Question about HP Color LaserJet 2600n Printer
Hp color laser jet printer 3000n
Hi the printer has diferente languche corean or some thing... how i can restart it
    President:
  • 4,402 Answers
Try this. BTW, the Button with the "Check Mark" is the Enter button on this.
1). Switched the printer off.
2). Press and hold Enter button while turning the printer ON until CONFIG LANGUAGE appears in the Display.
3). After the power-on self test, lang=English (French, in your case) will appear. Press + button until the desired language (English) appears in the display.
4). Press Enter button to save your choice. An asterisk (*) will appear next to English to indicate it is now the default.
5). Press Online button. The On line indicator will be lit, and display messages will now be in English (you selected).
if that doesnt work try this
press...
green enter button once
right grey arrow button once
green enter button twice
then grey arrow button on right or left of green enter button until you see the language you want.
Select by pressing green enter button
Finished.
Posted on Jan 10, 2008
After some copies I have cleaning message on my Printer hp laser jet CM23220 MFP
If the machine is going into cleaning mode more often than it should the first thing I would do would be to ensure that the printer has the most current firmware installed.Secondly if you are using 3rd party, refilled or remanufactured cartridges they can cause problems as well.
Jun 18, 2015 | HP Laser Jet CM2320NF Laser Printer...
Hp color laserjet 3000n error 51.2
According to the service-manual, it looks like you have problems with the laser/scanner-unit.
Please foolow these steps
1. Press to continue.
2. If the message persists, turn the printer
off and then on.
3. Reseat DC controller connectors J1010,
J1012, and J1021. Reseat laser/
scanner unit connectors J101, J102,
J5001A, and J5001B.
4. Replace the flat cable.
5. Replace the laser/scanner unit as
necessary.
6. Replace the DC controller PCB as
necessary.
If you cannot comlete these steps by yourself, you have to put the product in for service.
May 15, 2012 | HP Color LaserJet 3500 Printer
59.62 error
hp color laser jet 9500 error 59.62 how fix
Jan 28, 2012 | HP LaserJet 9500mfp Printer
59.co printer errar hp color laser jet 3500
This error is a developer motor error not related to any color. Check the back of the printer to make sure that there is no paper jam in the exit assembly. Reseat all cartridges and restart. If it still does not start then the developer motor is probably shot.
Mar 19, 2011 | HP Color LaserJet 3500 Printer
HP 3000n Laser Color Printer - Paper is curling up when it comes out of the printer. How do I stop that?
Make sure you've let the printer know what type paper you are using. In the print dialog on your PC, you must choose in the preferences area whether Plain, Photo, Glossy, Cardstock, Envelopes, etc. Such things control the pressure of the rollers in the fuser, as well as it temperature. Too hot will result in curled paper.
Also, make sure you are storing the paper properly prior to printing. It can't be too damp either, or it will curl.
Finally, if all else fails, your fuser may be overheating and need to be replaced. Hope not. If so, look for a rebuillt one online. Much cheaper than new. Good lick!
May 03, 2010 | HP LaserJet 3000n Printer
WHERE DO YOU REPLACE THE TONER CARTRIDGE IN HP COLOR LASER JET 4500N
Hi Mvsantora
If any help I dont know if you got the manual.
I have put a PDF files on my website for you to download.
hp color laser jet 4500n.
Hope it a help to you, You can download from this links.
Just click on the links it will download for you.
http://www.4all2sell.com/pdf/hp-color-laser-jet-4500n.pdf
you need a adobe reader to see this file If you not got a pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
All The Best: Pineworks
Jan 27, 2010 | HP Color LaserJet 4500n Printer
Colour problem
If the printer gives magenta instead of red you have a problem with one of the other colors. Magenta needs other colors to print red. Print a cofiguration print and check witch color is bad or missing. Replace the cartrridge of the missing/bad color
Dec 24, 2009 | HP LaserJet 3000n Printer
Pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
Sep 19, 2008 | HP LaserJet color laser printer
HP Color LaserJet 2600n Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
