Question about RCA P42WHD33 42 in. Plasma HDTV
RCA P42WHD33 42 in. No picture and a loud buzz comimg from inside the cabinet not from speakers.
    Scholar:
  • 63 Answers
The buzz is very likely from the power supply. This may be occurring due to a shorted component else where in the units circuitry. The supply has a protect mode when it is over loaded and its operating frequency drops into the audible range when in this state. You will need a technician to diagnose this and give you an estimate, unless it is under warranty or a service plan.
Posted on Nov 17, 2009
Testimonial: "Very helpfull"
Why is there is a loud buzzing noise comimg from the top of evaparator
Check for loose mounting bolts on the evap coils, check to see the rubber grommets are in their proper place.
Aug 17, 2014 | Dometic Rooftop RV Air Conditioner
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Rca l26wd14 buzzing
Hi!
I have seen this before in a lcd tv I worked on! My problem was some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). But also check the signal board (rca s-video etc... inputs). My thought in this was a bad cap was producing a harmonic, causing the speakers to squeal! Good luck, I hope this is helpful!
Mar 02, 2009 | Samsung LN32A540 32 in. LCD HDTV
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
RCA P42WHD33 42 in. Plasma HDTV Logo
415 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
