Question about RCA HDLP50W151 50" Rear Projection HDTV
My picture keeps changing colors and images are shifting around on the screen. Example is say there is a person on theTV picture, well it will glitch and move part of his face to to oppostie side of the screen and the color will change and pulsate. This doesn't always happen the TV will work fine for a while this problem comes and goes.
  • robbyelam24 Dec 04, 2009
    I fixed the The problem and it cost only 5 dollars.
    I took the back of the TV off and used a electronic air spray can and dusted off everything from the fan, the boards and the lamp, then I double checked that every wire was pushed all the way in, and after that I put the TV back together and It looks better that it has in 3 years.
    Everyone I talked to told be it was my color wheel or my light engine but really it was just a lot of built up dust!
    President:
  • 1,284 Answers
Do you hear any strange noises when the color is shifting? If so then the possibility is the color wheel is failing. The color wheel failing after a few years is not so uncommon. The unfortunate part is you would need RCA part number 212184 for the color wheel and it is no longer available. The complete light engine is the only thing that appears to be available and that part number is 261589. I would have a technician look at the TV to verify my findings. Please take a few moments to rate my answer. Thank you...
Posted on Nov 17, 2009
Testimonial: "Thank you"
  • Don
    Don Nov 18, 2009
    Possibly a signal issue. Does this happen while watching DVD's or anything else?
How do i set laptop background image on my compaq 615?
This can be found in the Help and Support section of Windows on your laptop.
To change the desktop background
  1. ?id=microsoft.windows.resources.shellexecutetopiciconRight click on your desktop-Select personalize. This will open a window that asks you to select your desktop background
  2. Click the picture or color that you want to use for your desktop background.
    If the picture you want to use isn't in the list of desktop background pictures, click an item in the Picture location list to see other categories, or click Browse to search for the picture on your computer. When you find the picture that you want, double-click it. It will become your desktop background.
    getcontent.aspx?assetid=8456a207-d4c8-401d-8729-c5dda3f0e72c&documentset=en-us&prod=win700&market=usLook for pictures in other locations on your computer
  3. Under Picture position, click the arrow and choose whether to crop the picture to fill the screen, fit the picture to the screen, stretch the picture to fit the screen, tile the picture, or center the picture on the screen, and then click Save changes.
Note
  • If you choose to have a fitted or centered picture as your desktop background, you can also frame your picture with a color background. Under Picture position, click Fit or Center. Click Change background color, click a color, and then click OK.
Tip
  • To make any picture stored on your computer (or a picture you are currently viewing) your desktop background, right-click the picture, and then click Set as Desktop Background.
getcontent.aspx?assetid=7abb27d7-2989-4144-81e3-0a51f703885d&documentset=en-us&prod=win700&market=usThe Set as Desktop Background option
Apr 24, 2011 | Computers & Internet
Colors are separated on the display. Each color is shifted to the right from the preceeding color. Looks like a bad 3d pic w/o the glasses
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 14, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
No picture
The main problem is from theTV menu.I would recommend you press,menu,then settings,then display settings,and last tv screen. After, you'll get options on how you want to make your screen look like.Example:wide screen, Automatic, etc.
May 31, 2010 | GE 32GT740 32" TV
There is a wave in the picture only in the upper left hand 1/4 or the screen. The rest of the screen is sharp. You get the colors separated and thus double image.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 23, 2010 | Hitachi 46F500 46" Rear Projection...
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Cloud like image around edges of screen
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 04, 2009 | Philips 60PP9352 60" Rear Projection...
Multipoints will not align
  • Screen looks 3D
Jan 19, 2009 | Philips 51PP9303H Rear Projection...
ALOT OF BLUE ON THE SCREEN!!
  • Screen looks 3D
Aug 20, 2008 | Philips 60PP9200D Television
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
RCA HDLP50W151 50" Rear Projection HDTV Logo
463 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
