Question about Sony Playstation 3 (PS3) Console
My av port behind my system is not working is this because I only use my hdmi port.
2 Suggested Answers
SOURCE: Bad AV Multiout on a Japanese PS3
Copied from another forum: "On the PS3 from Standby (red light on) depress the power button till you hear two beeps. That will reset the resolution and you should get a picture." MANY THANKS to the original poster!
Posted on Dec 24, 2007
I bought a insignia DVD player, what cables do I need to hook up. The red white and yellow don't seem to work on hdmi ....what am I doing wrong?
the red white and yellow are rca AV cables
https://en.wikipedia.org/wiki/RCA_connector
does the TV have a HDMI in port ?
https://en.wikipedia.org/wiki/HDMI
Does the DVD player have a HDMI port out ?
If so you need a HDMI cable
Or the DVD player might have an AV out port that is RCA ?
Feb 24, 2018 | Insignia Televison & Video
WHAT DO I PLUG IN THE BACK OF THE TV/DVD COMBO?
You may not have AV ports, AV ports being the ports that you would plug in a yellow video and a white audio cable into, so you may want to take a look at some adapters. Maybe an HDMI to AV adapter?
Tmvel mini RCACVS 3 RCA Composite Video AV to HDMI Converter for TV PC PS3... This one may cost you a bit, but if you don't have AV ports, but do have an HDMI port, this should work.
Dec 09, 2015 | Video Game Consoles & Games
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
How do i set up dvd player
The newer players have an HDMI port on the back. If your AV receiver or television has an HDMI port, connect the player to the AV receiver or television using an HDMI cable, often sold separately. If it's conencted to your television, select the menu option on your television and under "source", choose the HDMI input. Turn on the player and you should see the DVD player logo if all is working properly.
Feb 19, 2015 | Televison & Video
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
How to Hook Up HD AV Cable?
High definition multimedia interface cables are a type of audio/video (AV) cable that hook between your electronic media component and television. HDMI cables allow transfer of high quality audio and video signals between devices with the use of a single cable. HDMI is widely used with current generation video game systems, Blu-ray video players, and high-end video playback hardware. In order to make use of HDMI cables, your television must be compatible with the proper HDMI ports present on the set.
First,plug the HDMI cable into the port located on your media device. Then Plug the other end of the HDMI cable into an available HDMI slot on your television.
Switch the output on your television to the HDMI slot you have the cable connected to.
Aug 12, 2010 | Televison & Video
Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Nov 30, 2009 | Sony STR-DH500 A/V Receiver
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
214 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
