I have an emachines T2542 computer where I just replaced the motherboard with an identical numbers matching unit I bought from ebay. I was informed that if I replaced my MB with an identical match I should be able to boot up from my exisiting hard drive. I am not able to do this. The computer MB will only spin the hard drive but does not seem to read it (I see the LED on the front of the computer on telling me the hard drive is being read and I can hear it spinning but the BIOS says no operating system found). All the numbers are the same on the MB except for one chip that is a different version (older version looks like) but that is it. Please help.
  • malibuvan Nov 17, 2009
    I have two hard drives and when I move the IDE cable from my original HD that came with computer to another one I have, it will read it. I had another motherboard that was not a direct replacement for my computer and it did read my original hard drive, so I can't explain why this motherboard does not seem to read it. I checked to make sure the boot sequence is in fact the hard drive first and it is. I am using a different IDE cable from the other computer that I borrowed this spare hard drive from but it looked like my original IDE cable. The reason I'm using the other computer's cable is that my had a small nick in it, although I never had a problem with it but I was just being cautious and I thought I might as well use the cable that was not nicked.
    Brigadier General:
  • 10,406 Answers
Restart your computer, and enter BIOS-setup.
First, check that the motherboard has detected the hard-drive.
Second, check the "boot-order", to make the hard-drive the "primary" device for booting.
Save/Exit from BIOS-setup, and try again.
Can you remove the hard-drive, and temporarily connect it to another computer? Does that other computer detect the drive? Can you "browse" files on that hard-drive?
Posted on Nov 17, 2009
Dont power
If the m/b is truly broken (not some other component) you will have replace the motherboard. You may be able to salvage the RAM and the processorcooler from the motherboard. You may be able to buy a working identical replacement either from new or second-hand (ebay).
You might even be able to diagnose the fualt and repair it/have it repaired by an expert the motherboard if you are very lucky, but this usually not worthwhile.
Before taking these steps, ensure that the problem IS that he motherboard is actually broken.
20.April.2014
Feb 13, 2014 | Acer Emachines E525 E625 E627 E630 E725...
I am trying to find the power switch diagram for an emachine t6520 thanks
On a Asus motherboard its not designed for eMachines systems because they come with a proprietary setting on the case. So what you need to is take the emachines motherboard that you took out and take the new motherboard that you bought and match the two. If there is a difference then you need to return it or buy a new case and you shift all the hardware from the emachines to the new case. If not buy a similar replacement board from emachines or ebay and you can find one and buy it. The Power setting is on all motherboards but some are different then others.
Dec 04, 2010 | E-Machines T6520 PC Desktop
Front power switch broken. Bezel won't come off easily. Thought we could just get a switch and install on the back but don't know which of the colored pairs of wires go to the original switch in the...
I would suggest this generic Power On switch,
1) http://www.directron.com/atxswitch.html,
and the Red, and Black twisted pair of wires go to the Power On switch.
Your statement of ,"....don't know which of the colored pairs of wires go.....", leads me to believe you may have all of the Front Panel wires disconnected.
How about information as to where ALL the Front Panel wires go?
(Provided I have correctly interpreted your statement)
Back in the time that the eMachines T2542 was made, TriGem was the motherboard manufacturer.
The Model Name of the motherboard is Imperial, and the Model Number of the motherboard, could have been one of four variations offered.
Model Name: Imperial
Model numbers could be G, GL, GV, or GLVE
(Imperial G, Imperial GL, Imperial GV, or Imperial GLVE)
ALL four variations used the same Front Panel header.
(The connector on the motherboard the Front Panel wires connect to, is named the Front Panel header)
I would like you to view this page,
http://www.e4allupgraders.info/dir1/ecase/support/front_panel_header_support.shtml
Scroll down to the heading -
Trigem Imperial Front Panel Header Pinout.
A) Pins 1, 2, and 3 are for the Power On LED light.
B) Pins 5 and 6 are for the HarDDrive activity LED light.
(Pin 4 is not used. NC. No Connection)
C) Pins 7 and 8 are for the Power On switch
D) I wouldn't connect any wires to Pins 9 and 10, nor Pins 11 and 12
E) Pins 14 and 15 are for the Reset switch. (The button you press to restart your computer.
If the T2542 doesn't have a Reset switch, don't worry about it. There are many other ways to restart your computer)
F) Pins 17 18, and 20 are for an internal speaker.
This speaker is used for BIOS Beep Codes.
