Question about Dryers
I have an LG gas dryer, 2 years old. I have been moving. does not heat up now. what could be the problem?
  • 10,515 Answers
What you are going to need to do is get yourself a test meter to test the heating components...Could be a bad heating element....Thermal fuse.....igniter.
You could download the Service Manual from :-
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=29
If you have a different machine, let me know the Model so that i could provide you with the Service Manual.You need to be good at electronics to fix this.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 17, 2009
Our dryer is a little over a year old. Everything seems like its running ok except for the fact that there is absolutely no heat. Any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | LG DLE2512W Electric Dryer
Lg dryer stop heating after i stuffed it witha blanket front load gas dryer Tromm 3 years old. I completely cleaned it, but still won't heat I can fix it with your help
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | LG DLE2514 Electric Dryer
I have an lg electric dryer that I've had for 2 years now. It seems that it's taking a long time to dry anything. I have to run everything through 2 times. Is this normal?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
May 20, 2010 | Dryers
It will not heat up 2 and a half year old gas dryer works perfectly just no heat
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
May 14, 2010 | LG DLG6952 Gas Dryer
It will not heat up, 2 and a half year old gas dryer works perfectly just no heat
LG gas dryers have a manually resettable high limit thermostat on the burner assembly. It is near the igniter and is about the size of a dime with two wires attached to it. There is a pin in the center of it which can be pushed in to reset the thermo. It usually trips due to a poor vent (poor air flow, causes excessive heat build up at the burner). Eliminate any flexible ducting, make vent as short and straight as possible, and clean out lint in vent pipe and at the exterior vent hood. Make sure the exterior vent hood has a full 4 inch distance the flap can move (not the two in low profile type) or is one of the multi louver types. You will have to take the front of the dryer off to get to the resettable thermo. (make sure the dryer is unplugged when the front is off)
Mar 23, 2010 | LG DLG6952 Gas Dryer
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Whirlpool Gas Dryer
you will need to let it cycle a few times in order to bleed the air out of the gas line to the valve it should start up after a few attempts let me know
Jun 09, 2008 | Whirlpool LER5636P Electric Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
14 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
