Kenmore 335 CADR Air Purifier Logo
Posted on Nov 17, 2009
Kenmore progressive 335 replacement parts
I have a kenmore progressive 335 ... i need to replace the hepa filter, and apparently, the prefilter. i do not know what to order, since sears says they don't carry them anymore :(((
3 Related Answers
A
Anonymous
  • Posted on Feb 14, 2008
SOURCE: Kenmore Progressive 335
Open the machine and look on the side of the filter. You will find the part number. Sears handles it, too, of course.
Anonymous
  • Posted on Feb 25, 2008
HEPA Filter Replacement Part No. 83376 and Pre-filter Replacement Part No. 83378
kjhbewfw
Ekse
  • Posted on Dec 25, 2014
Hi, filters can be found at amazon, click here and take a look: 1 HEPA Kenmore Air Purifier Filter Fits Kenmore models 83200 83202... I hope this was helpful. Cheers
2answers
I need the owners manual for Kenmore Progressive 335. Where can I find this?
Since it's a Kenmore unit, you can find the Owner's Manual online at a Sears Parts Direct.
Thanks for choosing FixYa.
2answers
How do I change the filter on the Kenmore 335?
According to the Owners Manual, here's what you need to do,
1.Turn the air cleaner OFF and unplug it from the power outlet.
2. Carefully lay the unit down on a flat surface with the Front Grille facing up.
3. Gently push in on Release Buttons on both sides of the unit, pull Front Grille out and away.
4. Remove and discard used HEPA filter.
5. Remove any plastic protective wrapping and from the new HEPA filter.
6. Set new HEPA filter into the air cleaner.
7. Install the Front Grille by engaging its tabs into the bottom slots on the unit. Then swing grille up and gently push in top to snap into place.
8.Turn the Air Cleaner upright and plug it into an outlet for
operation.
Hope this helped you. Please let me know. Thanks
I have a Kenmore Progressive 295 air purifier. I have the model number for the large filter and the dimensions of the carbon filter but, because it is older, can't seem to locate comparable replacement...
Have you looked at Sears' online parts store? Type in the model number, and it will display available replacement parts.
http://www.searspartsdirect.com/
You can also get there from the Sears home page:
http://www.sears.com/
Click "parts direct" at the top of the page.
Where to find the filters for Progressive 335 because I could not find at Sears
Buy online at:
Are there filters that have to be changed and where do you get them?
Yes. You will have a prefilter and after that you will have a HEPA filter. Keep good maintenance on the prefilters which are not washable. You will need to check it once a month to see if it is time to replace. If you have good maintenance on the unit and change the cheaper prefilter, you will get years of service out of you HEPA filter. Bad maintenance means replacing the HEPA filter which is a good chunk of the cost of the purifier.
2helpful
Which way does the filter go? I'm replacing the pre-filter and the hepa filter. Is there a front or a back to either? The hepa is a white square that looks the same front and back, except for diagonal...
there should be a directional arrow to show which way air flow should go, if its framed it will have a pull tab that goes facing out, if it a piece that looks the same on both sides, it can go in either way, if it has a white side it goes facing in
9helpful
2answers
Hi, are you sure about amazon?! I found your part there for 15$ (less than your budget of 25-30$). Take a look again here:
Amazon com kenmore charcoal filter. I hope this was helpful. Cheers
2helpful
2answers
How to "reset" the carbon filter dirtiness scale?
Make it holding the button between 10 & 15 seconds & it works. THANKS
62helpful
4answers
1helpful
5answers
Finding replacement filters
http://www.totalvac.com/HAPF600.html?zmam=6843742&zmas=1&zmac=6&zmap=HAPF600
You can actually use the size B....made by Holmes...Also C for the carbon filters
Top Kenmore Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
