Question about Olympus FE-230 Digital Camera
I can't get the flash to come on on any setting
I can't get the flash to come on any setting what is wrong. I think I have messed up all the settings trying to find the solutions. I need the correct settings for set up . I have lost my instruction book and need help. I am going on out of town tomorrow and need my camera to take pictures.
    Brigadier General:
  • 11,967 Answers
Find the button on the back with the lightning bolt on it. Press that button and watch the screen for either a lightning bolt or one with the letter "a" beside it. If that doesn't work, try this...go into the menu and scroll to "reset"...follow the on-screen instructions.
Posted on Nov 18, 2009
Tension wrong on sewing genie , bottom stich just makes a huge mess
Begin with tension setting in the middle of it's range. If the stitching improves tighten until it's perfect. Ps "Sewing Genie" isn't a real sewing machine... apologies.
Jul 19, 2014 | As Seen On TV Sewing Genie Mechanical...
Onkyo sr 605 set up problem
once you finish the set up. u must disconnect the microphone cord.
it will be red in colour mostly.
Dec 27, 2007 | Onkyo TX-SR605 Receiver
Flash problem
The only things I can think of that could go wring with this camera are:
Batteries are not fully loaded or not new. When not having enough power the flash can't be charged enough, so it won\t fire.
the second thing could be you dailed in the wrong setting. The setting is for full sun light and yu are taking pictures inside. (not likely.)
The film package you are using is out of date or was stored wrong. (not likely eighther)
The flash (camera) is defect
Nov 11, 2013 | FUJIFILM instax mini 7 Digital Camera
Pentax optio e50
Try messing around with the settings so different pictures are achieved. is there flash? (I personally never use flash in any pictures I take). Just setting the ISO to manual doesn't do anything, There are specific values, setting it to a lower may help, there's also white balance and exposure you should take in account. The camera also isn't that great of a camera and I'd suggest getting a new one.
May 27, 2013 | Cameras
How do I turn on the flash? I tried to buy a really simple camera and there's just too much 'stuff' on it. everything seems to be ok, just can't figure out how to make the flash work. ...
Easy. When the camera is in normal shooting mode, press the up button (marked with the symbol of a lightning bolt) until the symbol of a crossed out lightning bolt near the top left of the screen turns to an uncrossed lightning bolt symbol. that's it.
extra tips-
  • if you keep pressing the up button until the lightning bolt symbol has a letter A next to it, the camera will fire the flash only when it thinks it is necessary. this will keep your flash from firing in bright light and therefore save battery charge.
  • remember when you flipped through your math textbook in the first grade and it had "too much stuff on it"? you think its too much because you aren't used to it. don't be afraid to mess with the settings in order to learn how to use your camera best; you can never permanently damage a camera in changing its settings. the worst that could ever happen is losing all the photos in memory. if anything else goes wrong, you can always return the settings to what they were when you bought the cam in a few button presses (refer to the manual).
good luck and happy shooting!
Sep 04, 2011 | Vivitar ViviCam 8018 Digital Camera
I have an edelbrock 1500 carb. in a 350 chevy. I want to adjust it because It hesitated when you opened up the four barrel. I think someone already tried to adjust it. I don't know how many turns out they...
The turns out is an idle miixture adjustment. I hope that your camshaft is set up for your new carb.You may need to mess with your ignion timing. Those engineers that set things up are usually not wrong.
Apr 28, 2011 | Chevrolet Camaro Cars & Trucks
Airbag light flashing 4-2code dont know what it means or whats wrong, do you or anyone know what it means?
Flash Code 42 is for the driver's airbag circuit. Most common problem is with the clock spring or another term is the sliding contact. This is not something you should mess with if you dont know what your doing. As testing wrong can set off the airbag. If you choose to take it apart look for a bad connection, maybe just a wire popped off behind the bag but again caution as these are very dangerous 200 mph deployment! It can kill.
May 15, 2010 | 2003 Ford Explorer
Problem on start up
there should be a cmos reset jumper on the motherboard somewhere close to the bios chip. Given you didn't mention the actual model and brand of mobo i cannot be certain. Also you can remove the little watch battery for a few minutes and it too should reset the bios.
Aug 19, 2009 | Computers & Internet
Unit does not make outgoing calls nor receive incoming calls. Display seems OK but tiny vertical bar top RH corner doesn't flash 9should it?). Unit is fully charged. Trying to call IT from cellphone gives...
Friend i think u r cell phone setting are mess up
so please go to ur cell phone setting and go to security and then try to find restriction menu and then turn of it if u find it then
u got
three options like
outgoing call
incoming call
messege
phone book restriction
so set it unselect
Jul 22, 2009 | Cell Phones
I HAVE A NIKON D40X.I CANNOT GET THE BUILT IN FLASH TO WORK.IT IS IN AUTO MODE AND FLASH IS TURNED ON.IF I ATATCH AN EXTERIA FLASH IT FIRES EVERY TIME.I HAVE TRIED IT ON ALL THE OTHER MODES,IT DID FIRE...
In Auto mode the flash will only fire when the camera thinks it needs it.
Only in the PASM modes do you get to decide whether to use the flash or not.
Aug 27, 2008 | Nikon Cameras
Olympus FE-230 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
