Question about Texas Instruments TI-30XA Calculator
What size replacement battery for TI-30Xa calculator
  • 11,896 Answers
The battery is an EPX76
Posted on Nov 17, 2009
SOURCE: cant get M2 off of my TI-30XA calculator
Press 0 STO 2 to clear your memory 2 (M2). to clear M1 and M3 press 0 STO 1 or 0 STO 3
Posted on May 27, 2008
  • 7993 Answers
SOURCE: how do I reset the calculator after installing new
[OFF] ON/C] clears display, errors, all pending operations, constant calculations K, and STAT, but not M1, M2,and M3. Sets DEG angle units, floating-decimal format.
To clear memory M1 : Store 0 in 1
0 [STO] 1 clears M1
0[STO] 2 clears m2
0 [STO] 3 clears M2
Posted on Feb 03, 2010
  • 102366 Answers
SOURCE: How do i replace my texas instrument TI-30xa
Use a small Phillips screwdriver to remove the back of the case.
Posted on Feb 05, 2010
  • 7993 Answers
SOURCE: reset calculator ti-30xa after replacing the
Posted on Feb 20, 2010
SOURCE: Texas Instruments TI-30XA Non-Solar battery replacement
My batteries were fine but the LED display was jammed so it needed to be reset. This can be done either by removing and reinserting the batteries, or by shorting out the reset board. In either case, the back will need to be removed. After I removed the 6 small Phillips screws, I used a small flathead screwdriver (jeweler's size) to pop the two tabs apart on the top of the calculator. I then slid the edge of the screwdriver along one side of the calculator and then the other. The back came off rather easily in this manner.
Posted on Dec 18, 2010
I have a TI -30XA calculator. Need a battery for it. What is the number of the battery? Thanks, Ed
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include: Duracell® D357 and Eveready® 357
Sep 23, 2010 | Texas Instruments TI-30XA Calculator
What size of batteries for ti-30ax
(A76) is the type of battery fot your TI-30Xa. The calculator requires 2.
Mar 11, 2010 | Texas Instruments TI-30XA Calculator
I need a battery
The battery is EPX76 (it uses 2)
This page describes how to get into the calculator to replace them;
http://tutorialninjas.net/2007/05/04/replacing-the-battery-in-your-ti-30xa-calculator/
The batteries can cost as much as $5 each, a new calculator can be as low as $10
Good Luck!
Nov 08, 2009 | Texas Instruments TI-30XA Calculator
What is the battery size to replace for the texas ti-30xa, please
I do not own this calculator and the manual does not specify the battery model number. However on this site, it is identified as EXP76. There must be many equivalent batteries.
The site shows you in pictures the whole procedure for replacing the battery.
Hope it helps.
Nov 04, 2009 | Texas Instruments TI-30XA Calculator
REPLACE BATTERY 30XA
Good Luck!
Aug 30, 2009 | Texas Instruments TI-30XA Calculator
Need to replace battery on TI-30XA. What is No.
It's cheaper to buy the new one. On amazon they are pretty cheap. take a look Amazon com TI 30X. cheers
Aug 24, 2009 | Texas Instruments TI-30XA Calculator
My texas instruments ti-30Xa doesn't turn on!
It is battery powered. You simply need to replace the battery. This website may help you.
http://www.calculatorsource.com/ti-30xa.html
Aug 03, 2009 | Texas Instruments TI-30XA Calculator
Battery installation for TI-30Xa
Good Luck!
Nov 11, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
2,325 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
