Question about Uniden Cordless Phone
It will not charge. Replaced the battery, still will not charge
How to charge new battery
One you have replaced the batteries, place the unit in its charging stand and it will inform you approx. how long until the charge is complete. If not, there will be a charging status bar at the top right hand corner. I would typically leave it on the stand for 12 hours minimum. Also, do not put it back on the stand until it tells you that charging is required. Putting a device on charge before required develops a "battery memory", meaning the battery may be half full, but read as empty requiring a full charge.
Oct 09, 2015 | Uniden DECT 6.0 Cordless Phone
Laptop works great on AC input, Battery charges and discharges per the indicators but will not power up on DC only. What needs replacing?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 03, 2013 | Fujitsu LifeBook S6231 Notebook
Replaced the power board on acer aspire battery will charge to 28% overnight but charge nlight doesnt lightup
Aug 22, 2012 | Acer Aspire 4720 Notebook
My battery dies i replaced a brand new alternator but still dosen't charge tomthe battery
The battery most likely has dead cells and not charging due to the alternator .The alternator is doing what it should, your battery just can't hold the charge the alternator is putting out. Go have the battery tested at a local auto zone or advance auto store. Free to check
Dec 15, 2011 | 1995 Ford Windstar
The cellphone does not get charged
hello there,
There are 3 possible causes of the problem that need to be checked. The phone, the battery and the charger.
Try to insert another battery into the phone and try to charge with another charger, if it charges, the phone is okay, if it does not charge, then it means the phones connection/ charging port is bad and need to be replaced.
Test the battery in another phone and try to charge to see if it will charge, if it does not charge, then the battery is faulty and need to be replaced. But if it charges, then the battery is okay.
Finally check the charger by trying it out on another phone to see if it will charge, if it charges, then it is okay, but if it does not, then it means the charger is bad and need to be replaced.
After carrying out these tests, you would be able to detect the problem and know the best part to be replaced.
Thank you for using fixya.
Caseytech
Jul 04, 2011 | Cell Phones
My garden tractor is not holding it's battery charge. I replaced the battery, but still doesn't hold a charge after I use it.
If you replaced the battery with a new one and it is not holding a charge, then your charging system is not putting out enough power to run the mower AND recharge the battery. So you need to figure what is wrong in the charging system.
Mar 26, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Battery replaced - won't hold a charge. Is the alternator the problem?
THE BATTERY IS ONLY FOR STAR THE CAR. WEND THE THE CAR IS RUNIG ALTENATOR IS CHARGING THE BATTERY FOR NEX TIME YOU NEED TO STAR THE CAR . CHECK CHARGE ON THE ALTENATOR . IF ALTENOTOR NO CHARGING REPLACE.
Apr 17, 2009 | Mazda 626 Cars & Trucks
REPLACED THE ALTERNATOR BUT THE BATTERY WILL NOT CHARGE
check the regulator on the side engine panel
Feb 24, 2009 | 1994 Pontiac Sunbird
Charging system
I had this car about 10 years ago. Loved it!
You must either clean or replace the battery cable. The corrosion is not allowing the charge to get to the battery.
Many parts houses carry a battery post/terminal cleaner that will aid in getting all of the crud away from the terminal.
You should be sure to remove all of the corrosion!
Good luck
Brian
Sep 06, 2008 | 1985 Nissan 300ZX
Uniden Cordless Phone Logo
42 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
