Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
My filter light came on and I replaced the filter below the unit and the light remains on, is there another filter?
    Problem Solver:
  • 23 Answers
Disconnect power supply for couple of minutes.
Posted on Nov 17, 2009
I have a Maytag window air conditioner unit (model M6T12FSA). The 'check filter' light came on and after I cleaned the filter, the 'check filter' light remains on even after a few hours of...
Turn the unit OFF & Unplug it. Remove the filter and reinstall it, being sure that it's installed properly. Particularly, which way the plastic filter frame is facing when installed.
Plug the unit back in and turn it ON. Hopefully, the electronics now will accept the filter being properly in place.
Hope this helps and thanks for choosing FixYa.
Jul 25, 2011 | Maytag Heating & Cooling
Filter light beeping n flashing on a rinnai 556 ftr
Tara, generally that means the filter needs to be removed and cleaned. However, the electric part of the unit must be turned OFF and unplugged, before the filter is removed for cleaning, The unit should remain that way, until the filter is replaced. Then plug the unit back in, turn the Master ON/OFF Switch to ON and the unit will revert back to its original factory settings. From there, you can set it however you like.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 03, 2011 | Heating & Cooling
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
Replace air filter warning light to reset?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 30, 2010 | Filter Queen Defender Air Purifier
How do you reset the red light on the defender when you put in a new filter? My light has never went out and I think it is supose to .
It won't go out by itself.
Sep 16, 2010 | Filter Queen Defender Air Purifier
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
Reset the water filter indicater light
hold light and lock buttons until lamp blinking release and lamp turns off no it is reset.
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
    70 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    mike cooper
    Todd Arndt
    Todd Arndt
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
