Question about Craftsman Air Tools & Compressors
Power switch not working properly it will turn on for about 5 seconds the turn off no pressure build up
    Problem Solver:
  • 7 Answers
I know this sounds too easy, but it sounds like a faulty power switch. Being a Craftsman, parts are no problem. I'd replace the switch.
Cabinetman54
Posted on Nov 19, 2009
The fuel pump stay runnning for awhile before the car starts
Don't really understand your question but the fuel pump is suppose to run when you turn the key on. Runs for a few seconds to build to the proper pressure and then shuts off until the pressure is needed again. In most cars it will cycle every time you turn on the ignition switch.
Mar 02, 2015 | 1997 MERCURY COUGAR 71-1770 TurboWire -...
Works for 5 seconds
This sounds like a power problem .. It may have a switch mode power supply... turn it on and listen if you can hear a faint clicking sound ... maybe the switchmode power supply is not switching on properly.
Feb 28, 2014 | Vizio Vht210 2.1 Home Theater Soundbar...
98 explorer air conditioning compressor only engages for a few seconds, what do I check first
It sound like it has a low charge but if you know that it is fully charged you may have a bad low pressure switch . Also make sure that the condensor fan is working properly and the system is not building to much pressure.
Aug 06, 2012 | 1998 Ford Explorer
Starts then dies & won't restart
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
report back
Aug 22, 2011 | 2005 Ford Expedition
Fuel Pump problems. Diagnostics shows a pressure loss.
pressure loss is either a bad fuel pressure regulator on the fuel rail where the injectors are, or a bad check valve in the fuel pump in the tank. usually the latter.
A quick test is to turn the key to on and measure pressure. Should be 40 psi. Pump will hum for 5 seconds and shut off if engine is not running. (Safety step).
Pressure should drop very little for 5 minutes.
You can cycle the key off for 15 seconds or until you hear the relay click off. Then turn key back on to start pump for 5 seconds again to build pressure. This will help get it started for the day as it builds pressure that bled down over night.
Please rate, thanks.
May 25, 2011 | Ford Ranger Cars & Trucks
While using my compressor (Husky WL65004AJ) the compressor used to go on when the pressure dropped down to about 85-90 psi. Now it doesn't. The only way that I can build up the pressure again is to shut...
Hi and welcome to FixYa, I am Kelly. I tried several places too cross this model number: WL65004AJ without success. The pressure switch has 2 settings one for HIGH cutoff and one for LOW cycle on. 1/2 of your pressure switch is not functioning properly. With the proper model number I could find a source for the pressure switch for you. There are a couple of different types of presure switchs, One is a stand alone switch on the air plumbing with no external controls (under $30.00) and one is an all-in-one switch that has the on off switch and air lines connected to it that runs around $86.00. You need a pressure switch.... it is just a matter of finding out which one fits your model and replacing it.
Thanks for choosing FixYa,
Kelly
Apr 15, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Will only build pressure to 100psi of rated 140psi
Chances are that the pressure switch, were you turn the compressor on and off, is bad. When they go out, they no longer build pressure to the regulated level you are looking for. If you haven't already, try turning up the regulator, if no more than 100psi build's, then it's a sure thing, bad pressure switch.
Oct 11, 2010 | Makita MAC5200 Electric Powered Air...
Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Apr 05, 2010 | Air Tools & Compressors
The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Sep 19, 2009 | Karcher 1750 psi Electric Pressure Washer
Air Tools & Compressors Logo
56 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
