video performance than a PCI video card.
Jun 06, 2008 | Foxconn (865G7MC-ES) Motherboard
Acer Aspire AM5641-U5520A PC Desktop Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
