Question about Black & Decker Leaf Hog Blower Bv4000
My blower is electric, and it also vacuums. I accidentally vacuumed up a plastic trash bag that was under a pile of leaves. It made a terrible sound, smelled hot, and won't come back on. I've removed all the pieces of plastic bag from it, and replaced the cord, but it still won't come back on. A friend looked at it, and said the motor "sparks". I can't find anyone in Lexington, KY who will work on this. Can you help? I have piles of leaves!!
    President:
  • 1,515 Answers
Hi, It sounds to me that when the plastic caused the motor to overheat, that it actually took out the windings to the electric motor. Most motors have an internal overload to prevent this from happening, but it sounds like it has open windings or shorted to ground. If you or you're friend can get together, and if you have an electrical voltage meter, you can check the motor alone to see if it will run. If you can disconnect all moving mechanical parts and isolate just the motor with no load on it, you can use the cord that is attached to the unit and make sure you are getting 120 volts directly to the motor to see if it will run, or use a different cord and bypass the switch and anything that may be between power and the motor, wire the cord to the motor and see if it runs. If not, after applying 120 volts to it, the motor is gone and you will have to replace it. It sounds to me like you are mech. inclined and would be able to handle this with no problem.You might compare the price of a new motor to a new unit to decide if the cost is worth it, and have the motor shipped overnight. If the motor does run under no load and you have an amp probe, the data plate will tell you what the R.L A. should be and the F.L.amps also. I doubt if it will ever run again, and that's to bad the internal did not open and save this motor. But check the motor, you replaced the cord, just bypass the on/off switch and put power directly to motor to solve knowing the condition, and go from there. I hope this has helped you out.
Sincerely, Shastalaker7
PS If it does run after bypassing the switch, look at replacing the switch. You can still use it without one until you get one. Lets hope its that and not the motor. Good Luck
Posted on Nov 17, 2009
  • 388 Answers
First off, what make and model is your blower? Second, all electric motors "spark"; if you don't believe me, take your electric drill and pull the trigger and look in the case while it's turning...you will see "sparks". Now, what KIND of sparks is your friend seeing? Third, what do you mean, when you say you "replaced the cord"?
Without answers to the questions I have posed, there is little chance of being able to actually repair the blower/vac. However, I can give you some generic electrical motor advice. You said the bag was picked up and the blower/vac made a noise and smelled hot...the smell most likely was electrical in nature and that means the motor may be fried.
When you try to turn it on, do you hear something like a buzzing or humming noise coming from the blower? If you are hearing that noise, the motor is fried and unrepairable (it's not cost-effective to rebuild or replace the motor).
If you don't hear any noise at all, it may be because of a fuse, fusible link or internal breaker. Electric blowers usually have a fuse, fusible link or internal breaker of some sort between the plug, switch and motor housing. If that is the case, it should be a simple matter of replacing or resetting the link, but like I said earlier, I need to know the make and model number to say for certain if there is a fuse, fusible link or internal breaker.
I accidentally vacuumed up a small plastic bag. Now I have no suction. No plastic bag is visible in the canister or the hose. What do I do?
Take my word for it, the plastic bag and / or its' remains is / are somewhere in the hose. Visibility of clear plastic in the dark environs of the interior of the hose is extremely limited if possible at all. Some hoses are corrugated on the inside especially if so on the outside. Without specificity as to brand my best first shot would be to attach the hose to the vacuum cleaners exhaust and try to blow the plastic back out the hose. The exhaust is the port from which the air comes out when everything's working as it should. Even before that, disconnect the hose from the canister, turn on the machine and see if there's any suction at the port where the hose attaches. No suction at the port eliminates the hose as the problem. If your machine will run without a bag, take the bag out and momentarily turn the machine on. Suction with no bag = bad bag. Still no suction= a trip to the vacuum service / sales store
Nov 02, 2017 | Vacuums
Where i sit vacuum leaves pile of dirt
Jolene,
I would suggest checking any filters that might be in your vacuum and make sure the bag or whatever collects the dirt in your vacuum has been emptied. It sounds like you have a clog somewhere that is keeping the dirt from going where it should. If you have hoses and wands with your vacuum, check those for obstructions. Hope this helps!
Jul 03, 2015 | Vacuums
How long does it take for frontline to work
It takes about 24 hours to kill the fleas. In the meantime, vacuum your house really well and when you're done, throw the bag in a plastic bag and put it outside into the trash can. If you have one of those vacuums that have a wind tunnel thing, empty it into a plastic bag, outside, and leave it out there in the trash can until trash day. Fleas can live about 30 days without eating. You may need to spray your yard to kill any fleas out there, and also spray your house. If you have a bird, be very careful and maybe let the bird stay with a friend for a few days. Good luck. This is a very bad year for fleas.
Oct 07, 2014 | Merial 004fltsp-23-44 Frontline Plus Flea...
Need to clear blower in 8850 model vacuum
Unless you have removed the plastic guard under the motor filter it is impossible for the toy to have lodged in the fan. The toy would have to go through the bag, through the motor filter and through the guard before it could reach the fan.
Mar 04, 2014 | Riccar 8955 Upright Vacuum
How to attach vacuum mode on blowers
Brian, the black cover comes off/folds down and the large plastic tube mounts under this cover. The normal blower tube comes off and the elbow that the bag hooks to goes in its place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
Where do I attach the bag for the vacuum?
When the machine is converted to vacuum mode, the collection bag will go on the machine where the blower tube (long part) is connected for blowing mode.
Mar 19, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Can I run this without the bag attachments if I am only blowing the leafs to a pile?
You can use it for blowing without the bag. You should have the bag in place for vacuuming and have the zipper closed.
Oct 16, 2010 | Worx Electric Blowervac With Carrying Case...
Lid won't close. I started to put in a new bag but accidentally took out the plastic insert section the bag should attach to--so when I closed the lid over that, I must have pushed a little too hard. Now...
Your supposed to take out the plastic part that holds the bag but the way this unit is designed the lid will not close unless everything is inthere correctly so just make sure evverything in inserted correctly and keep trying! DO you still have your bag holder?
Jul 18, 2009 | Electrolux Harmony Canister Vacuum -...
Leaf Blowers Features
* CFM (cubic feet per minute) is the measure of vacuuming power. Ratings fall in the 350 to 600 CFM range. * MPH (miles per hour) measures blowing. Leaf blowers perform at levels from 125 - 210 mph. * Decibels (dB) is the noise rating. * Reduction ratio on mulching blower/vacuums calculates how many units of leaves the mulcher can produce. A 10:1 ratio means that 10 bags of leaves can be reduced to 1 bag of mulch. * Speed settings allow better control when blowing or vacuuming. * Attachments, such as extension tubes for cleaning gutters, are available separately.
Aug 27, 2008 | Craftsman Blower Attachment
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Black & Decker Leaf Hog Blower Bv4000 Logo
444 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
