Question about EPoX EP-4PDA2 Motherboard
Does not boot all the way shows a 7F error on the motherboard. just put in a new HD and trying to boot for the first time. Brand: EP 4PDA2
2 Suggested Answers
bill406
  • 34 Answers
SOURCE: Epox EP-9NPAJ
Go into the BIOS setup and select 'Load setup defaults', save and exit.
Posted on Sep 19, 2009
EP-8KRAI motherboard does not see WD2500AAKX SATA HDD
check the cable
make sure the hd is getting power
try another sata connection by swapping the cable from dvd device
make sure you set the drive select some drives require it
do not use cable select
make sure the battery back up has 3 volts
you could try shorting out the bios to reset the motherboard - there should be a jumper on the board, turn power off, the jumper or connect the two pin so the short out, than turn on machine, just for few seconds and turn off, remove the jumper.
xxxxxxxxxxxxxxxxxx important xxxxxxxxxxxxxxxxxx
before or when booting the system push F10 to access bois
setup all devices, dvd, video card, if that dont work you can try F1 or F2 when you start the system
when you exit the bios make sure to save it i think F10 save and reboot. so save new changes and device ID.
Apr 16, 2015 | EPoX EP-8KRAI-X Motherboard
I need EP-4PDA2+ user manual or a list with POST error codes
go to web site of board download them there free and ebay for board
Mar 21, 2010 | EPoX EP-4PDA2 Motherboard
Epox EP-9NPAJ
Sep 19, 2009 | EPoX MB EP-9NPAJ NF4 RET Motherboard
Failed to download audio driver
You should be able to use the Realtek AC97 HD driver available from this link with your audio device.
Post your results here, especially if this doesn't fix your issue.
Apr 02, 2009 | EPoX EP-4PLAI Motherboard
Need a driver for motherboard
You can download all the drivers and updates for BIOS and manuals at the following EPOX link
http://www.epox.com/product.asp?ID=EP-9NDA3plus
Mar 12, 2009 | EPoX EP-9NDA3+ Motherboard
Software drivers for 4pda2 motherboard
Hi, you can download the drivers for 4PDA2 by clicking on this link: http://www.epox.com/usA/product.asp?ID=EP-4PDA2plus
Enjoy!
Need anything else? Post your question here.
Mike
Aug 16, 2008 | Computers & Internet
Boot up problem
Sounds as if you need to change your cmos battery (Cr2032 on motherboard) first of all as i'ts a very cheap item to replace, then set the bios up again, then try to boot, if still no boot you may need an operating system repair.
Sep 28, 2007 | EPoX EP-9NPA3 Ultra (EP9NAPA3ULTRA)...
Blue iMac
It sounds like there's underlying problems unrelated to Panther. If the computer boots from the the old HD, but then the HD didn't show under Disk Utility, this is an intermittent problem. Try replacing the cable that goes to the HD (if there is one), it may have become damaged sufficiently that things aren't working under "heavy use" (like trying to install an OS). If there is no cable, or replacing it doesn't work, I'd suggest putting the original HD in and selling the computer as-is. Again, if it still botos from the old HD, then it's not a problem with the HD or Panther, unless the reconditioned HD you bought was faulty (unlikely but possible). More likely is when you installed the reconditioned HD, something else changes (e.g. connection made better contact) that caused the HD to show.
Sep 10, 2007 | Apple (661-2795) for iMac Motherboard
Unable to restart
Are you saying that you cant restart or shutdown your computer using the software menus, but using the reset or power switch does work? What Operating system?
Nov 29, 2006 | EPoX EP-8K7A Motherboard
EPoX EP-4PDA2 Motherboard Logo
51 people viewed this question
Top EPoX Computers & Internet Experts
Steven Burn
Steven Burn
David
David
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
