Question about HP IQ504 TouchSmart
I have a hp computer. and a windows vista but the speakers of my computer don't sound i can only listen through the earphones.
    Champion:
  • 206 Answers
Go to control panel, sound devices, and look at the default sound device.
Posted on Nov 17, 2009
HOW DO I GET SOUND ???
Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
Amazon com AmazonBasics USB Powered Computer Speakers A100 Computers... Amazon com Joylive White 3 5mm In Ear Earpiece Earbud Headphone Earphone...
Jun 27, 2016 | HP Pavilion F1903 19" LCD Monitor
Not work the spekears
Your speakers probably stopped working if you can use your earphone to listen. The sound card/driver is working properly if you got sound. Use the DirectX Diagnostic Tool to diagnose the problem. click on the Start button, type dxdiag in the Search box and then press enter. There's a tab for Sound, if there's no indication that the hardware/driver is not operable and you can perform the sound test, and get a passing result for sound then your speakers are definitely out.
Nov 09, 2013 | Gateway ZX6961 All-in-One Computer - Intel...
I have left and right handed dell a215 speakers but don't know how to connect them
you might need a usb to speaker adapterhttp://www.ebay.com.au/itm/USB-2-0-MIC-Speaker-5-1-Audio-Sound-Card-Adapter-/120645945426?pt=AU_Laptop_Accessories&hash=item1c170f0852
hope this help
Jul 21, 2012 | Dell Inspiron 1720 Notebook, Windows Vista...
I have a new windows 7 laptop that I am trying to use my old yamaha MS55D speakers with, but it says there are no drivers. Please can you suggest where I might get the driver or what else I can try
PROBLEM SOLVED: YAMAHA YST-MS55D allows both USB and audio jack. On the back of your subwoof - find the USB ONLY area. Disconnect the USB cable from your sub and computer. Then use the other audio cable to link ur sub with the audio jack on your computer (the earphone plug). You don't need to change the other connections. Your Speaker will then function like an earphone, which means no drivers needed as it is not a USB device anymore.
May 16, 2011 | Yamaha YST-MS55D Computer Speakers
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
if you go to the bios (restart computer and press del to go to setup) you should be able to look around and find the option for internal speaker. Set that option to disable and do not change anything else unless you know your way around. Save it and restart afterwards and it should disable the internal speakers.
May 06, 2011 | HP Compaq Evo d530 PC Desktop
I using conexant hd idio inputand output device. I record my sound but after play back i cannot heard sound
If you cannot hear the sound you have recorded. Make sure that the sound you record generates the visual pattern. This confirms that at least your microphone is working.
  • In any of the upper case your audio driver must be install and your audio hardware must be in working order. You can check this in Windows Device Manager. To go to device manager you right click "My Computer" in XP and In Windows Vista and Windows 7 its "Computer. After right clicking it select Manage and on the left pane select the Device Manager and you will see the list of devices and their installed drivers. Make sure all the audio devices and there drivers are not showing any errors.
  • Make sure that you speakers are not mute. If you take a look at the bottom right corner of your computer screen you will see a speaker icon.make sure there is no "X" or any other RED signs on them which represents mute states.
  • Similarly check other related settings. Go control panel after going to the start menu and look for the "Sound" icon and make sure there is not anything suspicious.
  • If all the above is fine and okay than look for any problems in your speakers that are open or if you are wearing them as Headphones or earphones and try to replace them to test them. Maybe the sound is coming but the speakers might be faulty make sure you increase the volume of the speakers when you hear any recordings.
  • Make sure the speakers are okay by listening to music or movie that you might get free from internet or in Disk collections. This is the way you can easily detect the problem.
  • If you can hear sound from music and movies than your microphone hardware might be faulty.
Good Luck!
Jan 14, 2011 | HP Pavilion Tx1110us Notebook
I have hp dv 1000 laptop and i install windows vista os and i install all driver from hp.com but i cann't listen sound from my notbook,sound is coming in headphone but not in notebook speaker what will i...
You have to go to hp website www.hp.com/#support go to start control panal and click on sound make sure that it is not muted ,if not remove and reboot computer and vista should reinstall sound drivers
May 26, 2010 | HP Pavilion dv1000 Notebook
Earphones wont work on dell computer/vistas have to restart computer to go from sound to earphones . how do i fix this
first check you connected the earphone properly. earphone has two wire. connect earphone green wire where you connect the speaker.
Jan 22, 2010 | Dell Inspiron 531s Desktop Computer
Laptop speakers working, ear phones not working
Check when you plug in the headphone the laptop speakers get off or not also see the audio configuration under control panel sound that you choose digital sound or its having channels system like 5.1 or 7.1 channels you have to configure it to headphone
Jun 29, 2008 | HP Pavilion dv6000z Notebook
HP IQ504 TouchSmart Logo
35 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
