Question about Mitsubishi WS-55613 55" Rear Projection HDTV
How do i clean the screen inside of ws-55613 55"
    President:
  • 1,284 Answers
You will have to take the lower back off of the TV with the power off of course for safety. Only use like a Swiffer to reach in there to clean if the only issue is spider webs. If you use anything else you will end up scratching the screen assembly and they usually run between 300-500 for the assembly. Please take a few minutes to rate my answer...Thank you. :)
Posted on Nov 17, 2009
How to clean sreen and lens
In order to clean the Picture Tube Lenses you will have to remove the front screen. As for cleaning the screen use only correct screen cleaning solution or just replace the front screen if it is streak to badly.
Oct 08, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55807, screen removal / cleaning
Hi, thank you for visit fixya.
Pull out the speaker cover ( slow toward your self).
You will see screws in the middle , take it out ( maybe is 4 o 6 screws), be careful with any wires connect to panel control. Disconnect any connector to panel control. Pull toward your self , slow and slide up . Use a fine brush for best result, use glass cleaner liquid.
Any question, I will be here.
If you need additional help, please send me a picture front tv and I will show the right process.
Thank you
Dec 05, 2009 | Mitsubishi WS-55807 TV
No picture Just blue lines on the screen
Take off the top of the tv ( remove bolts from back and lift the top off) Under neath you will see three bulbs they are probably out or dirty. While you are at it clean the inside of your screen after replacing the bulbs. Go on website for Mitsubishi and they will tell you what bulbs you need
Jul 09, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Removing and cleaning the screen on a 65" rear projection tv
You can remove the screen, take the speaker cover off in the front you sould be able to see the screws that hold the screen on the bottom remove the screws and unplug the wire the goes to the screen fron the tv, you need two people one on each side just pop each side up about an inch and pull it off,
Jan 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65713
Yes Rhonda, first you need to do a self test to show what is going on inside set. You can search threads on test or goto ctechnicians.com. This will put you in the ball park of what is going on.
Dec 29, 2007 | Mitsubishi WS-65713 65" Rear Projection...
Remove screen?
I watched the set up guys install the screen on my WS-73907. They poped it in with great difficulty which made me think it would be difficult to get back out.
Sep 07, 2006 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-55517
the outside screen is called a linticular lens and the inside one is the fresnele lens. They both should come out together from the front as the trim on this set if im not mistaking pulls or slides off then theres mounting plates holding it on. Becarefull and dont try to clean the mirror as the coatings on the outside of the mirror. Also be very carefull not to touch any componets as theres extremly hi voltage in these sets even with them unplugged. Good Luck
Jun 14, 2006 | Mitsubishi WS-55807 TV
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
