Question about Canon Office Equipment & Supplies
Myprinter will not print all colours they are mainly blue and yellow but very faint. I have carried out ALL the maintenace procedures several times without success and have checked that all the cartridges a re full and correctly installed. Black prints without a problem
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Classic View
Click Printers
Right-mouse-click on your printer, and choose "printing preferences" or "properties".
There may be an option to control how "light" or "dark" the printing will be, i.e., use "less" or "more" ink per page.
Also, click "print test page", to ensure that the test-page has all 3 "primary" colours.
Also, click "clean ink cartridges", to try to repair any blockages inside the ink-cartridge.
Posted on Nov 17, 2009
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
Faint rainbow line of blue/orange/yellow at end of printed photo
You might try cleaning or unclogging the print head[s] with a drop of water or two onto the outlet from the print cartridge[s] and a drop of water or two onto the inlet orifice into which the outlet of the cartridge feeds the ink.
May 18, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Cannot obtain yellow colour.
Clean the Nozzles of the printer, you can do this by the printer driver.
Mar 02, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Card printer is not printing in colour
You have probably bought fake color ribbons , or you have taqken of the blue cup with the rfid inside.. Wich tells the printer what kind of ribbon installed
Nov 19, 2008 | Datacard SP35 Printer
INK
download the utility ssc service from the site ssc.com and use the power cleaning option
Aug 14, 2008 | Epson Stylus Color 640 InkJet Printer
Pixma IP4000 Printer
OK, Canon will hate me for posting this!!!!!
Remove cartridges.
Remove print head.
Go to sink or tub (stianless steel, not pastic type), pick up roll of paper towel on the way.
Fold several layers of paper towel and place on flat surface.
Run HOT water till HOT.
Turn hot water to dribble.
Run hot water through print head, careful not to wet contacts.
When water is clear coming through print head, place print head on paper towel.
Repeat process until no colour on paper towel.
DAB print head (DO NOT WIPE) inside and out to dry.
You may wish to let print head air dry overnight but I replace it after drying.
Replace print head in printer and replace cartridges.
Start printing again
I do this on all my Canon printrs every 6 months
Jun 30, 2008 | Office Equipment & Supplies
I have replaced the inks with new one but I am not getting any colour except a very light yellow
Carry out the two cleaning procedures several times until test print is OK
Apr 13, 2008 | Office Equipment & Supplies
MP360s
Hope this will give you hints. To pin point directly you need to replace printer head. But before replacing please consider suction cartridge caps or nozzle by cleaning and freeing clogged airways by dettaching manually. I understand that the long time being not used has caused the problem. However if you can still use black and other colors then used it than complicating downtime in repairing procedures. Yes, you are right no need to clean deeper more than three times it will consume inks half empty. Have a nice day.
Besr regards,
Rosener Guyano
Nov 22, 2007 | Canon i350 InkJet Printer
Colours printing really faint
dear sir you should check the colour mixing detect sensor
Sep 26, 2007 | Epson AcuLaser C900 Printer
Printing colours?
solutions :
Try changing consumables, if near emty or maybe with defect.
If it does't help, there may be problem with cleaning system, then you have to call for service.
First try consumables
Apr 11, 2007 | Konica Minolta magicolor 5430 DL Laser...
75 people viewed this question
old marine
old marine
