Question about Microsoft Office Professional 2007 Full Version for PC
Macros office 2007 macros I can't find how to use them
    Sergeant:
  • 206 Answers
Try this. Macro tips from Word MVPs.
Posted on Nov 17, 2009
Testimonial: "worth a try,thank you"
Hi Team, I have created macro in MS Excel2007 and after executing macro output file will be created MS Excel2003. Once MS Excel2003 file closed and reopen all the formating lost. How can overcome this...
It is unlikely that you can really overcome this as Office 2003 and Office 2007 have completely different file formats and structures. But if you output it to an Office 2007 file and use the Microsoft converter for Office 2003 than it may work. The converter can be found here
Jun 22, 2011 | Microsoft Excel 2007 0882224152648 Full...
I am using microsoft excel 2007, the code is not running, the macro was disabled.. How to enable the macro...?
From the excel help file
  1. Click the Microsoft Office Button o12filemenubutton_za10077102.gif, and then click Excel Options.
  2. Click Trust Center, click Trust Center Settings, and then click Macro Settings.
  3. Click the options that you want:
    • Disable all macros without notification Click this option if you don't trust macros. All macros in documents and security alerts about macros are disabled. If there are documents with unsigned macros that you do trust, you can put those documents into a trusted location. Documents in trusted locations are allowed to run without being checked by the Trust Center security system.
    • Disable all macros with notification This is the default setting. Click this option if you want macros to be disabled, but you want to get security alerts if there are macros present. This way, you can choose when to enable those macros on a case by case basis.
    • Disable all macros except digitally signed macros This setting is the same as the Disable all macros with notification option, except that if the macro is digitally signed by a trusted publisher, the macro can run if you have already trusted the publisher. If you have not trusted the publisher, you are notified. That way, you can choose to enable those signed macros or trust the publisher. All unsigned macros are disabled without notification.
    • Enable all macros (not recommended, potentially dangerous code can run) Click this option to allow all macros to run. This setting makes your computer vulnerable to potentially malicious code and is not recommended.
    • Trust access to the VBA project object model This setting is for developers and is used to deliberately lock out or allow programmatic access to the VBA object model from any Automation client. In other words, it provides a security option for code that is written to automate an Office program and programmatically manipulate the Microsoft Visual Basic for Applications (VBA) environment and object model. This is a per user and per application setting, and denies access by default. This security option makes it more difficult for unauthorized programs to build "self-replicating" code that can harm end-user systems. For any Automation client to be able to access the VBA object model programmatically, the user running the code must explicitly grant access. To turn on access, select the check box.
Jun 21, 2011 | Microsoft Office Professional 2007 Full...
I m using windows 7 and having a problem of macron by pasting some matters from m s word 2007 to the same m s word 2007. can you tell me that how can i paste that matter on my desired m s...
you can change the macro security level in Word 2007. To do so, simply follow these steps:
1. Click the Office Button
2. Select Word Options
3. Open the Trust Center
4. Select the macro security level you'd like
5. Click OK twice
Although you may want to allow some macros to run, select the security level carefully. I strongly caution against allowing all macros to run.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
How to create macro button in microsoft excel 2007 because
well follow the steps below to get your job done:
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
  1. Click the Microsoft Office Button, and then click Excel Options.
  2. Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
  1. In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
    In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
  2. Select any cell in the worksheet.
  3. In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
    In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
  4. In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
good luck ...:-)
Apr 08, 2010 | Microsoft Office Excel 2007
Help: excel 2007 suddenly hangs when working with macros
check the physical memory,and also if the excel file size,if the file size is so big then it gets hang
thanks
Feb 17, 2010 | Computers & Internet
How do I copy macros in word 2007 from one
1. Just search for 'Normal.dot' file in your old Computer containing you macro. Copy it..
2. Now search for the same file in your new Computer and replace it with your old Computer's file.
3. Copy Normal.dot from old to new computer and you are done.
Good Luck!!!!!!!!!!!!!!!!
Sep 28, 2009 | Microsoft Office Professional 2007 Full...
Problem opening Access Database-upgrade from Access 2003 to 2007
if the form "products" really exists, then your office 2007 security settings are not allowing to load macros. Try the following settings:-
Office 2007 has some security settings disabled by default to prevent any harm to your system.
go to trustcenter settings(click the office button at the top left of the office 2007 screen then click Access options, then select Trustcenter, then click trustcenter settings.)
In trustcenter settings, select message bar then select "Show the message bar in all applications when content is blocked" radio button.
Then from macro settings ,make sure to select "Disable all macros with notification" . Click ok twice to close the settings windows and try opening the file again.
Good Luck
Mar 25, 2009 | Microsoft Access 2003 for PC
Normal.dotm Won't Adopt Macros & Code is Seen as Full of Bugs
It sounds like your Anti-Virus or Spyware is blocking and won' t allow access, it thinks its harmful, try turning off the Virus software installed, do your thing and then turn the software back on. If thats not it then your Software is damaged and you will have to install a new copy of Office. Good Luck.
Oct 27, 2008 | Compaq Presario 5000 PC Desktop
Macro
you can try macro recorder software, download macro recorder software named AutoMe from
http://www.asoftech.com/autome/
May 16, 2008 | Microsoft Office Professional 2007 Full...
Office 2007 Standard - VBA not working
There is no indication that VBA should not work in all versions of Excel. There is a new file extension (xlsm), which is used to activate macros and allow usage. If you have, perhaps, opened and saved with incorrect extension (new is xlsx), VBA may be unavailable. Try to resave it with the changed extension. It seems likely that this is the issue (reference http://office.microsoft.com/en-us/excel/HP100141031033.aspx?pid=CH100648071033). Also, if you make sure your Save As option is set at xlsm, this should help to prevent problems. VBA should not be an issue in any version of Excel and custom functions ARE available (see http://office.microsoft.com/en-us/excel/HA102189961033.aspx?pid=CH100645021033). It should be as simple as changing the extension, and I would suggest changing the default save as option. If this helps, please rate "FixYa"! Thanks!
Apr 03, 2008 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