In the chart to the right, you will see GRD used many times.
GRD stands for Ground.
ANY Black wire in the twisted pair of wires, is a Ground wire.
Most of the eMachines I have worked on, use a Red, and Black pair of twisted wires for the Power On switch.
I could be mistaken on the T2542.
Best method, is to follow the color code of the wires that come from Pins 7 and 8, and be sure.
Aug 17, 2010 | E-Machines T2542 PC Desktop
I just lost all my cd 's with my emachine t2542,i re install new W XP OS because my hard disk was damaged and replace new one,the problem is,it's usb ports doesn't work,help me pls.tnx
In order for us to assess possible drivers that are available for the eMachines T-Series T2542, please download the trial of Driver Detective and run it to ensure a more accurate list of drivers for your computer with less chance of error.
http://www.drivershq.com/Drivers/eMachines/T-Series/T2542/22605/22647/22688/Drivers.aspx
Oct 05, 2009 | E-Machines T2542 PC Desktop
I have an emachines T2542 computer with a bad motherboard (Imperial G motherboard). I am wondering if I have to get an identical motheboard to replace mine if I want to boot up using my hard disc with WIN...
Your better off replacing the motherboard with an Emachine spare, this is because your hard drive will not notice the change when replaced so you can still use all your programs.
If you was to get another motherboard with a different chipset or GPU (graphics processing unit) then chances are the operating system will not boot resulting in loss of data and programs due to a clean install.
Go here, fill in the form and get a quote for a replacement motherboard>>
http://l7inc.us/quote.php?buy.x=29&buy.y=15&buy=Buy&ID=2834574460
Regards.
Aug 26, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
I want to expand my memory, so I went to Fry's with my computer model number and bought a 1Gig memory card, brought it home and the pin configuration doesn't match. The one I bought has two rows of pi
Go to http:\\www.pby.com and look at the memory configurator. You will be asked about your system (make and model). They will then advise you of the specific part number for your memory. Keep in mind, you should never expand upon existing memory. It is always better to replace the memory completely so you don't have to deal with any manufacturing conflicts. Take your new found part number and plug it in at amazon.com
To replace 1 GB of memory completely should cost about $45.00 USD.
May 23, 2009 | E-Machines eMachines Refurbished EMA...
Emachine t2542
When you say out, do you mean they are broken, or just disconnected? Most of these computers have a plug on the end of the wires to the front panel and it just plugs into the system board. If you look at the board you'll see where the front panel wires go. Sometimes it's hard to read the small type, but there are labels on the board that tell you what connector does what.
Nov 17, 2008 | E-Machines eMachines Desktop PC
Mother Board Failure Where do you get a replacement.
ebay!
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board ... - eBay
https://www.ebay.com/itm/...W3706MH...Motherboard.../162597765902?_...
  1. Cached
US$59.99 - ‎In stock Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. ' eBay!
Dell Main Board 01004-2960 for W3202mh W3706mh ' eBay
https://www.ebay.com > ... > TV Boards, Parts & Components
  1. Cached
Used condition; • Returns accepted - 60 days money back or item exchange. Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. See details.
W3202mh W3706mh ' TV Repair Parts & Components Online
https://tvrepaircomponents.com/...motherboard.../discount-w3202mh-w3706mh__part_... Get the best deals on Part in our clearance section in addition to deals on motherboard board, board video motherboard, main video motherboard, main unit, un.
Dell TV Main Board ' eBay
https://www.ebay.ca > ... > TV Boards, Parts & Components > Dell TV Main Board
  1. Cached
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board Motherboard Unit. Model: W3202MH,W3706MH. Type: Main Video Board Motherboard Unit. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. C $74.81.
DELL 37" W3706MC 01004-3190 Main Video Board Motherboard Unit
https://www.ebay.ca > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
SKU: 01004-3190. Brand: DELL; Condition: Used; Notes: Please be sure that the BOARD Part Number and picture on your motherboard is EXACTLY as shown above. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV.
Mar 04, 2018 | Dell W3706MH 37 in. LCD HDTV
Emachine T2542 Won't power on
you need to open the PC and check the power supply for some fuse and safety device that acts like a fuse , these fuse looks like a 3 leg transistor only that it have 2 , look for this , and of course the typical fuse . hope it helps
Apr 19, 2008 | E-Machines eMachines Desktop PC
20 people viewed this question
k24674
jasbo
jasbo
