Question about Onkyo TX-SR876 Receiver
Brand new. No sound from any speakers or headphone. Headphone indicator is on without headphone jack inserted
  • khushroo5 Nov 17, 2009
    Cannot access speaker setup from setup menu (option 2 'Speaker setup' is greyed out.
  • khushroo5 Nov 18, 2009
    Jude, I have inserted headphone jack many times but nothing happens. The speaker setup also remains unselectable in the setup menu.
    Problem Solver:
  • 12 Answers
Try to reinsert the head phone jack there is small switch in side while moving or play the system and try to insert
Posted on Nov 18, 2009
  • Jude Williams Nov 18, 2009
    press the power button and keep press the system will reset
  • Bert Dekker
    Bert Dekker Aug 12, 2013
    Tried it, but still no sound at all..
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
How do I turn off my 550 Samsung tv speakers?
Take the audio out from the audio output RC jacks (Red and White). Then connect a headphone into the headphone of the TV. The speakers then will then get off. Never insert a dummy stereo jack, as the amplifier without speakers can get damaged (depends on the audio IC used).
Jul 18, 2012 | Televison & Video
I have sound from my headphones but nothing from the speakers, pls help
So it IS acting like headphones are inserted even without them. Stop messing with other connections. The jack for the headphones has spring-loaded normally opened and normally closed contacts that are designed to disconnect the speakers when the plug is inserted. Perhaps the NC connection isn't making good contact on headphone removal. With the Volume turned to soemthing NOT LOUD, repeatedly insert/remove the jack to see if it makes any difference; or with power OFF squirt a little tuner cleaner in there first and repeat with the headphone jack.
Jul 25, 2011 | Bose Audio Players & Recorders
My headphone jack is broken on my Dell Latitude Cpx J & i have no sound through my speakers because of this. Is their a way i can change something in the settings so the sound plays through my laptop...
It is a mecanical problem, not in settings. The laptop's headphone jacks have builted-in switches that disconnect internal speackers when the headphone jack is plugged in. You need to replase headphone jack with a new one or manually desactivate the swith - must to get ino your laptop and have skills in work with soldiering iron
May 22, 2010 | Dell Latitude CPX-J Notebook
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
My sony 771 won t play any sound -- not the speakers because doesn't come through headphones either. Just cleaned the lens for CDs last night, then this problem developed. Can see the amp bars moving, so...
The lit indication ("amp bars") proves that the aduio signal is getting through the unit's circuitry @ least to that point; lack of sound @ the spkr & headphones indicates the amplifier portion of the circuitry is either inoperative or disconnected from the load (i.e., either the speakers, or the headphones). A common cause of this type of problem cropping up unexpectedly is the headphone jack itself; in most products of this type, the audio path from the amplifier output to the speaker connection runs through the headphone jack, so the the speakers may be "turned off" when the headphones' plug is inserted into the jack. If the unit's owner uses headphones regularly, the most common problem to be found with the jack is loose solder connections to the printed circuit board's traces from the jacks' lead(s); in units with this problem whose owner's irregularly use the headphones, it's more common to find oxidization of the electrical contacts within the jack itself.
Dec 10, 2009 | Sony Audio Players & Recorders
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
Aug 30, 2009 | Logitech X-540 Computer Speakers
Sound for toshiba laptop
headphone jack maybe damaged from wrong insertion of some material,, try to insert headphone very slowly until sound will transfer to headphone..
Dec 29, 2007 | Toshiba Satellite A135 Notebook
Onkyo TX-SR876 Receiver Logo
251 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
